THREE DIGIT PROGRAMMING CODE FOR VIEWSAT DV3
I have a VIEWSAT DV3 Satellite Box to view DISHNETWORK Programs & have misplaced my REMOTE, Just purchased a Universal Remote & cant program it to work with this box, i cant seem to find the three digit code for this BOX, PLS HELP ...........
ovais
  • Anonymous Apr 02, 2009
    tengo problamas con mi caja
SOURCE: Innovage jumbo universal remote code
try this website, you have to scroll down and find "Innovage" on the list and then it will download the pdf of the manual.
http://www.xdiv.com/remotes/
Posted on Jan 03, 2008
Kazong
  • 152 Answers
SOURCE: Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Posted on Feb 05, 2008
betlor
SOURCE: missing cjannels
do a auto scan on all sats
Posted on Feb 08, 2008
  • 11 Answers
SOURCE: Universal remote codes for Philco digital to analog converter box
http://www.remotecodelist.com/remotes/
Posted on Dec 12, 2008
  • 56 Answers
SOURCE: remote contol will not work
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380052#h:1020.989
directv remotes are not guaranteed to work w/ all types of TV's. when programming remote to TV, make sure you are holding down MUTE and SELECT both at the same time for about 4-5 seconds. until it blinks twice at the top of the remote. also the slide switch must be under the "tv" mode on the right hand side. the website i provided is by directv, and has a list of their codes for the brand of tv that you have.
if you are trying to program a remote to a directv box, and none of the codes are working for the directv box, contact directv to have them send you a new remote.
Posted on Apr 05, 2009
Need the codes to program dishnetwork remote to work the zenith converter box
Hey there marlastewart!
I can definitely assist you in getting the codes for that. You can view this link http://www.dishnetwork.com/SupportSection/apps/remotecodes.aspx to search for codes based on the equipment and brand.
If none of the codes work let me know and I can try further troubleshooting with the remote!
Tommy Faust
DISH Internet Response Team
Jan 05, 2012 | DISH Network IR Remote Control
To program venturer tv to dishnetwork receiver
Hi my nameis Mike Houston of DISH Network and I see you want to program the Venturer TVto our DISH Network receiver. We currently do not have the three digit code(s)for the Venturer TV, what we do have to setup the remote is called a Power Scanand it will find the code to setup the remote to the TV. I will send you the linkto help with the setup; http://www.dishnetwork.com/SupportSection/power-scan-instructions.
Jul 28, 2011 | dishnetwork.com
My remote will not turn the tv on or adjust the sound, it will change channels
First, try pressing TV on the remote, check if that solves the problem. Then press Sat and try the TV power button again. If the remote previously controlled the TV, you lost the code for the TV. If you have your Dish Network manual, check if you wrote down the code when it was originally programmed. Which specific remote/receiver do you have? The programming directions and code lists are available here: http://www.dishnetwork.com/supportsection/remote-setup . You can also scan all of the codes to find the correct one: see http://www.dishnetwork.com/SupportSection/power-scan-instructions . Additional remote/receiver manuals are here: http://www.dishnetwork.com/SupportSection/manuals .
The direct coding procedure for the Dish remote that I have is: while facing the TV to be controlled (after adjusting the key for TV1/TV2 in a multiple TV system), press and hold TV until all four indicators light up. Then enter the 3 digit code. Press and release the # key. Then see if the code TV powers off when you press Power. Then press Sat and check if the TV power button works. Try additional codes if the TV doesn't respond.
If you recently got a new TV and you tried to program the remote for your TV, your dish remote may not have the code you need. (Most universal remotes are limited to codes for devices released 6 months or more before the remote was programmed.) In that case, you should use the TV remote (and see if it has an option to control the satellite receiver). Alternatively, get a new universal remote that will control all of your devices. (The remotes that can be programmed by USB are the easiest to set up.)
I hope this helps.
Jul 09, 2011 | DISH Network IR Remote Control
Cannot add new 722 dishnetwork satellite box to remote
I can help you program your Logitech Harmony 520 remote for your Dish Network satellite box.
The Logitech Harmony 520 remote control is programmed through the Harmony Setup Software you can download from here.
Once installed, you will simply run the software, and select the devices you would like to control from menus. The software finds the right codes for you and loads them into your remote control.
I hope that helps.
_____________________________________________
Harmony 520 Manual Download
Logitech Harmony Firmware Update
Harmony Win Software Download
Logitech Harmony Safe Mode Fix
Harmony Remote Glow Light Fix
May 23, 2009 | Logitech Harmony 520 LCD Remote Control
Remote control code
i've zenith universal remote control and i need to program my viewsat 2000. Do you now the codes?
my mail is japenax@hotmail.com thanks.
Dec 23, 2007 | Televison & Video
Fta viewsat extreme dead.
I am using viewsat extreme 2000. After downloading the new program PC-STB. Front panel power has gone. Only rear light on. All view has gone.
Would you please send me by email, how can I solve this problem? I shall be grateful if you please reply.
Thank you.
-Rajesh
rkb@295.ca
Dec 11, 2007 | Audio Players & Recorders
"No Signal" on ilo-26hd
Call Dish Network at 1-888-284-7116 and they can walk you through the remote program setup. Or you can look in the instruction manual for code searching using the DN remote control.
Feb 26, 2007 | iLO 2600 Television
Televison & Video Logo
476 people viewed this question
Top Televison & Video Experts
