Question about Kenwood VR-7080 Receiver
Kenwood vr-7080 I have an optical cable from the output of my TV to the optical input on my reciever and dolby digital mode will not come on.i have tried to auto detect, manual and nothing works. I have also had it to the shop twice and it works fine there. Also after being on a while it starts to pop, click and make some weird digital jumble noise. Thanks for your input. Lou
Your vr-7080 over heats , thats why, it pops like that and the sound
is horrible at times after its been on for a while,
i installed a internal fan and, that solved my problem.
Posted on Feb 07, 2015
    Problem Solver:
  • 6 Answers
Is your tv wired to a cable box or an HD antenna?
Case 1: If your signal is weak, then the chances are that the feedback from your tv to the receiver's processor cannot interpret a Dolby Digital signal.
Case 2: Check the TV MENU AUDIO setting. Does your TV have a ON/OFF feature for the optical output, or any aux. speaker outputs?
Posted on Feb 17, 2009
I need to hook up my Kenwood vr-207 to a satellite HD receiver and blue ray player. How do I hook up the component cables. I am not sure where to plug in the "in's" and "outs".
In's always go to Out's.
The VR207 has no component video inputs, just a composite video output so you can use your TV for the receiver's On Screen Display.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Home/Manuals/vr207.pdf
Just run your BluRay and Cable box HiDef HDMI, component, s-video, composite video, whatever (in that order of preference) to a matching input on your TV or monitor.
As a rule you should run the best audio from each of your video sources to the VR. There is no compelling reason to ever send good audio or video to a device that has little (or no) use for it.
Unfortunately, the VR207 has no digital audio inputs, so the best it can muster regarding surround is Dolby Pro Logic derived from 2-channel inputs.
BUT, if you have a DVD, BLURAY player or cable Box with 5.1 analog outputs you can let their internal circuitry decode Dolby Digital programming to true 5.1 for input ("DVD/6CH") to the VR207.
Feb 05, 2011 | Kenwood VR-207 Receiver
Got a Kenwood vr405 surround receiver, a Sanyo plasma TV, hd cable box and an insignia blu ray player. Both the cable box and the blu ray player are connected via hdmi to the TV and the TV is connected to...
If you would like to use high definition audio decoding, connect the HDMI from the blu ray player to the receiver. If that it not an option for you due to lack of equipment such as an additional HDMI cable to go from the receiver to the television for the video portion of the signal, then connect your optical cable again. After the optical cable is connected, make sure the Dolby Digital decoding is enabled on the receiver, and that the media you are playing also has a version of 5.1 surround sound. Then, enter the setup menu of the player (which I suspect this is actually where the problem might reside in your case) and make sure that Dolby Digital and DTS are not set to "downmix." Dolby Digital should be set to output Dolby Digital and so on and so forth...hope this helped.
Jan 14, 2010 | Kenwood VR-405 Receiver
No surround sound from Kenwood VR-5090
please select the 5.1 option in the audio menu of the reciever.
Jan 10, 2010 | Kenwood VR-5090 5.1 Channels Receiver
How do i get dolby digital to work on my kenwood vr0405 reciever?
Make sure your source is playing something that has been recorded in dolby digital, not all dvd's and tv boxes transmit dolby digital. what is your source?
Dan
Dec 27, 2009 | Kenwood VR-405 Receiver
I have a vr-405 5.1 channels reciever, I have it hooked to nanlog out on tv per tv manual,tv speaker r off,there is a dvd/vcr hooked into video 1 and it works on tv speaker, where do i hook into the...
try to be a little more clear on what you are trying to do.do you have it connected to hdtv and cable box if so run hdmi cable from cable box to tv and then run optical cable from reciever to cable box you then must turn reciever to cd/dvd to listen to it leave reciever in auto mode go into cable box menu under audio and select dolby digital
Feb 21, 2009 | Kenwood VR-405 Receiver
Unit does not detect/play dolby dts/5.1 from DVD
make sure that the the DVD setting on your reciever is set to look for the the fiber connection (if it is not looking at the coorect input it will not work)
Oct 04, 2008 | Kenwood VR-309
How do i use the dolby digital
You have to connect your dvd player to your kenwood receiver by using the digital port.
DVD ------------ Digital out
Receiver ------------- Digital input
Apr 09, 2008 | Kenwood VR-405 Receiver
Kenwood vrs-6100 receivers optical digital
You want to receive the optical signal from the TV's built in decoder / receiver to play through your Kenwood? Maybe you need to select the digital input. The manual says:
Use the INPUT SELECTOR key (or Input Selector keys)
to select DVD, VIDEO or FRONT AUX.
2 Press the INPUT MODE key.
Each press switches the setting as follows:
1 "F-AUTO": Auto detect
("AUTO DETECT" indicator lights up)
2 "D-MANUAL": Fixed to digital input
("DIGITAL" indicator lights up)
3 "ANALOG": Fixed to analog input *
("AUTO DETECT", "DIGITAL" indicator goes off)
Also check your TV to make sure it is outputting to the optical jack.
Jan 11, 2008 | Samsung HTP-1200 System
Full Surround Sound
Dear Jennis,
Have you set properly your input source? What about program mode on your playback on your amp was it properly set. You have to let the amp knows that you are using an optical cable for input, this must be done from the controls.
Sidlahora
Dec 06, 2007 | Kenwood VR-7080 Receiver
Dolby Digital Has Stopped Working
i sthe thx dobly digtal button on off or on auto ?
Nov 14, 2007 | Kenwood VR-505 Receiver
Kenwood VR-7080 Receiver Logo
217 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
