Question about Frigidaire ATF6000ES Front Load Washer
Clothes washer the washer ack like it is not going through the cycles
  • 30 Answers
If your washer act like it is not going through the cycles, you could be experiencing a faulty timer.
Solution, If you already have a voltmeter, trace and free motor leads from timer--prove them with your meter on ohms 2000. Look for a relatively high reading (usually 1,120 to 2000 ohms) indicating continuity. If reading is infinity, replace the timer mechanism.
Good luck.
Posted on Aug 06, 2008
SOURCE:
Is Whirlpool AWT 5108 only a washing machine or a washing machine with dryer?
Washing machine usually have different wash cycles you can chose from. The washing machine should go into a spin mode to get most of the water out of the cloths at the end of the wash cycle. You might try another wash cycle on the washer and see if the washer goes into spin mode and gets most of the water out. If it goes into spin mode on one cycle and not another my experience has been it is the timer which is part of the switch where you chose which wash cycle you want.. My experience is only working on my washers and driers of the last 40 years. I have washed cloths with what ever cycle worked till I could change timer.
Nov 19, 2017 | Whirlpool Washing Machines
Whirlpool front load washer (W-WFC7500VW1) was ran through the clean cycle. After this was preformed, the washer will not spin the clothes the dry. The washer will spin but never reaches the 'higher' spin...
I suggest going on the Whirlpool manufacturers website and check their forums for a similar problem. It could very well be something very easy to fix.
Jan 08, 2015 | Whirlpool Washing Machines
Why won't my Maytag Washer extract water properly from clothing after going through the complete cycle?
Belt tension spring faulty, belt loose. Pump partly blocked, look for coin caught in hoses. Internal clutch failed in gearbox, replace gearbox. Gearbox pulley wrongly adjusted, remove pulley, re-grease, re-install with correct clearance.
Dec 18, 2013 | Maytag Neptune MAH5500B Front Load Washer
Kenmore washer model 11022722100 wont spin out wet clothes
the PCB has a problem and only a certified tech should try repairs
Sep 13, 2017 | Washing Machines
Washer not draining
Probably the pump filter needs cleaning.
It should be located at the bottom front of washer behind drop down cover, turn anti-clockwise to remove and clean.
May 04, 2010 | Bosch Nexxt 100 Series WFMC1001UC Front...
My washer won't go through it's cycle. The door
If you do not have both hot and cold water lines hooked up, some cycles might not work. Also, if you put too many clothes in.
Jun 09, 2009 | Maytag Neptune MAH5500B Front Load Washer
My washer will not go to spin cycle,.
Hi my name is joyce,
first lets try to get the water out of washer, put on drain cycle, after it drains water out take clothes out of washer, then lets see if it will run on spin cycle, it may have to many clothes, if this does not help then you have a transmission problem, this will defenently need a technichan to look at it. if you need I can look in you area and see if I can find you some assistance.
Joyce
Feb 06, 2009 | Kenmore 98702 Stacked Washer/Dryer
Cloths Soaked after Spin Cycle
If the motor has a transmission, it could be stuck in 1st gear. I think the agitator running is normal.
Jan 17, 2009 | LG WM1814CW Front Load Washer
Soaking wet clothes
Burly Bob,
Is this the same model as listed by the previous poster? If so, does the washer ATTEMPT to go into the spin cycle? That is, does the timer advance to spin cycle properly, and can you hear the transmission or drive motor engage?
May 31, 2008 | Kenmore 22422 Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
