Question about Dell Inspiron 600M Notebook
No power power supply is working, output is 19,3 v. but my inspiron 600m doesnt show any sign of life.
  • rebel102469 Oct 04, 2008
    I am having the same power problem, the light is on from the AC power supply but the second I plug it into the computer the light goes out and the rest is obvious, no power, no nothing......
    Genius:
  • 2,028 Answers
Two things you can do. 1- remove the battery and try starting with the supply only. Dell batteries are notorious for causing a no start. 2- remove the memory and try starting with one chip in one then the other slot, then try the other chip. A bad memory chip can also cause a no start. If these don't correct the problem, then it's going to be with a motherboard component, most likely the power management system. You will need to take it in for a professional diagnostics in order to trace the exact problem area.
Posted on Aug 05, 2008
SOURCE:
PA 21 adapter shows no sign of life. LED does not light up. No output voltage
Try another mains power cord. If this does not work then the PA-21adapter is faulty and needs to be replaced.
Jun 13, 2011 | Dell PA-21 Family AC Adapter For Dell...
My charger won't charge. Computer detects plugged in but no charge
This is usually caused by an old or defective battery or possibly the power supply is a few volts too low to activate the charge indicator. It might be charging but not letting you know.
Try to run it off battery for a while (look at the battery life) and then plug it back to for a while then unplug it again to see if the battery life if higher than before.
To check the power supply you will need a volt meter that can read at least 20 vdc (most power supplies are 19 vdc). Put one lead of the meter on the inside of the plug that goes into the computer and the other pin on the outer silver part while the power supply is plugged into the wall outlet. You should read close to what the Output Voltage on the power supply says which should be on the sticker on the back or side of the black box part of the power supply.
Mar 10, 2010 | Dell Inspiron 1545 Notebook
Wireless network problem with Dell Inspiron 600m.
Your wireless router is acting as the mechanism to hand out IP addresses using DHCP.
Sometimes glitches occur and I would recommend unplugging your wireless router from its power surce, letting it sit for a minute or two and replug it back in.
It will come back to life , reset itself and start handing out IP addresses to all computers and peripherals that normally connect to the router.
Nov 27, 2009 | Dell Inspiron 600M Notebook
I replaced a motherboard for my Dell inspiron 600m with a used one. It works but system thinks its a latitude d600. I tried to update the BIOS using the Dell BIOS for the 600m and i got a message that...
If everything works OK I wouldn't be concerned what the system thinks it is. If you go messing with the bios, and install the wrong version, the your system won't work at all! As long as the system does what it is supposed to do I would care less what it shows as a system name, and wouldn't worry about it.
Hank.
Nov 01, 2009 | Dell (04U621) for Latitude D600, Inspiron...
Unable to connect my pc to TV
The reason why your TV is showing no input from your laptop is because of the display resolution of your graphics card, which is higher than what the TV can handle.
What you can try is, when your system is powered up, just go to your display settings, then reduce the systems display resolution to--preferably 800x600, then go to where you normally select the output, and select 'Output to external monitor"...this should send the signal input to the monitor.
Most Laptop graphics display resolution are generally very powerful as compared to what the TVs can handle.
I have actually dealt with a no input signal like this before, and this was what I did.
Hope this helps.
Jul 18, 2009 | Dell INSPIRON 600M HARD DRIVE CADDY 6X609...
CAN NOT CHARGE BATTERY AND AC POWER NOT WORKING ON MY DELL 600M INSPIRON
the battery could be a bad one or it my be a bad dc jack and would need to be replaced
Apr 28, 2009 | Dell Inspiron™ 600M PC Notebook
General question
all I can say is go to tiger direct .com and compare prices
Dec 09, 2007 | Dell (04U621) for Latitude D600, Inspiron...
No Power
This is a motherborad problem If the machine if new-ish contact Dell A reair shop may be able to help- but a machine that is more than say 2 years old is proba;by better simply to replace it.
Jun 22, 2007 | Dell Inspiron™ 600M PC Notebook
Dell Inspiron 600M Notebook Logo
98 people viewed this question
Ekse
Clive
Clive
