Question about Vulcan EF3 Deep Fryer
Wont come on
Ok, I lite the pilot, it stays lit. then when I go to turn the knob to set the temp it clicks and shuts off the pilot.
  • 21 Answers
Low gas pressure to unit must check and see if gas valve in back of unit is fully on or same for regulator if there is one if the gas valve is open and the unit has a regulator ajust regulator regulator with center screw clockwise all the way down this will give you more pressure
Posted on Nov 18, 2008
Per landlord, need to light pilot
You would smell the gas, so you're probably ok. Lighting the pilot is not too tough, first you have to get the cover off the furnace. Inside you will see pipes and parts. Hopefully on the cover, inside or out, or somewhere inside the furnace will be instructions.
If not, find a knob that has 'pilot', 'off' and 'run' or something like that. It will probably be in 'run'.
Usually, you have to push the knob down and turn it to get it to the 'pilot' spot. When you do, have something to lite the pilot, which will be inside the furnace more, near the burner. The burner looks like a gas stove or oven burner. The pilot place will be at the end of a small tube.
With the button held down, wave something burning around the burner area. especially at what may be the pilot. The pilot doesn't put out much gas, so don't worry about things blowing up.
Once the pilot has lit, hold the button down for a while, at least a minute. Then you should be able to release the button and the pilot should stay on. If it doesn't, you need a serviceman to come. Let the landlord know the pilot would not stay lit.
If the pilot stays lit, move the knob to 'run' or such, and the furnace should lite, if the thermostat is set higher than room temp. If it has been off, and the room is cool, it should lite.
If the furnace doesn't come on, let the landlord know.
Most landlords have service people for this, it was my job for a long time. Lighting pilots was a common chore for me. If you can, have the landlord send one out to show you how to do it.
As you see, it's not all tough, but it's not all easy, either.
Nov 29, 2013 | Heating & Cooling
Oven wont lite
if its a pilot lightr that stays lit all the time,then its the thermocouple next to the pilot light thats bad and cant keep the pilot on
Nov 24, 2012 | Ovens
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Fryer wont lite when temp knob is turned up to 350 range pilot is lit
Observe the thermostat when set to higher temp, you should hear a clicking sound as the mechanical contacts inside closes, at this point, burners should fire up.
Thermostat can be tested by checking the continuity across its terminals (using an ohm meter) when set to a temperature higher than the oil temperature.
Also, the thermopile must be free of soot or any form of dirt and the pilot must have good flame quality, gas pressure should meet the nameplate's requirement.
Jun 09, 2011 | Imperial IFS40 Deep Fryer
It wont lite, how do you lite the pilot, where is it located, do you have a manual i have a coleman presidental 3 furnace
There is a window directly above the gas control valve. Either a spring held latch or a screw off cover need to be removed to access the pilot. To light the pilot, turn the knob to pilot and hold down while lighting pilot. The pilot in straight back inside the hole about 10 inches. Use a long fireplace match or rig a wire to hold the match. Once the pilot lights, hold the control knob down for about 30 secs., if it stays lit after release, turn to "On" and operate normally.
Dec 13, 2009 | Tools & Hardware - Others
How do i start the pilot light on a JGBP28wek6ww
That model is an electronic ignition, ther isn't a standing pilot on it(no liitle flame that stays lit). Light the burner by pushing in on the knob and turnlig to "LITE" position, you will hear a clicking noise the sound of the electric spark igniting the burner, turn the knob to adjust the flame size. Keep in mind that all igniters spark whenever any of the knobs are turned to the "LITE" position. Good luck !
Nov 30, 2009 | Televison & Video
Pilot wont stay lit on my furnace
Bad thermocouple. you can get these at a hardware store. easy to replace rus
Oct 04, 2009 | Heating & Cooling
My magic chef kitchen range oven won't turn on, no gas
Some of the models require you to push in the oven thermostat knob to set the pilot if it blows out. So try pushing in the knob and hold it while lighting the pilot. When the pilot lights continue to hold the knob in for about a minute. When you let go of the knob the pilot should stay lit. If it does not stay lit then try it one more time. If it continues to go out the thermocouple or aso might be bad and will need service.
Sep 11, 2009 | Magic Chef 31000 Gas Kitchen Range
Pilot lit clicking noise no burner
make sure knob on gas valve(inside heater)is turned to on position.3/4" should be fine as long as heater is not larger than than 175,000 btu
Jul 14, 2009 | Jandy Lite 2 Natural Gas Pilot Light...
Vulcan EF3 Deep Fryer Logo
217 people viewed this question
Top Vulcan Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Vulcan Kitchen Appliances - Other Expert? Answer questions, earn points and help others
