Question about Dryers
MAYTAG DRIER I HAVE ALREADY TRIED THOSE 2 THINGS. I THINK IT MIGHT BE IN THE BUTTON THAT TURNS IT ON. (YOU PULL IT OUT TO START) IS THAT COMMON OR IS THERE A SOLTION TO THAT?
  • Mike Durland
    Mike Durland May 11, 2010
    can you give me the model number?
  • Mike Durland
  • 481 Answers
Let me know if you need help.
Posted on Aug 11, 2008
Front load frigidaire one year old and cycle won't start from one day to the next. The panel lights are indicating things are correct but the door lock light does not go on when I press start and the start...
I have had to change the door switch on every washer and drier I have ever had. Just a thought: If the door switch is bad the drier and washer will not start working. The one I changed on my drier about a month ago, when I opened the door and played with the switch while pushing the start button it finally came on. I changed the switch and no more problems. If the door is open the dryer and washer are not supposed to operate. I have changed some which you could not move around on those I would pull the wires off the door switch. Depending on if the switch is normally open or closed I would connect the two wire and try to start or leave them separate and try to start..
Nov 19, 2017 | Frigidaire GLTR1670A Front Load Washer
Drier turns but no heat (electric drier)
dsd
Sorry to read about your problem. Their is a 80% chance you have a defective heat coil or coils. or the heat selector switch is defective. in addition you may have a clogged dryer vent.
I suggest you place a call to a service company.
I tried to help you. Please help me and vote/rate this response thanks.
If you live in Denver area, I can help you.
Dec 30, 2010 | Maytag Dryers
My 7-year old Maytag MDE6000AYW drier will not start when I push the start button. It has been making a buzzing sound before starting for quite awhile. Today it died with a click followed by an...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Sounds like the motor has gone bad...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2010 | Maytag MDE6000 Dryer
Drier will only run if you hold the button in. maytag model mde508dayw
The infinity start button has a detent that has failed. Replace the button.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 23, 2010 | Maytag Dryers
I have an older Maytag D8512 with an electric igniter. When I push the start button, nothing happens. I checked the pilot light and it is off. I used a long matchstick to see if I could start the pilo
there is no pilot light. electric igniter will glow and pull amps allowing gas valve to open. if you do not see igniter glow it is bad or thermal fuse has blown. look for 120 volts at the igniter when running. if voltage found bad igniter, if no voltage trace back to fuse/stats.this assumes dryer is actually running. if drum not turning could be a number of things. door switch, fuse, etc
May 24, 2009 | Maytag Dryers
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
Bravos Dryer blinking start button
Manual says it could be a number of things, and you should have a copy of the manual since you've only had the dryer 3-4 months. If not, go to the Maytag website and download.
Some things to check -
1) Press Start/Cancel if dryer was stopped in a middle of the operating cycle.
2) Check that one of the two breakers has not tripped or fuses blown (if an electric dryer) in your breaker panel.
Please reply the flashing code number so that I may can help you further.
Jan 19, 2009 | Maytag Bravos 7.0 Cu. Ft. SuperSize...
Maytag Drier, doesn't turn, doesn't heat, but dings.
hi thanks for the question i would check the power coming to the dryer it looks like its only getting 110 check that the appliance doc
Sep 17, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Dryers Logo
32 people viewed this question
Top Dryers Experts
