Question about HP Officejet 5610 All-In-One InkJet Printer
I have problem. Message on the display "cartridge error. Refer to device documentation to troubleshoot" what do i do?
    New Friend:
  • 62 Answers
First take out one and close the door. Take note of the error that comes up. Then put it back and take the other cartridge out. Take note of the error now. One error will be Cartridge Error and the other will be just letting you know that you need to put a cartridge back in. The cartridge that was in while you got the Cartridge Error is the bad cartridge. Replace and go!
Posted on Mar 30, 2011
SOURCE:
My J3680 keeps dis[playing "Cartridge Error:" "
Remove both cartridges, switch off then on, printer detects cartridge missing, install cartridges one by one & observe which one showing faulty, replace faulty cartridge..end..
Oct 07, 2011 | HP J3680 Officejet All In One Printer
Getting "Catridge error: Refer to
if the cartridge is not sensing poperly this error may occur.clean the cartride contact and try it.
the following link may useful to you.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01571812&tmp_task=solveCategory&cc=us&dlc=en&lang=en&lc=en&product=3441011
Aug 08, 2011 | HP J3680 Officejet All In One Printer
I got 3 months ago message on hp officejet j4580 display: Print cartridge problem: [Tri-Colour]. Refer to device documentation to troubleshoot. Today while printing a document, i noticed printing with...
You must be using HP60.
Have you refill your cartridge at all?
If you did, gentely wipe out the cartridge circuit part with Q-tip (with bit of alcohol).
And wipe out the circuit part in the printer where cartridge goes in as well.
And try back.
Sometimes by having some dust or bit of ink make cartridge unreadable.
If you used brand new, do same thing to cartridge circuit part.
Otherwise, there got to be some circuit shot happen in printer.
For your reference, HP4580 is pretty new model and has not cause major problem.
Good practical and durability is good.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
Apr 19, 2011 | Office Equipment & Supplies
Hp officejet 4355 gives this message " cartrige error" refer to device documents for trouble shooting
Mostly, printer cartridge error occurs when the printer head is unable to identify the cartridge properly. And the basic reason behind this is that the cartridge is improperly attached. To reattach the cartridge, turn on the lid of the printer and then remove the cartridge from the printer head. Check the cartridge to make sure that there are no scratches or other damaged parts that can contribute to a printer cartridge error report. Take note that the cartridge should not be left open for more than 30 minutes; otherwise the ink will start to dry up and the cartridge will get clogged.
Mar 21, 2011 | Office Equipment & Supplies
Message in display: Cartridge error refer to
Here are the basic reset instructions. See also here.
Please make sure you followed these instructions to change the cartridge, and the alignment was completed. (see also here)
It may be necessary to clean the cartridge contacts as described here.
If that does not help, you may also access additional online support for your printer here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | HP Officejet 4315v All-In-One InkJet...
Print cartridge problem: tri-color
lestave my j4580 trouble lt says ck blk cartrige
Jun 09, 2009 | HP OfficeJet J4580 All-In-One Laser...
Officejet 5610 fax machine
my printer hp 5610 all in 0ne.
cartridge error reffer to device documentation plz ans.
Sep 10, 2008 | HP Officejet 5610 All-In-One InkJet...
HP Officejet 4355 All in One Cartridge Error
your cartridge may be faulty if you change cartridge and message display same problem so clean catridge block contact with soft cloth clean cartridge back side using student eraser if problem will continue so contact your hardware technician
Mar 27, 2008 | HP Officejet 4355 All-In-One InkJet...
Hp 4355 cartridge error
Mar 10, 2008 | HP Officejet 4355 All-In-One InkJet...
HP Officejet 5610 All-In-One InkJet Printer Logo
947 people viewed this question
Clive
Clive
Thomas F. Schneider
