Question about Karcher 2500 PSI Pressure Washer
Craftsman PSI Washer w/4.5 honda eng. Psi coming out of soap pick up tube
Not sure why but my psi washer all of the sudden started to have high psi come out of the syphon tube. When I pull the handle or nozzle back for low psi and pull trigger the tube will then start to **** up. Also seems like I do not have alot of high psi when nozzle switched to high?????
oldnovii
  • 667 Answers
SOURCE: KARCHER 2400 PSI HONDA ENG GC SERIES 160 RESIDENTIAL PREMIUM
Hi - You're not trying to use the gun safety lock to keep the trigger on are you? I know how it sounds but I have to ask. This feature is just meant to act as a safety so that the trigger can not be accidentaly engaged. You are supposed to lose pressure when you let go of the trigger.
Posted on May 09, 2008
  • 14 Answers
SOURCE: craftsman 4 hp 2150 psi pressure washer wont start
Go to www.karcher.com ,click on your region and then click international. Enter the model of the machine or the type number . That is is the first 8 digits of the number under the barcode. This will take you to the parts listing for your machine.
Posted on Mar 11, 2009
  • 83 Answers
SOURCE: honda pressure washer cuts out when lance trigger released.
You most likely need to set your valve clearances. If it is hard to pull over or the recoil snaps back after starting your valves need to be set for sure. This may not be the entire problem but it is a good start. Also change the spark plug, a bad plug will cause odd problems and is too cheap not to eliminate as a source. In addition check your fuel, pour a little out into a white container (I like spray paint can caps for this) and look at the color. If it is yellow to orange it is bad. You can pour it into you car, the car electronic sensors will compinsate for it quality but a small engine can't. Use a NGK BP6ES or BPR6ES plug.
You need:
Feeler gages
10mm open end wrench
14mm open end wrench
1 long shaft screw driver or rod
1 spark plug socket and ratchet
Remove the spark plug and the valve cover. Pull the recoil over slowly until the intake valve opens (intake is closes to the carb and it will go down when it opens). Now put your long screwdrive down the spark plug hole. Slow pull the engine over until the screwdriver handle is at it highest point, this is top dead center. It may take a few attempts. Now check your valve clearance between the rockers and the top of the valve. The intake should be .006 and the exhaust .008, both can be +/- .001. To adjust: hold the large nut with the 14mm then loosen the small one with the 10mm. Lefty loosey. Now turn your large nut until you get the correct setting and then tighten the small one the lock it in. It may take a few attempts and alway reverify your setting after you lock it down. Once done, find top dead center again and reverify. Now your valves are set.
Posted on Mar 31, 2009
  • 2692 Answers
SOURCE: karcher 2600 psi pressure washer wont stay running
Remove and clean the carburator. Sound line a stuck needle on the float.
Posted on Apr 22, 2009
  • 226 Answers
SOURCE: How can I start the
If there is a check valve in the little line that you put into your soap tank, it doesn't need primed. I have very large 5000 psi units and have enough suction without one. If you can't get it going, you can always remove the hose end near the pressure washer end and fill it by immersing the tubing in the soap, but that shouldn't be necessary. Sometimes the little fitting with the check valve in the bottom get plugged up as well, so that might be your problem. Hope this helps you, Rick
Posted on Apr 26, 2009
Why won't the cleaning solution come out of the hose for Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490?
Most people I run into with this problem are trying to get the cleaning solution to work with one of the high pressure tips, usually red, green, white or yellow. The only way to make the machine use the cleaning solution is with the low pressure, soap tip, usually black. With the high pressure tips there is too much back pressure for the solution to be picked up and mixed into the water stream.
Apr 28, 2014 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
Cant get soap to come out of resevior
it only will pull soap with the large hole tip or no tip very low pressure
May 01, 2012 | Honda Pressure Washer PSI 3000
I have a 2750 PSI pressure washer with a 6.5 hp Honda engine. The soap mixer will not work. Any ideas? Please advise Tahnks
Check the draw tube and soap inlet for a clog. The soap mixer works on siphon action so an obstruction is pretty much all that can go wrong with it.
Jun 27, 2011 | Honda Garden
Sears 2600 psi power washer
there should be a low presure tip for dispensing wash cleaner or if you have an adjustable wand turn it to low presure setting also make sure the suction tube is open some have a adjustable filter...good luck
Jul 25, 2010 | Briggs & Stratton 2200 PSI Gas Pressure...
Very little pressure
INFO:
Sound like its drawing air through the soap pick up tube.
RECOMENDATION:
Pench off soap pick up tube.
Hope this tip helps.
r/
David
Mar 10, 2010 | Psi Blue Max 2200 High Pressure Gas Power...
How much oil in pump...Craftsman 2200 PSI pressure washer
Hello:
Best to use NON DETERGENT 10W30. Be sure you fill the reservoir only 1/3 to less than 1/2 full.
Aug 25, 2009 | Briggs & Stratton Garden
Whe using the honda 3000 psi power washer, I've
Are you putting the soap nozzle on the end? Either that or depending on what type of nozzle you have, some times you pull out or push in the nozzle to switch it to soap.
There has to be no pressure to draw the soap, so you either have to put in the soap nozzle in, or if it has an adjustable end, set it to soap by pushing or pulling.
You cannot spray high pressure with soap unless your unit is equipped with another siphon hose for pressure soap.
May 03, 2009 | Garden
Pressure washer - can't figure out soap
Dont use your mouth youll get poisoned, soap will only come out when there is high water flow, ex. with soaper tip (the one with the bigger hole) or no tip. When you have high pressure tip on it will not work.
Apr 09, 2009 | House Brand Garden
How can I start the soap syphon feature on the Karcher Model 210 - 1200 PSI unit ? Does the line need to be primed ?
Apr 03, 2008 | Karcher 2500 PSI Pressure Washer
Karcher 2500 PSI Pressure Washer Logo
474 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
