Question about LG Microwave Ovens
I had vinegar and oil explode in my microwave and now the macirwave will not shut off unless the door is open. What do I do?
  • LG Master
  • 9,098 Answers
Sounds like moisture may have gotten into the controls and / or the door switches.
You may have to remove the control panel to help it dry out.
You want to unplug it first.
Posted on Aug 08, 2008
My microwave heats & shuts off with timer But it comes back on when I open the door (not heat) just turntable spins in opposite direction, and fan & light come on.
OOHH this could be dangerous to use, seems your door interlock switch is not operating , Id unplug it right away and refer it to a qualified service center
microwaves on live flesh (such as your hand) could explode !!!!!!!
Feb 20, 2015 | In Microwave Ovens
Microwave won't stop running
my microwave door wont shut
Jun 26, 2013 | Microwave Ovens
My ge microwave just runs. It will not stop unless I unplug it.
First you should determine whether it's cooking when it should not be, in this case anytime it is plugged in and the door is closed or open.
Do that by putting a cup of water in a microwave-safe container into the unplugged microwave, shutting the door, then plugging it for about a minute.
Then unplug the oven and check to see if the water is warmer.
If so, you have a shorted secondary relay on your microwave''s control circuit board, and we regularly repair such control units for customers nationwide by mail for $39.95 with a one-year guarantee.
Do that test again by putting the water in, leaving the door open, and plugging the oven in for about 30 seconds or so. If you get any arcing or buzzing or flashing, unplug it.
If it is not cooking, then you need to test further.
If it just seems to be "running" with the door shut, but it is not cooking (as shown in the above tests) then note whether the oven lamp, internal cooling fan and turntable are running when the door is shut, but when you open the door, the turntable and colling fan go off.
This should mean you have a shorted main relay on the board. We can fix that, too.
Differing symptoms would indicate a bad door switch or door switch mount.
Our info file on door switches is here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
Also at our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Sep 30, 2010 | GE HVM1750SMSS Microwave Oven
GE Microwave Oven would not shut off even when the door was opened. We unplugged it and plugged it in later and now it seems to be OK. What happened?
Hi, the contacts in the micro switch or relay proberbly fused together. Do not open door if is still on unless you want to cook yourself
Aug 04, 2009 | Microwave Ovens
Sharp Microwave R-1480 Door Release Button want open the door.
What usually breaks is the door open lever. Please unplug the oven first.
At our site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
You can usually find exploded views and order parts by entering your model number at the Sears parts site, but the best place to order Sharp parts is Tritronics. You can also call them at 866-779-5835.
Nov 19, 2008 | Sharp R-1480 Microwave Oven
GE XL1800 Micro fan won't shut off after light burned out
The problem appears, at least in part, to the door latch circuitry which cannot be serviced by the owner. If the unit is still in warranty, call GE customer care. If not, replacing the unit is your best bet. I just bought a new GE 1100 watt oven with great features for less than $100 If the door dosen't latch correctly, you could be exposed to dangerous microwave energy.
Nov 15, 2008 | GE XL1800 1100 Watts Microwave Oven
GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya:
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here:
Dec 02, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Spacemaker II Microwave problem
Quite often this is due to a bad door switch. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: You can find helpful exploded view diagrams and order parts by entering your model number here:
Sep 27, 2007 | GE JEM31 Microwave Oven
Microwave builtin
This is almost certainly a bad upper door switch or a broken switch mount. You can find exploded views for this model at The involved parts are on exploded view 5 with reference numbers 10, 11, 12 & 13. We have important safety info, disassembly info, and door switch diagnosis and replacement info at our site which is available via our FixYa listing:
Jan 30, 2007 | Whirlpool GH7145XF Microwave Oven
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
