Question about Sega Genesis 2 Console
Controller port 1
When I plug a Sega Genesis controller into Port 1 on the console, the buttons work, but on the d-pad, the only direction I can control is left. When I try to go down, up, or right, nothing happens. I need to know how I can get controller 1 to go in all directions like controller 2.
I had the same prob a few years ago when i had my frist one probly dry jonits
Posted on Oct 01, 2008
Sega genesis no down button
Well try and resolder the controller one port I have had a problem with my and controller port for my sega and i resoldered the controller port and it worked again it could just be that then.
Dec 17, 2011 | Sega Genesis Console
Control pad
Control pad's are generally all or nothing devices, they either work or they're dead. However with a console of this vintage there are a few things that can cause this kind of issue and therefor a couple things you can do to try and resolve it. 1: Clean the serial ports and plugs (the ports and plugs that connect the pads to the console) with an air duster. Air dusters are cans of compressed air with a long nozzle and are available from most computer, electronics and hardware stores. Clean both serial ports even if you're only using one. 2: if cleaning doesn't work try unplugging the power cable, removing the console's casing and touching a hot soldering iron to the base of each of the pins that connect the serial ports to the PCB (Printed Circuit Board) in tern to re-solder them without using any extra solder, if you find that you do need more solder be sparing. You can see a pictorial guide to disassembling a Sega Genesis here www.takeitapart.net/archives/sega-genesis/ click the pictures to see a larger image. Lastly if you know anyone else who's in to retro-gaming swap a control pad with them to see if your pad works on there Sega Genesis and there pad works on yours. If you find the pad actually is dead it's not the end of the world, there are a few around on popular auction sites, retro gaming sites and specialist game stores pretty cheaply.
Aug 23, 2007 | Sega Genesis Console
Bought a Sega Genesis on ebay. It displays the games correctly but will not respond to the controller. The controller has been tested to work with another system. What could be causing this?
Its the controller ports inside of the system that controlls the controllers to function is broken or loose then and needs to be resoldered. I had a problem with my sega after i resoldered the 2nd controller port it worked again then.
Sep 09, 2011 | Sega Genesis Console
The sega genesis controller won't work completely in the first player port, but works fine in the second player port. It will only let me use the start button, the C button, and arrow buttons, but A, B, X,...
The port might need to be cleaned out, thats a seriously old school console so if it hasnt been cleaned in a while thats probably your issue, especially if the controller works in the other ports. If you have any experience with cleaning out consoles, you could do it yourself, if not i wouldent recomend it, id say to take it to an expert for cleaning.
Dec 16, 2010 | Sega Genesis Console
I have an old Sega Genesis. went to play tonight and now A,B buttons won't work on either controller even when I switch them. Unplugged the game and reset it...played for a few seconds on a different...
Well it might just be that its old then so the controller ports do that i had a problem with one of
the controller ports on mine and i resoldered it and it worked again after that.
Dec 06, 2010 | Sega Genesis Console
I have a sega genesis model two. My controller 2 port works completely fine, but my controller 1 port does not work. How do i fix this?
Unfortunately you would have to take apart the system are-solder in a new controller port. This is definitely not easy to do. Noone really does repairs on these units anymore, so it may be cheapest just to replace it with one from ebay.
Hope this helps!
Tim
Sep 20, 2009 | Sega Genesis Console
Controller Ports Not working
try blowing real hard into the controller port, sometimes dust gets inside there
May 24, 2009 | Sega Genesis Console
Game console having wire trouble connecting to controller?
Most likely the controller port is bad on your system and you need it repair or a replaced system. There are also 3 different licensed versions of sega genesis so each one is different to repair.
Check out ccgamingonline.com
They give you free estimates for your broken system.
May 02, 2009 | Sega Genesis Console
Directional Pad
honestly sounds like its the controller port either have to open it up and make sure everything is connect correctly around it or even blow some air into the ports to blow anything that might be blocking they come loose now and again over the years of use.
have you tryed it on the controller port 2 yet? if not try that and see if it works on that one.
Aug 20, 2008 | Sega Master System Console
Sega Genesis 2 Console Logo
144 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
