Question about Sony PlayStation Portable (PSP) Console
Psp broken the arrows to select a game or load game flip up and down and won't let me select
Hi like psp games help love
Posted on Aug 05, 2008
Do not the psp broken you are so sad!
My psp down arrow button not working... how can i fix it?
The only way is to take it appart and realign the pieces. There isn't a whole lot to them but they have a bezel that is rubbery that pops in and out when the button above it is pushed. This contacts the board under it and sends the signal for the button you pushed. It seems as if the rubbery bezel part under the button is not popping back out so it won't allow you to register a button push. It's not too hard, just take your time, don't force anything, and be patient as these things fit together very tightly and can be broken if forced.
Sep 28, 2012 | Sony PlayStation Portable (PSP) Slim...
Tip
How to Download Games on a PSP for Free
1.Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews (later versions have protections that avoid use of non-commercial PSP games).
To check your PSP's firmware, press the PSP's "home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PS
2.Format a PSP memory stick. (The size of the memory stick doesn't matter since most PSP homebrews are relatively small.) Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
Press the "Home" button and go into the "Settings" section. Scroll down and select "Systems Settings." In the next screen, continue scrolling down until you can select "Format Memory Stick." The PSP will ask you if you want to format the memory stick. Answer "Yes," and the PSP will format the memory stick within just a few seconds.
3.Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading.
4.Unzip the files. Usually, when you download free PSP games, you receive files in a compressed (or zipped), format. This allows a developer to send larger files without the hassle of breaking them up into pieces. However, before you can use these games, you will have to unzip them so you can have access to the individual files.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, (for the PC), or Stuffit, (for Macs). Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.Connect your PSP to the computer via a USB cable. Make sure you place the smaller end of the USB cable into your PSP. Place the larger end into any of the USB ports available on your computer.
6.Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then finally selecting "USB Connection."
7.Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and, it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by 'right-clicking' in the PSP directory and then entering in the name "Game."
8.Run the games you downloaded. After you have installed the desired games onto your PSP, disconnect the device from your computer. In the main menu, scroll to the "Game" section. Select the "Memory Stick" option. The PSP homebrews you downloaded will be contained here. Highlight one of them and press "X." Assuming the homebrew is coded properly and you have the right firmware, it should run just like a commercial PSP game.
on Apr 02, 2010 | Video Game Consoles & Games
My son's psp game is downloaded..the problem is it goes slowmotion every game he play.... what will we do?
Hi there.
Try increasing the PSP's "CPU Clock Game" by doing this;
1. In the main screen, press "SELECT" button and XMB or VSH Menu shows up 2. Scroll down to "CPU Clock Game" which is usually second from top 3. Press "Arrow Right" until the value on the right shows 333/166 (300/150 will also do).
I hope this solves your (and your son's) problem...
Jun 09, 2011 | Video Game Consoles & Games
When I switch on my PSP, it directly goes onto load the UMD game and when I try to quit using HOME button, the buttons and consoles dont work. Then I need to use the hold button after which though the...
Hi. Since you're in UMD Autoload mode, you need to configure that in the PSP Settings. To do this, turn off your PSP and remove your UMD. Now, turn it back on and it won't autoload your UMD since it wasn't there anymore.
Now, go to "Settings" and scroll down to "System Settings" and press X. Scroll down again the selection until you see "UMD Auto-Start" and press X. At the right side will appear the options "ON" and "OFF". Select "OFF" and press O button several times to go back to main screen.
Insert your UMD. Now, try playing games from Memory Stick. You may have to turn off your PSP and turn it on again to finally play homebrew...
I hope this helps...
Jun 07, 2011 | Sony PlayStation Portable (PSP) Console
How to get psp games
Try these steps : 1.
Check to see if you have the right firmware. Firmware is the proprietary operating system the PSP requires for functioning. You need Firmware 1.0 or 1.5 to download free games on a PSP. These versions allow you to play PSP homebrews; later versions have protections that avoid use of non-commercial PSP games.
To check your PSP's firmware, press the PSP's "Home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
Format a PSP memory stick. The size of the memory stick doesn't matter since most PSP homebrews are relatively small. Insert the memory stick into the slot located on the left side of the PSP, where the directional buttons are. Pop open the cover and slide the memory stick in, making sure it's face up and follows the direction of the white arrow.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding; links are provided at the end of this article.
4.
To unzip files, you need to use an unzipping utility. Windows comes with one, and it's relatively easy to use since you just select options from a Wizard. But if you prefer something more sophisticated, consider using WinZip, for the PC, or Stuffit, for Macs. Both of these programs can be downloaded free, though the legal version of WinZip only offers a 30-day trial. Either way, unzipping is as simple as selecting "Extract" and entering in the name of the file you want your games in.
5.
6.
Switch to USB mode. The PSP cannot communicate with your computer unless it is in USB mode. This is accomplished by pressing the "Home" button, scrolling towards "Settings" and then selecting "USB Connection."
7.
Transfer the games onto your PSP. This step is the heart of downloading free games onto your PSP, and it is simple. With your PSP connected to your computer, take whatever games you plan on downloading and place them into the PSP > GAME folder. If this folder doesn't appear automatically, you can create one by "right-clicking" in the PSP directory and then entering in the name "Game."
8.
In case of any problem please revert back
May 22, 2011 | Sony PlayStation Portable (PSP) Console
How to connect psp to internet
Flip the switch up on the right side of the psp. Go to settings, then scroll all the way down to network settings. Click infrastructure Mode. Click new connection. Select a wireless network and follow the instructions it gives you.
Nov 02, 2010 | Sony PlayStation Portable (PSP) Console
How can i download free psp games ?
Follow these steps to Download Games on a PSP for Free :
1.
To check your PSP's firmware, press the PSP's "home" button. Scroll down and select "Settings." From there, select "System Information." The firmware information can be found in the section where it says "System Software." If this section has the number 1.0 or 1.50, you'll be able to play PSP homebrews. If the number is higher, you won't be able to download free games on a PSP.
2.
3.
Download free PSP games onto your computer. Sites like PSP Brew, UR PSP and PSP-Homebrew.eu contain tons of free PSP games. And the downloading process is pretty much the same. You either select an option to download, or you right-click on the file and use "Save As" for downloading. Visit the sites to gain a better understanding.
4.
5.
6.
7.
8.
Oct 31, 2010 | Computers & Internet
Trying to connect PSP but says "the connection to the access point timed out".
1. you will wan to go into the router ( use 192.168.0.1 )
2. select "advance setup" link
3.Select "Application Category:"then click the drop down arrow and select t game consoles"\ then select PSP 3 your game console
4. click "view rule to the right and note.
5. click "add" then "apply"
6. Instruction set is in the router .
7. check you connection with you ISP / you may have lost the ip
8. if so this may be a server issue or firmware issue with your router manufacture if if times out consistently
Aug 11, 2010 | Actiontec (GT704WG) Router
My psp scrreen won`t work
ur psp lcd is broken...go to the nearest psp service repair and they will fix it...
May 10, 2009 | Sony PSP (Piano Black)
While playing with PSP it suddenly gets stuck and screen goes blank
check battery, run without the battery, using ac adapter, see if problem persists did you update psp firmware? if so, undo the update, go back to previous firmware version
Aug 26, 2007 | Video Game Consoles & Games
Sony PlayStation Portable (PSP) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
