Question about Hoover Vacuums
The brush rollers are on off, how do i turn them on? model #u6616-900
  • Anonymous Mar 07, 2009
    Hooverwindtunnel S3639 roller brush not spinning
    Novelist:
  • 97 Answers
There is a slider on the front of the hood labeled "brushroll on/off. Carpet/ Bare Floor."
Slide this switch over to the carpet position. Note that if the handle is upright, it will not shift into "carpet" mode until you drop the handle back. This is a safety feature.
If the brushes are not turning at all, it is either your rubber belt, or possibly a problem with the belt tensioner.
-R
Posted on Aug 04, 2008
I changed the roller brush on my Oreck XL Insight vacuum and now when I turn it on it only runs for about 5 seconds and shuts down Any ideas
Bigme03,
It sounds like you may have been given the wrong brush roller. Several models of Oreck's have a sensor in them that watches for the brush roller turning at the proper speed. The way they do this is by mounting a magnet into the brush roller and the sensor counts the number of times the magnet passes. If that magnet is not there or if the sensor does not detect the magnet passing, ie..a broken belt, it will shut the motor off. The only way you can fix it is to get the correct brush roller and put it back in. Hope this helps!
Mar 07, 2015 | Oreck XL Insight Upright Vacuum
Why the Dyson dc 41 roller brush will not turn?
Try these steps:
  • Check the button that turns off the roller brush to make sure you didn't press it by accident.
  • Unplug the vacuum and clear pet hair and other debris off the roller brush. It may stop as a safety feature if the roller brush is too restricted.
  • Make sure the belt to the roller brush is placed correctly and not broken.
  • Press the roller brush reset button. It may be located on the side of the vacuum's head, or inside the handle. The switch may need to be replaced if it's defective.
  • The roller brush is disabled while the handle is in the upright position, so tilt the handle backwards while testing the roller brush.
I hope that helps you!
Jun 21, 2014 | Dyson Dc 41 Ball
The brushes on my Hoover Steamvac Widepath LS SpinScrub model # F6040 900 are not spinning. What should I do to get the brushes spinning again?
On those models the brushes are turned by suction.
1. Check the lower tank to be sure its completely closed and sealed.
2. Check the lower tank to be sure the tools filler plate is in place (if you used the tools recently)
3. If both 1&2 ok, manually turn the brushes, if they do not turn freely you may have a stuck turbine or bad brush block.
4. Take the brush block out by releasing the tabs on each corner being careful not to break them.
5. Place a large flat blade screwdriver in the square drive hole that drives the brushes under the machine. Gently turn. It should turn slowly with some resistance. If it turns slowly it is ok. If it turns with no resistance it may be bad as well. If it will not you may be able to break it loose with some even pressure being careful not to strip the hole. If it will not turn or makes a lot of noise replace the Turbine assembly.
6. If the brush block has a broken drive shaft or will not turn replace the brush block.
Here is what that brush block should look like.
http://www.vacuummedic.com/product.php?id=206
Good Luck!
Aug 21, 2012 | Hoover SteamVac F5914-900 SpinScrub...
Replace belt on hoover vacuum U4655
Turn the machine over and remove the 4 screws which hold the cover on the brush. Remove the cover and brush roller. Remove old belt. Slide new belt over the motor pulley, first. Then slide roller through new belt (if self propelled model, slide roller through the small belt, also) and slide brush roller into slots on housing (note: slots are different, match roller sides to correct slot.)
Oct 22, 2011 | Hoover Vacuums
How do you replace the beater bar belt on the hoover u 6626-900
It is not a "Beater Bar". Hoovers have brush rollers and are easy to replace. Turn the machine over and remove the 4 screws which hold the cover on, over the brush. Remove the brush roller. Slide the new roller through the small belt (self propelled models) and secure into slots (note: slots are different, match roller sides to correct slot.
Sep 20, 2011 | Hoover U6630-900 WindTunnel Bagless...
Roller brush on Kenmore model: 116.31199100 won't turn
Refer to Larryclare1's solution at http://www.fixya.com/support/t1095798-kenmore_model_116_powermate_jr_stopped It worked great for me. Replace the belt, which you can get at Sears Parts store/online and clean out the hair as per Larryclare's instructions.
Feb 27, 2010 | Kenmore Vacuums
Anyone know why my Bissell Proheat 2X Turbo Model 9300's brushes won't turn anymore
If the Brushes don't rotate, & you have two brushes; 1). Turn unit on side. ( Make sure unit is up-pluged) 2). Rotate the front brush roller, if the second roller moves at same time, 3). Locate a small ribbed belt that goes from the further back roller, to a small ribbed pully. (Gates belt #177-3m5) ( on side under a clear cover) The belt may not be broken, but may have carpet fuzz / lint covering the belt ribs, causing the belt to slip. If that belt is OK and you find that the small pully doesn't turn the belt/rollers, the problem is with a small internal direct drive motor, that drives the brush rollers. At this point return the unit, as Bissell has a design defect & is using cheap parts.
Nov 04, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Eureka the boss 5893A brush roller will not work
is there anything jammed underneath.can you turn the brush roller by hand.if not then take it back where you bought it.sounds like you have a defective brush roller
Jan 11, 2009 | Eureka Altima Upright Vacuum Model 2996AVS...
No manual
Take the hood off of the unit, and remove the brush roller and belt. Wrap the new belt around the shaft of the motor and slide the brush roller inside the loop of the belt. Use the brush roller as leverage to stretch the belt out and slide the brush roller back into the roller housing. Once you have it installed correctly, make sure the roller and belt are free, by spinning it by hand. If that belt is pinched it will just burn it up when you turn the unit on.
Good luck
Oct 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
Rotating bruch
take off the bottom cover where the roller brush is a few screws should be all it takes underneath cover should be roller and belt if belt is broke replace it lift up roller there is a slot for the belt to run in put other end should be the motor side put belt around pulley bar put it back the same way it came off.
hope this helps
Dec 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Vacuums Logo
88 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
