Question about Apple iPod MP3 Player
Ipod Video 30GB and matching Logitech speaker/charger
Hi - just got my first Ipod Video 30GB and matching Logitech speaker/charger and I need to know how to charge it for the first time!
I can plug both of them in, and if I put the ipod in the Logitech, do I turn it on in order for it to charge up, or does it charge up even if it's switched off - the ipod, that is, not the Logitech unit.
Help!
  • tessa888 Aug 05, 2008
    I couldn't wait for the answer so plugged them in without switching on the Ipod and it's charged up beautifully so thank you for bothering to reply!
My ipod 30gb needs to connect to its charger before it power on, and sometimes when i disconnect it from its charger sometimes my ipod will also shutdown, My next problem is that, when my ipod 30gb...
The Batteries in these units like all rechargeable batteries only have a certain number of times they can be charged and discharged before begining to fail. Your only option is to replace the battery with a new one. They are cheap to purchase off eBay and YouTube has Videos detailing how to change them.
May 06, 2011 | Apple iPod MA446LL/A MP3 Player
My speakers stopped charging. Now the battery is dead and the speakers are completely useless. Is there anything I can do?
The first thing you could do is trying another charger of the same type, if the battery starts charging you'll only have to get a good charger, if it doesn't, you have a failing charging jack, circuit or battery at portable speakers.
Feb 16, 2011 | Apple Logitech Inc MM50 Portable Speakers...
I had my iPod (5th Generation Late 2006, 30gb) plugged into my computer yesterday and my computer went to sleep (with my iPod still plugged in). I woke my computer up and then all my iPod would say was: ...
Try a manual reset by holding the center button and the play button together for at least 10-15 seconds, this should reset your iPod and should refresh the battery,
In future do not let your battery run flat completely always keep a charge, and lastly charge through a wall charger and not from the usb port,
good luck
Aug 12, 2010 | Apple iPod MA446LL/A MP3 Player
Ipod 30gb does not go "Do not disconnect"!
put it on a charger overnite, or for at least 4 hours. if u can help it, DO NOT use ur cp as a charger. After u do this it should go to "do not disconnect" the next time you plug it in to your computer.
:) hope this helps, tell me if you have any more problems, or if this doesnt help. Thanks :)
Sep 30, 2009 | Apple iPod MA446LL/A MP3 Player
IPOD 30GB
USB is the same thing as a charger.
Thank You for using Fixya!
Oct 25, 2008 | Apple iPod MA446LL/A MP3 Player
IPOD30GB
you obviously need the charger, is your ipod the ipod video black? I need to know so I can point you at the correct charger.
Will not charge
If this Problem has come because you not use a speaker for a long time.I Know How to Repair. In This Morning. I had a Problem Like you but I Can Repair it. Try it you Self.I use a Plug and Play a lot of time. lot of charged. and a lot of on-off switch mm50. I do this for a 12 hour. in my school holiday. Battery is become life! . I Can Portable with It Again. but now is mid night
PS.This is true , I test with myself to Resurrection that Death Battery
Oct 03, 2008 | Logitech Inc MM50 Portable Speakers iPod...
30gb ipod video is "mostly dead"
This sounds like your battery may be going out. Try plugging it into a wall charger to see if it comes on and stays on.
Your circuit board may have a problem. Try doing the reset by holding the menu and action keys until the screen goes dark. Then quickly hold the action and play keys until you see a check mark and disk mode. If you can get the iPod to go into disk mode, the circuit board is probably OK and it is just the battery dying.
When it is disk mode, connect it to a wall charger to get to charge up or connect it to your 'puter to restore it. Hope that helps.
Sep 08, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod 30Gb
Start with these five simple solutions: Reset, retry, restart, reinstall, or restore
http://www.apple.com/support/ipod/five_rs/
If you need more assistance let me know. I'm here to help.
Battery might be bad. well try another charger first.
Apr 17, 2008 | Apple iPod MA446LL/A MP3 Player
Apple iPod MP3 Player Logo
27 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
