Question about Fuji FinePix A340 Digital Camera
Initialize disc I am unable to initialize my XD card. I keep getting an error message. I have been to the set up menu and selected format...then pressed menu/ok. I continue to get the same error message.
The solution offers requires you to have a non-M type memory card to install the new firm ware before you can use an M type card.
The whole reason for the problem is not having a non-M type card to begin with!
Posted on Oct 03, 2008
If you have version 1.00, then you will need to upgrade to 1.22 in order for this camera to read an xd type M or H picture card. I believe this is your problem. Go to this link on Fujifilms site for specific info: http://www.fujifilm.com/products/digital/download/a340/fupd.html
Hope this helps!
Card not initialized?
The error can be caused by:
1. The xD-Picture Card or internal memory is not formatted.
2. The xD-Picture Card contact area is soiled.
3. a camera fault
for 1.:
Format the xD-Picture Card or internal memory on the camera (p.130)
To format the internal memory or xD card goto format in the setup menu and chose the correct memory.
for 2.:
Wipe the contact area on the xD-Picture Card with a soft, dry cloth. It may be necessary to format the xD-Picture Card
(p.130).
If the message still appears, replace the xD-Picture Card
for 3.: You won't like this one:
Contact your FUJIFILM dealer.
Oct 30, 2013 | Fuji FinePix S6500 Digital Camera
How to initialize card
Press the MENU/OK button. Use cursor-left/right to select "SET" then use cursor-up/down to select "Set-Up" and press MENU/OK. Use cursor-up/down to select "FORMAT".
Sep 03, 2012 | Fuji FinePix A340 Digital Camera
I received a finePix A330 camera without a memory card. I do not have a manual. I purchased an Olympus xD Type M= 2 GB card from WalMart because it is the only xD card they carried. I keep getting the...
Try googling fo r the info...they have a huge range of details for just this sort of problem. If not, tryto access memory operation thtough your unit's memory - there should be a trigger giving initialization details. Hope this helps!
Jan 12, 2018 | Fuji FinePix A330 Digital Camera
Yesterday I transferred all my pics from the xd picture card to my computer, nad now I keep getting write error message when I take a pic. The manual says that the card is write protected! How did this...
I don't think the XD card has a lock switch (some do) but what I fully expect is that the memory card requires your to format it to the camera you are using it in. You didn't tell me what camera make or model But you did say you have a manual, look for formatting or it may be called initialize. Formatting clean the surface of the memory card and makes it ready to accept new pictures again.
Jan 26, 2011 | Fuji Cameras
I am getting a message that reads "card not initialized". It is a new XD picture card. How do I initialize the card?
To initialize the new XD card, you go into the camera's setup menu and navigate to the format function. Format the card and you might be ready to go. If your new card has an "M" or an "H" preceeding the XD, your camera will need a firmware upgrade before it will recognize the card. Here's a link to the firmware upgrade procedure. http://www.fujifilm.com/products/digital/download/a340/fupd.html
Jun 15, 2009 | Fuji FinePix A340 Digital Camera
My FujiPix S700 is flashing card not initialized
If you have a new xD-Picture card that says "card not initialized" go to set-up and when it says "format OK? Erase All Data" press the triangle on the left of the menu/ok circle so it goes to "OK" then it will change to an hour glass going up and down until it stops and MAGIC! the card is initialized, at least it worked for this time for me.
May 14, 2009 | Fuji FinePix S700 Digital Camera
Fuji A200 xD card uninitialized
OK There are 3 problems that  a company like Fuji should have avoided:
1. Directing one to "re-initialize" the chip and not providing any directions for doing so.
2. Calling it "initializing" in the menu and "formatting" in the camera menu.
3. Building a camera that blitzes the chip when the USB cord is accidentaly disconnected without following the ritual.
The FIX: Turn the camera on. > Switch from the red camera icon to the green arrow icon on the ring around the shutter button. > Press the "menu/OK" button. > Under the "Erase" menu, scroll up to "Format." Press "Menu/OK" button. > Re-format (aka "re-initialize') the chip and lose all images stored on it. Whoppeee!
Nov 25, 2008 | Fuji FinePix A400 Digital Camera
How do I initialize a picture card?
Turn the camera viewer on (on your finepix 3800, it is the middle position where you preview photos). Press the "menu" button and you will be presented with four options, and the top option is FORMAT. Select format and your card will be usable again. Two things to keep in mind. Any pictures on the card will be lost, and when you press the menu button as I described it may take a few seconds before those four options appear. As an FYI, the most common cause of the card needing to be reformatted is when the pictures are loaded to a MAC computer and the USB cable is pulled before you eject the camera.
Nov 02, 2008 | Fuji FinePix 3800 Digital Camera
Initializing xd card
Put the camera into play or review mode then hit the ok/menu button on back and format the card. This will erase all of your photos so make sure you've backed them up or download them.
Jul 11, 2008 | Fuji FinePix 3800 Digital Camera
I had a similar issue with an XD card in my Fuji FinePix S3000.
I had used the several times for a couple of years without problem.
The issue appeared right after dowloading pictures from the card inserted in my notebooks' card reader - an operation I have done several times in the same notebook without any problem.
I have fixed the issue going to Menu, Option, SetUp, Format and choosed OK.
Deleted all the pictures (make a copy before if the card is readable in the pc as it was my case) but made the card readable again.
Nov 25, 2006 | Fuji FinePix S602 Zoom Digital Camera
Fuji FinePix A340 Digital Camera Logo
115 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
