Question about Uniden 5.8GHz Dual Cordless Phone
Uniden Power Max 5.8 - (TRU8880-2)
I have a Power Max 5.8 handset with 4 other satellites. Within the last 2 months, people i talk to on any of the handsets have been complaining that not everything being said is coming through. I tested by calling home and talking, and it appears to start out okay, but with in 10-15 seconds into the phone call, pieces of the conversation start dropping out. To the person on the handset, everything sounds normal. Also, if I call my home number via a cellphone from within the house, everything sounds pretty normal.
  • dbcooper Feb 07, 2009
    Ditto. The problem came on about a year after purchasing the Uniden PowerMax 5.8. First one, then the other handset began to cut out while talking. I could hear the other party, but they couldn't hear me even though I was standing right next to the base station. No indication that the battery was low.
  • 1,800 Answers
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Posted on Aug 25, 2008
SOURCE:
I would like to know how to transfer a call from one phone to the other on a cordless versatis p100
During an external call:
1. Press <MENU> and <UP/DOWN> to select INTERCOM.
2. Press <OK> to select the desired handset to intercom with.
3. The external call is put on hold automatically and the called handset
rings.
4. Press <TALK ON> on the called handset to establish an internal call.
5. Press <TALK OFF> on the calling handset or put the calling handset on the charging cradle to end the current call with the external party.
6. The external call is transferred to the called handset.
Jul 14, 2014 | Uniden Cordless Phone
Uniden base flashing 88 8
I just got off of the phone with Uniden for the same issue with my D1680-4. The alternating "8" - "88" code is an indication that the base is dead. They will be sending me a new base (and 2 handsets). During the call I learned that if you do not have a receipt, Uniden warrants their phones for up to 15 months. The advertised 12 months, plus 3 months for the product to get from manufacturing, through distribution channel and finally sale to the consumer.
Feb 17, 2012 | Uniden D1680 Cordless Phone
Good morning! I just a bout 5 month ago this phone with its 5 handsets. In the last month 2 of the handsets dead, they are not operating ant are not charging. What I have to do. Thank
If they are not charging the batteries they will need to be replaced, but just to be sure! take a good working battery and switch out for the bad one and if the phone charges, the batteries are no good and proves the phone is good. Now! since your phones are a few months old you may still have warranty, I would encourage you to go back where they were bought to remedy the problem.
Jan 09, 2011 | Uniden DECT 6.0 Cordless Phone
My uniden DSS7855 with 1 base station and 3 handsets wont connect when i dial a number and hit the talk button it tries to connect and then comes up "'out of range" much appreciated for any help...
Clear the Handset's Base Data
  1. To remove the base data from a handset when out of range of the base, press and hold the 'end' button and the '#' button simultaneously until the phone beeps.
  2. It will now be de-registered from the base.
Note: This requires that the base and handset can communicate with each other.
Clear the Base Handset Data
  1. To de-register all handsets from the base, remove power to the base, and remove the handset from the base.
  2. Press and hold the 'flash/find hs' button while applying power.
  3. Wait for the beep and release the button.
  4. The charge light will now flash.
  5. Sit any handset in the cradle.
  6. When the flashing stops, re-register the handsets to the base.
Re-Register a Handset to the Base
1. Remove Handset Battery.
2. Reconnect battery while holding down "*" and "#" key.
3. Then press the right upper key under the LCD.
4. Press the "End" key.
5. Wait a few seconds and then the phone will be ready to register to the base.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Nov 12, 2010 | Uniden Lands Phones
Uniden XS 1210 cordless phone won't connect to base unit
try connecting both phones via the base that is working and see if they recognize each other. Let me know if that works.
Jul 21, 2009 | Uniden Cordless Phone
After talking for about 5 minutes, the voice fades away on the
If you have a speakerphone on the base, try using that to make a call. If you have the same problem there is something fundamentally wrong with the phone. If not, try a new set of batteries in the handset. MAKE SURE you are using the same type of batteries that came with the phone in the first place. Don't let anyone in a tech store tell you 'that should be fine', check on the uniden website if you don't still have the box/manual/original batteries and make sure you get the right ones.
If that still doesn't work, Uniden will repair phones within warranty, send it off to them.
Apr 08, 2009 | Uniden Cordless Phone
Base Unit of DECT2000 Uniden Phone system (5 Handsets) went dead
You may have a defective battery, 90 day warranty.
Mar 18, 2009 | Lands Phones
Uniden cordless model DC7758-4
Does the Uniden cordless phone model DC7758 have an answering machine?
Sep 30, 2008 | Uniden Cordless Phone
Uniden power max 5.8 speed dial
Press and hold a number key (0-9) associated with the speed dial until the phone number appears, and then press talk/flash or speaker on the handset or speaker on the base. The number stored in the speed dial is dialed.
Sep 22, 2008 | Uniden 5.8GHz Dual Cordless Phone
Uniden 2645 out of range
The problem of phone not registering is sorted, I simply put that hand piece(2) into base station and it registered straight away, as for the "out of range" problem, we have not had a long enough call today to know yet , hopefully resetting to factory settings helped.
Jul 16, 2008 | Uniden Cordless Phone
Uniden 5.8GHz Dual Cordless Phone Logo
988 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
