Question about GE JGSP23 Gas Kitchen Range
Propane Conversion Burner Turndown
We purchased a new GE range in 2003, converted to propane, and installed it in 2004. The burners do not turn down adequately, causing significant cooking difficulty. For example, when making pancakes I must turn off the burners between batches to let the griddle cool. Is our burner turndown problem a standard problem with gas-to-propane conversions? and is there anything we can do to correct this problem? Thanks for your help.
    Master:
  • 382 Answers
Well really i hope your burners are worn out,thats the reason why it is not syncronised and obviously cannot control the propane flow adquately..Check with it,if its worn out then try to replace them!!...Thank you
Regards!!...
Posted on Aug 04, 2008
  • 4,472 Answers
It has to do with the diameter of th holes. The holes for natural gas are much bigger and this sounds like could definitely be your problem.
Thanks,
lee
  • Lee A.
    Lee A. Aug 04, 2008
    take it to your local appliance parts store and make sure they are the right orifice for propane.
    Hope that helps and if you have a moment to accept and rate the solution I would greatly appreciate it.
    If you need any further assistance let me know.
    Thanks,
    Lee
I've just converted my stove from natural gas to propane and the oven and broiler flame are both to high, how can I lower them?
When converting from natural gas to propane you have to switch the regulator to propane. then on most modern stoves you have to turn the orifice hoods down to adjust for the higher pressure of propane. there are some stoves that you have to purchase a propane conversion kit with different orifices for the burners and oven burners.
Oct 01, 2015 | Kitchen Ranges
I have a new Frigidaire Professional gas range. I am trying to convert it to propane and I do not know how to convert the oven burner.
need to get a conversion kit if not already set up for one the pressure is different between natural gas and lp/propane gas set ups
Aug 29, 2015 | Frigidaire Kitchen Ranges
Do older garland gas stoves need a conversion kit or can they be adjusted from nat to propane
They must be converted. New burner orifaces for burners, griddle, and oven and a new regulator for the gas valve.
Apr 30, 2014 | Garland Kitchen Ranges
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
79012 / 79014 / 79019 Gas Kitchen Range: The propane converson seems to be done right, howe...
It sounds like during the conversion process a step or two may have been missed.
The gas orifice for the main oven burner is most likely to large (was not converted to LP), or the air shutter on the burner was not adjusted. I would not use the oven with the flames that way.
There should be instructions with the installation instructions on how to convert the oven, basically on most oven burners the orifice is screwed down (tightened) until the flame is the right size, then the air shutter on the burner is adjusted for a blue flame.
Let me know if you have questions
May 05, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Oven gas will not flow with pilot lit
There are basically two types of ranges to deal with:
those with sealed top burners, which are pretty much the standard today, and the conventional, 'non-sealed' ones.
While they operate in much the same way, their conversion is usually different. There are still a few ranges that use adjustable sealed burner orifices, but most are 'fixed' and must be individually replaced to convert each burner from one fuel to another.
(An orifice is simply a small brass fitting with a specifically sized hole very accurately drilled through it, and, if adjustable, has a provision to change the size of this hole by turning closed a threaded portion).
Either way, basically what you're doing when going from natural gas to LP is changing to a smaller orifice to allow for the higher pressure supplied by the 'bottled' gas (The available energy in each ft of gas is different too, but for our purpose here that's not important). Natural gas supplies typically run around a pressure of 5.5 inches water column, while LP runs at twice that pressure, averaging around 11 inches.
The orifice through which the gas travels to the burner must be smaller to accommodate this difference.
Adjustable orifices are simply 'snugged' down, clockwise, with a 1/2 inch open-end wrench, to convert them. Nearly all oven burners use these too - more about that in a minute.
Fixed orifices are replaced, and the good news is: the LP parts are usually included with the new range. On some brands (GE being one), the unused set is attached to a storage point on the stove, and this is a great idea. This way, they can't get lost, and if you ever want to convert back, there they are!
The not-so-good news: these little top burner orifices very often require a metric wrench to remove & install. And some can't be changed without a very slender wrench or nut driver.
Aug 08, 2009 | Imperial Kitchen Ranges
How do I utilize the self cleaning part? Do I just press ''clean
  1. After self cleaning the range the door won't open
  2. Amana gas range conversion from NG to propane
  3. A tip on cleaning the surface grates
  4. Checking an common oven temp sensor
  5. Checking an common oven temp sensor: What does an oven temp sensor look like?
  6. Gas range repair aid - such as, my oven won't work or heat up, which style of gas oven do I have, the glow coil gets red but my oven burner will not light.
  7. GE gas range conversion from NG to propane
  8. How to change the oven temp on some common electronic controlled ovens
  9. How to re-light a surface or oven pilot light
  10. How to change a common oven glow igniter coil
  11. How a common gas valve works - click here.
  12. How Ranges, Ovens, and Stoves Work
  13. Help for storing an appliance
  14. Important Disclaimer
  15. Installing a gas flex line connector
  16. Maytag, (some) Magic Chef, (some) Jenn-Air gas range surface spark module - new module kit
  17. Maytag ( Magic Chef - Crosley - Jenn Air ) gas range conversion NG to propane
  18. My gas range flames die when I turn on more than one thing at a time
  19. My Range is flashing an " F1 F2 F3 F4 F5 F7 F9 " something, what does this mean?
  20. My surface burners keep "clicking" even after the burner is light
  21. Oven door and door hinge help
  22. Oven temp sensor - how to change helps
  23. Repair tips and information on surface burner spark modules and igniters
  24. Some "how to set the self clean" on my range
  25. Stainless Steel Cleaning
  26. Surface burners wont work
  27. This morning I noticed the range top ignition was clicking all by itself every 15-30 seconds
  28. Test for F1 fault code
  29. WCI - Frigidaire ( some Kenmore's ) gas range conversion from NG to propane
  30. WCI - Frigidaire /open burners/ (some Kenmore's) gas
  31. Whirlpool Direct Spark Ignition (DSI)
  32. Yes, your glow bar igniter can glow red and still be bad!!
Apr 01, 2009 | Maytag MGR5765QDQ CleanDesign Gas Kitchen...
GE Profile Gas Range oven light doesn't work even after changing
Apr 01, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting from natural gas to propane
Where do all orifices go on anything gas? Right there where the burner meets gas valve. The air shutter sits right in front of the orifice for proper air to gas ratio right.Go out and look at yer gas grill. Where the burners meet the gas valve ye shall find the orifice.
Mar 14, 2009 | Jenn-Air JGR8850 Gas Kitchen Range
Natural gas to propane
GE is one company which generally includes all necessary parts and instructions for conversion to LP with the range without having to order or purchase anything extra. Check the mini manual in the white envelope pasted to the back of the range for instructions. Generally, the LP orifices are in a metal holder near the gas regulator (right where the gas connects to the range). You will have to flip the plunger in the center of the regulator and turn down the collar (with a 1/2 inch open end wrench) on the oven burner and broil burner about 3 full turns. Air shutters are usually OK without any adjustments.
Sep 17, 2008 | Kitchen Ranges
GE JGSP23 Gas Kitchen Range Logo
112 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Richard Roth
Richard Roth
Are you a Kitchen Range Expert? Answer questions, earn points and help others
