Question about EliteGroup ECS 661FX-M Main Board Socket 478 for Intel Pentium 4 processor (MBEC661FXM) Motherboard
Hello,i have a problem regarding to my pc because there was no sound eventhough i downloaded the sound driver,it is not working. I've just reformat my pc. i really don't know why the sounds not working. This is the description of my PC model Machine manufacturer : ECS Machine Model: P4VMM2 Motherboard Manufacturer : ECS Motherboard Series : Socket 478 mPGA I would like to know if what sound driver is compatible to this PC. Thank you very much. I hope to heard from you,thanks in advance for helping me :)
  • EliteGroup Master
  • 27,725 Answers
If you are having problems with your sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 30, 2011
SOURCE:
After installing Win 7 Ultimte(32Bit) my webcam does not work. Where do i find the drivers
you can download your drivers here - http://esupport.sony.com/perl/swu-list.pl?mdl=VGNCR240EB
Jul 28, 2011 | Sony VAIO VGN-CR240E/B Notebook
Hello i've got an audio problem for my HP Compaq Presario V2000 Notebook, I want to download an audio driver after reformatting it but it seems that the drivers i've found on the internet...
Hi joriem739.
The link you provided is from the official site, so it means you can't find anywhere else on the internet a much better site to download the drivers you needed. Just make sure you choose the right driver. Are you using xp or windows 2000? There are 2 options there to download for windows xp, have you tried them both?
May 24, 2011 | HP Compaq Presario V2000 Notebook
No audio driver installed after reformatting my PC
Direct sound is actually referring to Direct X drivers. Do a search for Direct X drivers and download and install the correct ones for your sound card and operating system. Also, if you think your sound card drivers maybe part of the problem go to the Sound Card manufacturer website and download the drivers for your sound card and operating system.
Jul 07, 2010 | Audio Players & Recorders
CANNOT PLAY SOUND AFTER REFORMAT
Hi.
You have to reinstall drivers after reformat. Select operative system using the link below, then download audio drivers following the HP on-site instructions:
Select your operating system HP Pavilion zv5000 Notebook PC
Regards.
Apr 11, 2010 | HP Pavilion zv5000 Notebook
Why I am unable to upgrade to IE8 eventhough I ve
I would uninstall IE7 in control panel first, then delete the ie7 folder. After done, IE8 should install just fine.
Apr 07, 2010 | Lenovo IdeaPad Y510 Notebook
After i have reformatted my pc, i cannot play any sound although my speaker is in working condition. do i have to reformat my pc again? ASUS motherboard P5GV-MX do help me out. thanks!
Did you install proper driver for audio hardware? Download compatible driver from;
http://www.asus.com/Search.aspx?SearchKey=p5gv-mx
Regards;
Hasan
Nov 08, 2009 | Intel Asus P5GV-MX 915GV Chipset 800/533...
I just reformatted my PC, then there's no sound!
Hello and thank you for using Fixya's services.
You can go the manufacturers website (dell.com, Hp.com) and download driver free of charge.
Click on support, enter model number and operating system. Click on audio driver download and install. Reboot and your good to go.
Hope this helps!
Nov 06, 2009 | Creative Labs Sound Blaster Live! 5.1...
I just picked up a IBM T30 laptop. I reformatted the hard drive and installed XPPRO. Everything works fine except the sound. I cannot get the sound to work. I have tried everything I could find. Any ideas?
Hello there:
when you reformatted your laptop any of the drivers that originally came with the computer were removed. if you have internet connection i would go to the website of the manufacture of the computer and download the drivers for the soundcard and also the (vinal ac 97 combo pac) works good for most of the computers.
Also if you have your upddates turned on the updates can also help recover the lost drivers. ok these are just a few ideas that may help get you going if you need more please let me know cause there is still more i can show you ok?
best regards michael
Sep 30, 2009 | IBM ThinkPad T30 2366 Notebook
No sound at all
you may have a broken speakers, replace it. might as well check the sound card if its tripping replace it.
Jul 15, 2009 | Computers & Internet
Download vga driver for k8mm-v mother board
Try downloading and installing the drivers listed here:
http://www.nodevice.com/driver/K8MM-V/get38412.html
If you need us, just hollar.
Best regards,
PC REPAIR
Oct 12, 2008 | MSI K8MM-V Motherboard
Open Questions:
See all EliteGroup ECS 661FX-M Main Board Socket 478 for Questions
EliteGroup ECS 661FX-M Main Board Socket 478 for Intel Pentium 4 processor (MBEC661FXM) Motherboard Logo
106 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Thomas F. Schneider
Matson Kurian
Matson Kurian
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
