Question about Samsung RS2534 Side by Side Refrigerator
No ice at dispensor
I have in the bin, but the door dispensor does not work.
  • 958 Answers
Can you hear a motor running or making some noise inside the ice bin compartment as you press the dispenser switch?
if no noise, then there could be a peoblem in your micro switch at the dispenser or the motor that would bring the ice to the front.
if there is noise then look at the ice inside the bin, it could be all attached as a one big chunk that is why the sweeper is just sliding on the ice. it should be loose so the the sweeper could bring then to the front to come out of the chute.
i hope i was able to fix...
Posted on Aug 06, 2008
  • 10 Answers
SOURCE: Water dispensor not working
Since you have water getting to the icemaker/dispenser, the most common problem I've seen is the solenoid valve is history and needs replacing. It could also be the switch that is normally activated by the dispenser itself and in turn activates the solenoid valve or the wiring in-between the switch and valve, but I have personally not seen either one of those go bad.
Posted on Jan 02, 2008
  • 3 Answers
SOURCE: ice dispensor only dispensing crushed ice - not cubed
The spring coming off the rod will also cause this problem, also the bypass flap may be stuck open, always check the simple things first, hope this helps.
Posted on Apr 16, 2009
  • 36 Answers
SOURCE: The ice dispensor in my Kenmore side by side
possible bad dispensor control board mounted in dispensor console
Posted on Mar 02, 2010
  • 44 Answers
SOURCE: Ice maker is not working
The water tube to the icemaker inside the refrig maybe frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Posted on Jun 06, 2010
  • 3740 Answers
SOURCE: kenmore elite in door ice maker is not working...
Hi and welcome to FixYa, I am Kelly.
Often the reason ice makers slow or stop ice production is because the freezer compartment has gradually warmed up above 17 Deg F and the ice maker thermostat will not start an ice harvest cycle. What causes this gradual warming is usually the result of either an evaporator fan running slow or an automatic defrost circuit problem caused by a fault defrost timer/control defrost heating element or defrost thermostat / thermistor.
You can use this manual to troubleshoot the ice maker:
Note that jumpering T to H requires the ice maker thermostat to sense a termp of 14 - 16 Deg F for the ice harvest cycle to start. If by jumpering T - H under the ice maker front cover the ice maker does not cycle then either the freezer compartment is too warm or the ice maker thermostat is bad.
If it cycles and does not add water... then the inlet water valve solenoid has failed or the ice maker module is not supplying power to the inlet water valve.
Thanks for choosing FixYa,
Posted on Apr 16, 2011
LG Freezer ice maker makes ice but wont dispense
There is a mechanical flap (trap door) that should open to allow ice that is being pushed by the auger in the bottom of the bin to fall out. Possibly the solenoid that opens the door does not work, or you just have an obstruction (piece of ice) preventing the door from opening far enough to allow the ice to pass through. Here is some helpful information and instructions.
Mar 19, 2014 | LG LSC23924ST Refrigeration : Refrigerator...
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Ice and Water Dispenser on door stopped working
Sounds like the dispensor board has lost communication with the main control board . The part number for the main board is WR55X10942 . This is the board behind the refrig , behind the small 8 X 10 panel . It runs about $ 150.00 . I have never found a bad dispensor board . The main board is easily replaceable .
May 26, 2010 | GE GSS25LGM Side by Side Refrigerator
Ice dispenser delivers only crushed ice.
Make sure the dispensor door flap is closing completely .
Remove the ice bin , close the door , set the display for cubed and press the dispensor pad . Do you hear a " clunk " sound ? If not , open the door and press on the light switch , and activate the pad again . On the back wall , next to the " forks " , is a square hole with a white plastic square . Does this plastic square raise up ? If not , remove the top freezer door hinge cover and disconnect the plug there ( this removes power to the dispensor ) , you will have to remove the 4 screws holding this panel , and determine if the solenoid is bad , wire came off , or plastic piece is broken . If the plastic piece does lift , then the problem is in the ice bin . Lift the long rod , and see if the flap moves , where the ice comes out . If not , you will have to determine why .
Nov 03, 2009 | GE GSH22JFT Side by Side Refrigerator
Frost inside the ice dispenser chute and the ice cube dispenser seems "stuck" on crush mode instead of dispensing full cubes.
The stuck on crush mode , is caused by ice frosted in front of the ice bin , blocking the ice bin flap from opening , when calling for cube ice . Removing the ice bin and cleaning or defrosting completely , will solve this problem , AFTER , resolving the frost in shoot problem .
Remove the top freezer door hinge cover , and disconnect the plug there . This removes any power , going to the door . If no plug there , remove the bottom kick plate , by removing the screw on each side in the front , and disconnect the receptical from the wires comming from the bottom of the freezer door .
Remove the dispensor control board , by prying , or pulling , from the bottom of the board . Disconnect the 3 plugs to the board . You should now see the white dispensor cover , being held on by 4 screws . Remove these screws , and slide the cover out .
In the top right , inside the dispensor area , you will see a solenoid with a plunger , with the door flap arc , inserted into the plunger . Usually rust inhibits the movement of the plunger , keeping the door flap from closing completely .
Remove the 3 screws holding the plunger and solenoid ( part number WR62X10055 ) and replace . Cleaning will not help , due to rust will return .
Oct 10, 2009 | GE Refrigerators
Frost building up in ice maker exit shoot and
Look into the dispensor , and see if the door flap is closing , or letting warm air in which will cause the frost buildup . If not closing completely , remove the top cover on the freezer door hinge , and unplug the plug . This will remove power to the door . Use a small screwdriver , and insert under the freezer door dispensor control board , and pry outward . Remove the 3 plugs on the board . Next , remove the 4 screws holding the white dispensor cover , and slide outward . At the top right , you will see a solenoid and plunger , which control the door flap . Usually , this plunger rusts on the solenoid . Replace both , the solenoid and plunger ( come together in kit ) Pt # WR62X10055 . Re-assemble in reverse .
Oct 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE GSH25KGMD Crushed Ice Only
Remove the ice bin . Set the dispensor for cube and push in the door switch . Press the dispensor pad and you should hear a loud bang . If your looking inside at the same time , you should see a square white "gate" lift . This gate lifts to lift the rod on the ice bucket to give cubed ice . If this gate does not lift , then the auger solenoid is probably bad . Part # WR62X58
Aug 14, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Admiral side by side, the ice maker does not seem to making ice
Pull down slightly on the bottom bin lip , and pull the bin foreward . The bin has to lock in place , or it would slide foreward , each time the ice dispensor is used , causing the freezer door to be pushed open from the force .
Jul 11, 2009 | Maytag Admiral Top-Freezer Refrigerator
Ice Bin Dispensor freezes
you might try asking the mfg. site about this problem
did a search and nothing else come up. give them a try.
Dec 02, 2017 | Jenn-Air JSD2690HES Stainless Steel Side...
Ice maker works on Kenmore side-by-side but will not dispense
If there is ice in the bin and you hear the auger motor running when depressing switch then the auger is broke or the ice bin is busted , pull the bin out and empty it and de ice it to inspect for cracks. you can also turn the auger/fork in the freezer and it should turn the motor and have some resistance when turning. let me know if you have any other questions.
Apr 11, 2009 | Refrigerators
Samsung RS2534 Side by Side Refrigerator Logo
71 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
