Question about Garmin Forerunner 305 GPS Receiver
NO life in my Forerunner 305
I haven't used my 305 for about 8 months, and now it is completely dead, I have tried re-charging it through both my pc and the mains and also a soft reset but still no life at all.
Any suggestions?
Thank you
my 305 will not turn on or show a battery charge in progress when on craddle. completly dead dead dead. what do i do now contact garmin
    Master:
  • 382 Answers
Hello ,
By soft reset did you try "Press the mode and the lap/reset button simultaneously for a few seconds"??...IF you had not,then go with it..if this did not respond then you had to go to Garmin for a service like our experts told you already,Do claim your warranty if you have one..!!..Thank you...
Kind regards!!...
Posted on Aug 04, 2008
  • Natesan Sabesan
    Natesan Sabesan Aug 04, 2008
    Hey even try the vice versa that is press Lap+MOde for 5 seconds and press the Power button then..Well i thought i following link could help you so added it,do check it out buddy... :)
    http://forums.motionbased.com/smf/index....
    Kind Regards!!..Good Luck!!..
  • june veronica Dixon Jun 09, 2013
    you are fantastic, I was really devasted as my garmin was working perfectly fine then nothing......? I tried all the advice about pressing mode + lap reset and nothing, then doing it by your advice BINGO! Thank you so much
  • 4,472 Answers
Either battery is bad or unit is defective, and is still under warranty under a year. So change the batter then if that doesn't work get it serviced under warranty.
Thanks,
Lee
  • Garmin Master
  • 6,487 Answers
Try first changing the battery if you have but if not better call Garmin and let them repair or replace it if its still under warranty..
Hope that helps..........
I have a Garmin Forerunner 305. When I connected it to my PC It started to charge right away and then made an attempt to upload the data. The upload failed, although indicated it was successful on the...
the Gps should be on when you connect to the computer even if the battery is not good
it could be that it overloaded and the fuse burned
I fix the GPS
i am in New York
ecrdn@yahoo.com
Sep 17, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 won't turn on and won't charge. Is there a fix or is this it for the device?
Look at
"http://www.activesplit.com/my-garmin-forerunner-305-doesnt-power-on-its-just-dead-solutions/"
You can soft reset or hard reset the device. Hard reset deletes all data.
Apr 01, 2010 | Garmin Forerunner 305 GPS Receiver
Garmin watch
If you haven't already done so, try replacing the battery.
You can remove the battery cover with a small coin, check the type (all batteries are marked) and buy a replacement.
Jan 16, 2010 | Watches
Won't turn on or charge
Press Mode (bottom left side button) and Reset (left front button) simultaneously, let go, then press On (top left side button).
Jul 28, 2009 | Garmin Forerunner 305 GPS Receiver
Unit only powers on when attached to base charger
sounds like internal battery is dead, if underwarrenty contact company, if not these batteries are not user changeable u will have to use as is or replace
Jul 07, 2009 | Garmin Forerunner 305 GPS Receiver
My Garmin forerunner 305 recently got immersed in
I have read in some other posts about the unit only working while being plugged into a USB port. My guess is that the battery is in fact shot and the unit will only run off the USB port while plugged in. Submersing in water is not a good idea. On the back of the unit there are some small holes for the speaker. These speakers corrode from sweat and eventually quit.
Jun 05, 2009 | Garmin Forerunner 305 GPS Receiver
My Forerunner 305 was working when I ran today.  I just went to download and the 305 is completely dead.  No display when pressing 'on', and none in charging deck. What do you recommend? Thank you.
Press the reset and mode button simutaneously to reset watch
...then press the mode and start button at the same time for several seconds to start the watch up
Dec 22, 2008 | Garmin Forerunner 305 GPS Receiver
There is a hidden recessed button on the right side of the Garmin. Press this button and it should reset the unit and it should turn on immediately.
Jan 13, 2008 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 usb cable won't be read
The problem is probably not with the USB cable if the GPS wont even turn on. The older firmware of the Forerunner 205 and 305 have a problem with locking up. This causes the Forerunner to look completely dead. There is a reset procedure: push the mode and reset button at the same time and then let go and hit the power on button. If it powers on that is the problem. Go to the Garmin site and load the newest rev. of firmware into the Forerunner. Fixed mine and a few friends with the same problem.
I do however have a cable problem. Sometimes my PC will come up with unrecognized USB device and my 305 wont talk to the PC, it does charge. It is the cable or dock for sure, because I have tried a different cable/dock and the 305 has no problem. This is the reason I ended up here. I hope the lock fix works for those with the above problem.
Dec 16, 2007 | Garmin Forerunner 305 GPS Receiver
Garmin Forerunner 305 GPS Receiver Logo
293 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
