Question about Dell OptiPlex GX520 PC Desktop
Dell optiplex won't Boot-up.. Orange light on motherboard
My Dell optiplex gx520 is not booting up everytime i press power button. Tha CPU and Pow Supply fan is not working whenever i press power button. when i plug the power cord to the Power Supply there is an orange light indicator on the motherboard. What des this mean?
  • 5 more comments
  • bacondon Aug 08, 2008
  • godlistenser Aug 14, 2008
    I'm the It personnel with the same problem,before this my pc had power supply problem then i fixed the new one but once the power is connected to the pc on the motherboard it lights orange and on the switch it just blick red therefore no further process.I have tried to connect the same power supply to another machine and it starts properly so can i have ur assistance plse?
    regards
  • Anonymous Oct 05, 2008
    I have a dell optiplex g260 with the same problem (almost). It does power up but it's light on the motherboard (usually green) has turned yellow.
    The boot screen does'nt show. The screen, graphics cards, cables etc. all work but still nothing.
  • Anonymous Nov 19, 2008
    It's the same issue. I will try to re-sit the memory!
  • Anonymous Mar 25, 2014
    won't boot up
  • Anonymous Mar 29, 2014
    system will not boot
  • Anonymous Apr 01, 2014
    but our IT removes some parts like RAM and what else they remove.....and i plan to put ghrapics card on it if it can be fix....but now only i need to know wht to check why it automatically start and wont off,and why it wont give any display on my monitor.
Orange light indicator on the mother, replace power supply, same problem
Posted on Sep 30, 2010
  • 326 Answers
Its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
Have the same problem. Tried swapping the power supply with a known good one. Didn't help. So the orange light definitely doesn't just indicate a bad PSU. I'm gonna say this MB is a gone-r...
Posted on Aug 13, 2008
I had the same problem, try reseating the memory, it worked for me, I am running a memory test now.
Posted on Sep 19, 2008
How to solve orange solid light on my dell GX520 when i boot it
Nana, A solid amber power button on your GX520, indicates a motherboard failure. The motherboard will need replaced. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Solid orange power button on Optiplex GX520
My Dell Optiplex GX520 will not boot Forums
Dell Optiplex GX520 amber solid light no power
Aug 05, 2016 | Dell Computers & Internet
Dell OptiPlex GX520 PC Desktop won't power on
An Amber blinking power button indicates a low voltage problem. This can be caused by a defective power supply or a defective motherboard. Just to make sure that nothing else is causing the problem, remove any PCI cards like modem, video card, sound card, etc... Remove the memory modules and disconnect cables to CD/DVD drives. Look at the USB ports to see if any are damaged.
Jan 31, 2014 | Dell OptiPlex GX520 PC Desktop
DELL GX 520 Motherboard power led is orange, power button led is orange, the fun is running, no beep, no display....somebody help me with this dell gx520. sometimes it displays 3 and 4 lights on the front...
you should replace the motherboard or the power supply of your computer. to determine which one to replace is a simple test. disconnect all that is connected to the motherboard and if the problem is still there, then the problem is the motherboard.
May 06, 2011 | Dell OptiPlex GX520 PC Desktop
I have a dell Optiplex Gx520.When i put it on,the power button is a steady yellow clor and the PC will not boot up.Please help. Thanks, Farous.
here is the link that explains what these lights mean and how to resolve it. http://support.dell.com/support/edocs/systems/dim4700/sm/adtshoot.htm
Nov 04, 2010 | Dell OptiPlex GX520 PC Desktop
THe pc gives a steady orange light when power
Sounds like its in either standby or hibernate. Try unplugging it if it wont power on, press the power button, wait for 2 minutes then plugging it back in then turn it on. Afterwards, go into power managment, and find where it asks what do when you press your power button change from hibernate/standby to ask what to do.
Mar 07, 2010 | Dell OptiPlex GX520 PC Desktop
Unable to upgrade onboard graphics on dell gx520
Try disabling your onboard graphics in the BIOS. Some BIOS allow this. If you have a sound card, disable the onboard sound too. Count your beeps. they contain a code. Go online and "Google" bios codes. This should give you a starting point to diagnose the problem.
Oct 10, 2009 | Dell OptiPlex GX520 PC Desktop
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
CPU fan runs at high speed and won't boot
Change the setting in the BIOS menu. reboot your computer.. when you see the dell logo.. press F1 (or F2 if F1 doesn't work) button until you see the BIOS screen. Check for fan options and change it
Jun 20, 2009 | Dell OptiPlex GX520 PC Desktop
Dell gx520 will no boot, no response
ok
open cpu cover and refix RAM and connection of power cable and data cable to harddisk.
Apr 16, 2009 | Dell OptiPlex GX520 PC Desktop
Dell OptiPlex GX520 PC Desktop Logo
5,325 people viewed this question
Alun Cox
