Question about Maytag MZD2669KE Side by Side Refrigerator
Hose from door dispensor hook to refrigerater
Where do hose from door dispensor hook to refrigerater ? it was loose when went hook up water from faucet to refrig
  • 700 Answers
It should hook up to a water line with a coupling at the bottom of the freezer door. take the kickploate off and then look underneith the refrigeraqtor and there should be a clear plastic tube there3 to hook up to.
Posted on Feb 22, 2009
When the water line is hooked up to the back of fridge and the line is turned on the refrigerator leaks water out the ice dispensor and does not shut off the flow of water to the fridge.Thus causing it to...
the water soliniod maybe clogged with calcium. if you get it loose you can take the plastic hose loos from the icemaker side of the water valve see if it is dripping or running out of there. if alot is coming out maybe getting voltage too long from the icemaker. it will be one or the other.
Aug 04, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
I dont have any water coming from the dispenser i do have water coming out of the hose beneath the door from the solenoid my question is is there another solenoid inside the door of the freezer im thinking...
The water line in the door is frozen . Several ways to thaw . 1 ) turn on the dispensor light for a few daws until thawed , 2 ) raise the freezer temp a few days until thawed , 3 ) use compressed air to the bottom of the door on the line , to blow out the ice , 4 ) order the GE dispensor heater pt. # WR49X10173 , it comes with installation instructions .
May 09, 2010 | Hotpoint HSS25GFP Side by Side...
Water dispensor stoppedworking
If the light and ice dispenser on the front panel works and If your fridge is 4 years old or older, the insulation in the freezer door has most likely deteriorated and the water in the tube feeding the water dispenser has probably frozen. Open the freezer door, put a blanket over the food to keep it from defrosting, and use a blow dryer to defrost the door. Blow the hot air on the flat panel inside the door (the backside of the water dispenser). Close the door about every 5 minutes to check to see if the water works. Once the water begins to flow, you have successfully defrosted the ice in the tube. Defrosting the door works for about 12 hours until it freezes again. To solve this problem, I placed a 10" weedeater line up thorugh the dispenser nozzle leaving about 1/8 of an inch sticking out. When the line freezes again, pull out the weedeater line, dispense water to free the ice, and then reinsert the weadeater line. I keep the line in all the time...it works great! If the light or ice dispenser do not work, the problem may be *********** board.
Mar 17, 2010 | GE GSL25JFPBS Side by Side Refrigerator
No water from door. I've taken the water line loose from the siloniod water will flow when activated. but will not come out at the door.
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then , the water tank inside the refrig section , behind the crispers , is frozen . If the door line is frozen , pt # WR49X10173 , is a dispensor heater kit , with instruction , to keep the door line thawed .
Nov 11, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker works, but I can't get a drop from the water dispensor
If you are making ice then the chances are that the solenoid or the switch mechanism is bad on the water side. The water valve has two solenoids that control water flow. The icemaker side is control by the cam switch that rotates on cycling ice drops and the water side is controlled by the door switch which operates the water valve. If you hear the click when you activate the door switch, listen to see if you hear a clicking near the back of the refrigerater when you hit the switch. There is also a possibility that the water inlet screen is clogged with debris.
May 09, 2009 | GE GSS25SGMBS Side by Side Refrigerator
Broken hose at the bottom of refrigerater door that feeds into
to remove door there are screws at top door hinge, them and door should lift right off. fold back gasket and you will find a lot of screws under gasket remove them and inner door panel should lift off exposing hoses .
Jan 26, 2009 | Refrigerators
Refrigerator wate leak
Usually at the bottom outside of door (near hinge) is where the waterline will become loose or crack. Otherwise, I would have to look at it.
Apr 21, 2008 | GE Profile CustomStyle PSI23NGR Side by...
ICE MAKER
sounds like icemaker not turned on
Jan 03, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
Icemaker and water dispenser
Mine did the same thing.  Other web sites said it was the motherboard.  I replaced it and now it works great.  The part number is: Hotpoint Refrigerator Main Control Board Assembly WR55X10552best deal was at http://midwestapplianceparts.com
Sep 10, 2007 | Hotpoint HSS25GFP Side by Side...
Maytag MZD2669KE Side by Side Refrigerator Logo
123 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
