Question about Technics SL-1210 Turntable
It's an SL-B202
The belt stretched. We ordered another. Looks right, but it's too large. Is there a trick or was I sent the wrong belt? The guy in my office who knows this stuff best is at Navy Reserve for two weeks.
Ed
  • eshane Aug 11, 2008
    Many thanks!! Ed
  • 515 Answers
The belt wraps around the bottom of the metal turntable platter. Put the platter back on, then rotate the platter so that you can see the motor. Pinch the belt around the motor, and that's it. If it's too big, then the belt you ordered is too big. You have to get the correct size. Not just any size belt will work. If it doesn't fit, you'll have playing issues, and you'll wear out your motor, records, and styli very quickly.
- OPTiC
DJ Pro Audio
www.1200s.com
www.repairnyc.com
Posted on Aug 08, 2008
Is there a trick to getting the belt on the motor pulley and brush on the Hoover Elite Supreme
hi ,try warming the belt up in hot water first it will stretch better
Apr 08, 2013 | Vacuums
Technics SL B202 doesn't maintain consistent speed. I have cleaned the unit's surfaces where belt comes into contact and it improved. i used a little lubricating spray on the speed control pot as...
From your description it sounds like the motor is the issue, it probably needs to be taken apart and cleaned and re-lubricated with phono oil if it still available. It is possible that time will improve the performance, but you probably should replace the turntable belt especially when it has been sitting for a long time without use.
Jun 09, 2011 | Audio Players & Recorders
Turntable turns on, but it when i press play the plate doesnt spin. i noticed it budges like a mm but definetly not working
Turntable Drive Belt
The chances are the rubber drive belt has either broken or stretched so that it has fallen off the drive pulleys.
You will need to gain access to the underside of the turntable to replace it.
With most turntables the process will be to secure the tone arm (a rubber band will do the trick) before turning the whole thing upside down and unscrewing the base.
Replacement drive belts are easily available on the internet. Search by make and model number of your turntable
Feb 09, 2011 | Technics SL-1200 Turntable
Looks like the rubber band came off
if it is black and fairly long it's probably the drive belt and it has likely become stretched (or sticky).The belt fits on the inner circumference of the platter- to re-install - remove the rubber platter cover and platter
-stretch the belt around the inner (botom side inner) lip of the platter
- you should see the motor facing up with a brass capstan or drive bobbin
-from the top side of the platter stretch the belt slightly off the platter through the openings provided and while re-installing the platter loop the belt over the motor bobbin.
If the belt flops off the inner platter it's to stretched and a replacement would have to be ordered
Oct 18, 2009 | Aiwa PX-E860 Turntable
I have a 10' Craftsman table saw model 315-218290. I ordered new belts I removed the motor how do you attach the belts, I tried to stretch it won't work
Jun 20, 2009 | Craftsman 10" Table Saw
Schematic for turntable belt replacement - Technics SL-B202
Here is a link to a great website / form. You have to register but it is free.
http://www.vinylengine.com/library/technics/sl-b202.shtml
Mar 21, 2009 | Technics Audio Players & Recorders
The brush rollers on my hoover mach 5 won't turn. I've cleaned everything and checked the belts and everything checks out fine. I had the vacuum for about a year.
I had the same problem. The problem is the small v-belt for the roller brush (Hoover part# 38528034). Although it looks in good shape, it's been stretched too large for the idler to keep good tension. The tension on that belt varies with the handle geometry so if you slam handle all the way down the belt gets stretched a little bit each time.
Oct 06, 2008 | Hoover Vacuums
Belt type
The belt number is 91001028. The belt will be snug but not real tight, so the belt you got may not be the right one. Most repair shops for vacuums should have this belt in stock.
Jul 12, 2008 | Hoover U8145-900 Savvy Bagless Upright...
Replacement belt for Tascam 122
well, after a quick search on the net, the only place I can find that still carries them is consolidated electronics in the USA. I have ordered from them years ago and they were very good. You will find an online catalog and how to measure your belt to get the right one.
NOW.....when belts go, the rubber deteriorates with age. The belts stretch. Carefully, without stretching the belt further, place it on an inch ruler, belt laying flat. Make tight corners on the belt by pressing one side against the other and measuring the length against the ruler. The belt length is the measured length times 2. Write this number down !. Try stretching the belt A LITTLE....if it snaps back to length, then it isnt in too bad a shape, and you can order a belt 3% smaller and one 6% smaller. If you stretch the belt and is slooooooowly comes back, then the rubber has turned to licorice. If it If your belt has already stretched and it is still in one piece, when you measure it, it will be too big. I would order several belts, one 10% smaller, one 13% smaller and aonther 16% smaller, that way you should get the right one. If the belt has broken, without stretching it, **** the broken ends together and tape them butted together, then measure the belt. Its been a long time since I've done a 122', but if there are other belts in there too, order them as well. When one belt goes, there are more to follow in the very near future. I would first try contacting Teac/ Tascam to see if the correct belt is available from the factory, or possibly an entire belt kit !. If you need more instructions on belt measuring, go to : http://www.ceitron.com/passive/flatLbelt.html and follow instructions at the top of the page.
Good luck.....Rob
May 08, 2008 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
Technics SL-1210 Turntable Logo
182 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
