Question about Panasonic Home Theater System System
Can't get the surround sound to play the rear speakers and small front speaker
I purchased a Panasonic SC-PT660 DVD Home Theater sound system and I also have a digital cable box with high definition. My T.V. is a Phillips 47 in LCD T.V. I hooked it up and can't get the rear speakers and the small front speaker to work. I was told I have it hooked for sterio.I also can't get the dvd to play a picture only the sound comes out. Any suggestion.
  • Anonymous Jan 23, 2009
    I followed the directions to hook up a bran new panasonic home theater system to a brand new Phillips LCD TV. I can't set up the remote controll to get the system to work.
  • 31 Answers
Sounds like it's just in 2 channel stereo mode, only 2 speakers working out of 5 and a sub, look for a selector switch for switching to 5.1 surround, as far as the no video problem try replacing the cable for the video connection.
Posted on Aug 07, 2008
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
Rear speakers not working
Some TV is not broadcast in surround... you will not get back speakers from TV, only from DVD.
Feb 16, 2009 | Panasonic Home Theater System System
Panasonic SC-660 speaker problems
The center and rear speakers are off if the PLII is disabled, make sure it is enabled by pressing the PLII button in the remote, you should see it on the display
Jan 22, 2009 | Panasonic SC-PT660 Theater System
Speaker problem
is ther clips on the back of the speeker ??
if so push in on clip and remove wires.
Dec 24, 2008 | Panasonic SC-PT660 Theater System
Speaker wire
Use the same gauge that is supplied for the rear. Probably 24 gauge.Do it with the power off. If the wires touch with the power on the rear output IC will blow. Good Luck
Dec 11, 2008 | Panasonic SC-PT660 Theater System
Sc-pt660 panasonic home theater system
If you press the Dolby PL button which is next to the functions button you should get your surround sound.
Nov 30, 2008 | Panasonic Home Theater System System
Sc-pt660 + 46pz85u = NO SOUND!
Don't worry about sending the TV audio to the Panasonic. Just send a digital audio signal from the cable box to the Panasonic.
DVD - Panasonic connected via HDMI
TV - Panasonic connected via HDI
cable connected to cable box and TV. But you will not really be using the cable connection to the TV (TV Tuner) since you will want HD feed from cable box through HDMI input on TV.
You aren't concerned about feeding the TV speakers because your audio will always come from the home theatre.
Note that some components don't feed audio through HDMI, in which case you will need to use optical digital audio.
Sep 08, 2008 | Panasonic Home Theater System System
Panasonic SC-Pt 660
I fixed the main problem. It has inputs, not labeled as such. one set right next to all the outputs labeled only aux.after plugging in to the TV outputs, and putting the unit on AUX, this was fixed. The surround speakers were harder to work out, After downloading the manual, I was able to get sound out of them, however at a lower level than all the others. Even following the speaker level adjustments in the manual, cant get more volume out of them...I'll keep trying.
May 26, 2008 | Panasonic Home Theater System System
Poor Surround Sound
There is a setting in the dvd player to up the rear speakers to a + setting you have to dig deeep somewhere in the speaker settings. mine did the same thing till I found it.
Jan 08, 2007 | Panasonic SC-HT940 System
Panasonic Home Theater System System Logo
419 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
