Question about Honeywell Heating & Cooling
WE are trying to asjust our honeywell thermostat. It continues to register at 86 and we can't get it to go any lower than that. It's the model that has a small digital window on the left of the thermostat, and two up and down arrows to the right of the window and two square buttons that read hold and select. We have asked our apartmetns to help us and we have been ignored. Can you please help us? It's 105 here in Austin Texas. Thank you!
  • 182 Answers
The problem is very seldom the tstat.I think your air conditioner needs serviced.
Posted on Aug 05, 2008
SOURCE:
I have a honeywell thermostat that will not go below 68 on cool setting, how do I reset so I can lower the temperature
what is your thermostat model so i can give you the exact steps, but for now you can try out the best troubleshooting method out there...
take your thermostat off from your wall or where it is, locate the ppower cables and try to disconnect the cable, and just leave the thermostat for 15 minutes, after that reconnect the power cable and try it again..
good luck!!!
Apr 11, 2017 | Honeywell Heating & Cooling
Hi I have honeywell T822D 2642 model and my son while playing, hit the monitor with ball and the cover came off and since then my lower bedroom heating is not on. Can you suggest what should I check?....
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Mar 09, 2010 | Honeywell Programmable Thermostat Heater
Temp is ten degrees lower than temp called for
HONEYWELL WEBSITE:
Go to honeywell.com
Feb 20, 2010 | Honeywell Programmable Thermostat Heater
Incorrect ambient temperature on Honeywell Model RTH221B
Check in your manual for the thermostat. By pushing a combination of buttons you can get into the advanced installer menu. From there you can make an adjustment to correct the temperature.
Nov 11, 2009 | Honeywell Programmable Thermostat Heater
Honeywell thermostat not lowering temperature
remove batteries let sit a few minutes reinstall.
if still bad replace they are not servicable
Oct 28, 2009 | Honeywell Programmable Thermostat Heater
The heater runs and doesn't want to shut itsself off
check the wire to the thermometor then if the wire is ok replace the thermostat
Mar 03, 2009 | Honeywell Programmable Thermostat Heater
Honeywell round thermostat Model #T87F continuously running
you either have 2 thermostat wires bare and touching or a zone valve stuck open
Feb 28, 2009 | Honeywell Programmable Thermostat Heater
Problem with Honeywell RTH230B Thermostat
Sounds like you have it wired wrong..   Pop the top off and give me to color of the wires and tell me which letter each color wire is on.. that will tell us right away if you have it wired wrong
May 27, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
