I have installed Windows XP on my computer where I did have Windows 2000. I want to continue using the XP & uninstall the 2000 - how do I do that?
  • 26 Answers
If you installed XP over 2000, you don't need to uninstall 2000, but If you installed it parallel to 2000, and you have an option to run 2000, and XP when the computer boots, you cannot uninstall 2000 without wiping the Hard Drive and reinstalling from scratch.
If the version of XP that you installed is an upgrade, you will likely have to wipe the hard drive, then install 2000, then run the upgrade install of XP after, but choose to overwrite the 2000 install.
Posted on Aug 04, 2008
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Tip
"access denied" in XP
<p>Introduction:<br /> <p>When installing or uninstalling the printer driver, a message may appear stating that <span>access is denied</span>. This may occur in Windows 2000 or XP. It may be necessary to edit the registry of the computer to resolve this issue. <br /> <p>Editing the registry with the instructions in this document may bypass security profiles. Please consult your system administrator.<br /> <p>According the instructions below, first check the service pack on your computer, and if necessary update it. If the issue is not resolved, proceed and edit the registry.<br /> <p>Instructions:<br /> <p><b>Step 1: Check the service pack</b> <br /> <p>The issue may be resolved by updating the service pack, if the most recent service pack is not already installed. To check which service pack is installed on the computer, complete the following steps: <br /> <ul> <li> <p><b>Windows XP:</b> Click Start, right-click My Computer, and then click Properties. Under System:, the service pack is listed. <br /> <li> <p><b>Windows 2000:</b> Right-click My Computer and then click Properties. Under System:, the service pack is listed. <br /></li></ul> <p>Make a note of the service pack information. <br /> <p>On the Microsoft Web site, find the Windows Update information. Check to verify the latest service pack and whether it is installed on your computer. If necessary, follow the instructions provided by Microsoft, or contact Microsoft for help, to install the service pack.<br /> <p>If the error message returns and you are unable to install or uninstall the printer driver, proceed to Step 2.<br /> <p><b>Step 2: Edit the Registry</b> <br /> <p>Window maintains most of the information about your computer and its programs in a file called the registry. It is important to backup the registry before editing it. If mistakes are made when editing the registry, your computer may not function properly. Having a backup copy of a working registry will allow you to restore your computer to a working state if mistakes are made while editing the registry.<br /> <p><b>Backing up the Registry</b> <br /> <p>Complete the steps in this section to backup the Windows registry. <br /> <ol> <li> <p>Click Start and then click Run. <br /> <li> <p>In the Open box, type regedit. Click OK. <br /> <li> <p>In the Registry Editor, select My Computer. <br /> <li> <p>In Windows 2000, click Registry and then Export Registry. <br /> <p>In Windows XP, with My Computer highlighted, click File and then Export. <br /> <li> <p>Browse to a file location that will be easy to remember. <br /> <li> <p>Under Export Range, select All. <br /> <li> <p>Type in a filename. Suggestion: registry_backup with the current date. <br /> <li> <p>Click Save to save the backup copy of the register. <br /></li></ol> <p><b>Editing the Registry in Windows XP</b> <br /> <p>To make the necessary changes to the registry in Windows XP, follow these instructions: <br /> <ol> <li> <p>Click the ( <b>+</b>) next to HKEY LOCAL MACHINE. <br /> <li> <p>Click the ( +) next to SOFTWARE. <br /> <li> <p>Right-click Hewlett-Packard, then click Permissions. Verify that Full Control is checked in the Permissions for Users box below the Group or user names box. Then, click OK. <br /> <li> <p>Click the ( +) next to Hewlett-Packard. <br /> <li> <p>Right-click HPDJ PRINTING SYSTEM CONFIG and then click Permissions. Verify full control is allowed for each user on the list. Then, click OK. <br /> <li> <p>Right-click HPZ and then click Permissions. Verify full control is allowed for each user on the list, then click OK. <br /> <li> <p>Click the X in the upper-right corner of the Registry Editor to close it. <br /> <p>Now, with the registry edited properly, uninstall and reinstall the printer.<br /></li></ol> <p><b>Editing the Registry in Windows 2000</b> <br /> <p>To make the necessary changes to the registry in Windows 2000, follow these instructions: <br /> <ol> <li> <p>From the desktop (with the registry closed), click Start and Run. <br /> <li> <p>In the Open: box, type <span>Regedt32</span> and then click OK. <br /> <li> <p>In the tiled windows, find the one labeled HKEY_LOCAL_MACHINE on local machine and maximize it. <br /> <li> <p>Double-click HKEY LOCAL MACHINE. <br /> <li> <p>Double-click Software. <br /> <li> <p>Click the Hewlett-Packard entry. <br /> <li> <p>Click Security on the menu bar at the top of the window. <br /> <li> <p>Click Permissions. Verify that Full Control is checked in the Permissions box. <br /> <li> <p>Double-click Hewlett Packard. <br /> <li> <p>Click HP DJ PRINITNG SYSTEM CONFIG. <br /> <li> <p>Click Security and then click Permissions. Verify that Full Control is allowed for every user in the list. Click OK. <br /> <li> <p>Click HPZ. <br /> <li> <p>Click Security and then click Permissions. Verify that Full Control is allowed for every user in the list. Click OK. <br /> <li> <p>Close and exit from the registry.<br /> <p>Now, with the registry edited properly, uninstall and reinstall the printer.<br /></li></ol>
on Mar 10, 2011 | Computers & Internet
Tip
How to format a computer with windows xp.
<span> <ol> <li>The first step in learning how to format a computer with Windows XP or 2000, is to insert Windows CD and restart your computer.<br /><br /></li> <li>Your computer should automatically boot from the CD to the Windows Setup Main Menu.<br /><br /></li> <li>At the Welcome to Setup page, press ENTER.<br /><br /></li> <li>Press F8 to accept the Windows XP Licensing Agreement.<br /><br /></li> <li>If an existing Windows XP installation is detected, you are prompted to repair it. To bypass the repair, press ESC.<br /><br /></li> <li>Use the ARROW keys to select the partition or the unpartitioned space where you want to create a new partition. Press D to delete an existing partition, or press C to create a new partition.<br /><br /></li> <li>Type the size in megabytes (MB) that you want to use for the new partition, and then press ENTER, or just press ENTER to create the partition with the maximum size.<br /><br /></li> <li>Select the format option that you want to use for the partition (Recommended: NTFS), and then press ENTER.<br /><br /></li> <li>After the Windows Setup program formats the partition, follow the instructions that appear on the screen to continue installing Windows.<br /></li></ol></span>
on Nov 23, 2010 | Computers & Internet
How can i install windows xp in windows vista.if click install windows xp. setup cannot continue because the version of windows on your computer is newer than the version on cd
you cannot downgrade operating system. thats the number 1 rule. what you can do there is try to perform a clean install of windows XP if you still want to use windows XP. Boot the computer from CDROM. by pressing F12 key from the time you power on the computer. setback is, everything you installed in vista will be erased.
May 21, 2010 | Computers & Internet
I keep getting an error message when I start up my laptop. the 2 wire gives me a "corruption has been detected in feature manager, backup file has been loaded", and it will not connect. All other programs...
If the machine is a Dell with DellControlPoint, open start, run then type msconfig and hit enter. Choose the Startup tab and find the startup item named "Dell" with the Command from "C:\Program Files\Dell\Dell Control Point\Connection Manager\Dell.UCM.exe" and uncheck the box. Hit Ok, then reboot your computer.
Jan 16, 2009 | Computers & Internet
Tip
How to Format a Computer with Windows XP
Thanks,
Bhautesh.
on Mar 03, 2010 | Computers & Internet
I just installed xp pro and it keeps freezing
I would suggest that you run only one stick of Ram at a time to determine if they are the problem.. Also these CPU's had heat problems that damaged the cpu. This also causes freezing. I would consider resetting the CPU and the heat sink, and case fans are clean and working.
Dec 10, 2008 | Computers & Internet
Lost my right as administrator
You have done big mistake that's why you are getting problem.
1)Regarding installation of win XP over windows vista.
You have to install first lower version and then higher version i.e. you should install first win xp and then windows vista. But vice-versa you can't do it.
So my suggestion is that format your c drive then install win XP
after installation win XP install win vista.
2) which operation system do you want to open .
You can remove it using windows tweak utility software wich is freely available on most of the website. Also you can manually edit it.
For manually do this.( i m not sure about windows vista it is available or not)
right click on my computer->click on Advanced Tab->setup and recovery framework click on settings->click on Edit button
You will see the boot.ini file. You can remove the windows XP line from that file.
Oct 22, 2007 | Acer Aspire T690 (AST690UP820A) PC...
Computers & Internet Logo
129 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
