Question about Lexmark X6170 All-In-One InkJet Printer
Faxing set up
There are two pugs in the rear. which one does the telephone line go into. I have tried both but can not get fax to send
    Sergeant:
  • 390 Answers
If you have tried both then the problem may not be the line at all. As your post is under all in one, i am assuming you put the phone line in line in, and then the other and got no success. This may mean an incorrect installation or your printer may not be selected as the default fax. Check it is by going to my control panel, choose printers and faxes, and faxes, then see if your fax is ticked as default. if it is the default i would check to see if allis installed correctly and try a reinstall if not.
Posted on Nov 01, 2008
No dial tone on handset. can't send or recieve fax.
? Other equipment, which uses the same phone line as the HP All-in-One,
might be causing the test to fail. To find out if other equipment is causing a
problem, disconnect everything from the phone line, and then run the test
again. If the Dial Tone Detection Test passes without the other equipment,
then one or more pieces of the equipment is causing problems; try adding
them back one at a time and rerunning the test each time, until you identify
which piece of equipment is causing the problem.
? Try connecting a working phone and phone cord to the telephone wall jack
that you are using for the HP All-in-One and check for a dial tone. If you do
not hear a dial tone, contact your telephone company and have them check
the line.
? Make sure you have correctly connected the HP All-in-One to the telephone
wall jack. Using the phone cord supplied in the box with the HP All-in-One,
connect one end to your telephone wall jack, then connect the other end to
the port labeled 1-LINE on the back of the HP All-in-One.
If the supplied phone cord is not long enough, you can extend it. For
information, see The phone cord that came with my HP All-in-One is not long
enough.
Check the connection between the telephone wall jack and the HP All-in-One
to make sure the phone cord is secure.
Make sure you use the phone cord that came with the HP All-in-One. If you
do not use the supplied phone cord to connect from the telephone wall jack
to the HP All-in-One, you might not be able to send or receive faxes. After
you plug in the phone cord that came with the HP All-in-One, run the fax test
again.
If you are using a phone splitter, this can cause faxing problems. (A splitter is
a two-cord connector that plugs into a telephone wall jack.) Try removing the
splitter and connecting the HP All-in-One directly to the telephone wall jack.
If your telephone system is not using a standard dial tone, such as some
PBX systems, this might cause the test to fail. This will not cause a problem
sending or receiving faxes. Try sending or receiving a test fax.
Check to make sure the country/region setting is set appropriately for your
country/region. If the country/region setting is not set or is set incorrectly, the
test might fail and you might have problems sending and receiving faxes.
Make sure you connect the HP All-in-One to an analog phone line or you will
not be able to send or receive faxes. To check if your phone line is digital,
connect a regular analog phone to the line and listen for a dial tone. If you do
not hear a normal sounding dial tone, it might be a phone line set up for
digital phones. Connect the HP All-in-One to an analog phone line and try
sending or receiving a fax.
again.
After you resolve any problems found, run the fax test again to make sure it
passes and the HP All-in-One is ready for faxing. If the Dial Tone Detection test
continues to fail, contact your telephone company and have them check the
phone line.
Dec 03, 2010 | HP Laserjet M1319F Laser Multifunction...
Can't send or receive faxes ADSL
If you want to use the FAX - use the dedicated line to the FAX Machine..
Hi check the following steps
Problems with sending and receiving FAX
Check the TELEPHONE LINE
Make sure that you have plugged the phone cord directly and securely into the wall jack and into the back port of the fax product. The fax port on your product is marked "Line," "To Wall Jack," or with a wall jack symbol.
Check LIU
Make sure the Line Interface Unit (box that the phone cord plugs into) is fully seated into the back of the fax product.
Remove the SPLITTER
Remove any other devices from the line such as splitters, credit card machines, or telephone answering machines.
Can try sending the Fax on Another Line
CHECK WITH DIFFERENT CABLE
Try using a different telephone cord.
Jan 22, 2010 | Samsung CLX-3175FN Color Laser All-in-One...
I have two problems with my OfficeJet 6310: 1. The fax screens appear Hebrew. Similary, If I try to use the copier from the printer. This is continuously caused by HP Update 2. I can not send out a...
Use the HP Fax Test
The telephone number for this service is 1-888-HPFaxme (1-888-473-2963). The fax service receives faxes and returns faxes within 5 to 7 minutes to the number contained in the fax header. Solution two: Run a fax diagnostic test
  1. Load plain white paper into the input tray.
  2. Press the Setup button (c01669474.gif ) on the product control panel.
  3. Press the right arrow (c01669475.gif ) to select Tools , and then press OK .
  4. On the Tools menu, press the right arrow (c01669475.gif ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
Solution three: Check the telephone line and change the HP fax settings Step one: Test the telephone line
  1. Disconnect the telephone cord from the back of the HP fax product.
  2. Figure 1: Two-wire telephone cord c01501963.gif
  3. Pick up the handset of the telephone and check for a dial tone.
  4. On the single-line telephone, dial the fax number of the receiving fax machine.
    • If the receiving fax machine answers the call, continue with the next step.
  5. Hang up the single-line telephone.
  6. Use a second telephone line or a cellular telephone to call the telephone number assigned to the HP fax product.
Step two: Change the HP fax settings
  1. Connect phone line into line 1
  3. Press the right arrow (c01669475.gif ) to select Basic Fax Setup or Advanced Fax Setup , and then press the right arrow (c01669475.gif ) again to change the menu option settings to the settings listed in the following table. Fax menu Fax menu option Setting Basic Fax Setup Rings to Answer 1 or 2 (At least one more ring than a telephone answering machine, if an answering machine is connected.) Advanced Fax Setup Answer Ring Pattern All Rings
  4. Use the HP Fax Test Service to try to send and receive a fax.
If the HP fax product still cannot send or receive a fax, continue to the next solution. Solution four: Check VoIP digital telephone line Using a VoIP telephone service can cause faxing to fail because fax transmissions are sensitive to the timing of the signals used to transmit the fax. If using a VoIP digital line is necessary, changing the Fax Speed Adjustment setting to Medium might improve the ability to send a fax over a VoIP telephone line. Use these steps to change the fax speed adjustment to a lower speed.
  1. Press the Setup button (c01669474.gif ) on the product control panel.
  2. Press the right arrow (c01669475.gif ) to select Advanced Fax Setup , and then press OK .
  3. Press the right arrow (c01669475.gif ) to select Fax Speed , and then press OK .
  4. Press the right arrow (c01669475.gif ) to select Medium , and then press OK .
  5. Use the HP Fax Test Service to try to send and receive a fax
Jul 05, 2009 | Computers & Internet
Cannot send or receive faxes
Use the HP Fax Test
  5. Use the HP Fax Test Service to try to send and receive a fax.
Jun 23, 2009 | HP Officejet 5610 All-In-One InkJet...
I can't sent fax out
hello ! click on menu scroll to fax click menu set scroll down to easy receiveclick menue set the fax should receive now providing you have dial tone on ythe line check with phone plugged in good luck brother sr tech
Dec 09, 2008 | Brother MFC 7420 All-In-One Laser Printer
Cannot receive faxes
Step one: Check the fax number
Make sure the fax number is correct; include any numbers that you have to dial to use the telephone, such as an area code, access codes for outside lines or long-distance services, and so on. If you have to dial a particular sequence of numbers to make a telephone call from that telephone line, you also have to dial that sequence of numbers to send a fax.
If the issue is resolved, you do not need to continue troubleshooting.
If the number is correct, continue to the next step.
Step two: Dial the number manually
Instead of using a speed dial setting or sending the fax from the computer, dial the number manually from the product control panel.
If the fax sends when you dial the number from the control panel, follow these steps to recreate the speed dial setting and insert pauses in the number.
On the product control panel, press the Setup button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Speed Dial Setup appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) until Individual Speed Dial appears on the control panel display, and then press the OK button.
Press the Left Arrow button ( ) or Right Arrow button ( ) to select an unassigned speed dial entry, and then press the OK button.
Use the product keypad to enter any numbers that must be inserted before the fax number, such as an area code or access codes for outside lines or long-distance services, and then press the Redial/Pause button to insert a pause.
Enter the rest of the fax number, using the Redial/Pause button to insert pauses between the numbers, and then press the OK button.
Enter the name of the speed dial setting, and then press the OK button to save the speed dial setting.
Try to send the fax again.
If the issue is resolved , you do not need to continue troubleshooting.
If the issue is not resolved , continue to the next step.
Step three: Run a fax diagnostic test
Press the On button ( ) to turn on the product, and then make sure the product is correctly connected to the telephone jack.
Make sure that there is plain white paper in the input tray.
On the product control panel, press 6 , and then press 6 again.
This selects the Tools menu and then selects Run Fax Test .
The fax diagnostic test page prints.
Review the results of the test.
If the result of the fax diagnostic test is All Pass , skip to Step four: Reinitialize the fax.
If the result of the fax diagnostic test is a failure, a page prints that describes the issue and offers possible solutions. Follow the solutions on the printout.
If the solutions on the printout resolve the issue, you do not need to continue troubleshooting.
If the solutions on the printout do not resolve the issue, continue to the next step.
While the product is on, disconnect the power cord from the back of the product and from the electrical outlet.
Make sure that the telephone cord is fully inserted into the port labeled 1-Line on the back of the product.
Connect the power cord to the back of the product, and then connect the power cord to the electrical outlet.
When the product is in the ready state, try to send and receive a fax again.
Step five: Test the send/receive functions
Use the product keypad to send a fax. Watch the product control panel display and listen to the sounds the product makes.
If the product is working correctly, the following events occur.
When the product begins to dial, a dial tone is audible, followed by the sound of the product dialing. A Dialing message appears on the control panel display.
When the receiving fax answers the call, the product and the fax exchange tones. A Connecting message appears on the control panel display. During this phase, the product and the fax compare capabilities, exchange information about how to send the fax, and try to establish a reliable transmission speed.
After the connection is established, the product sends the pages of the document. Messages appear on the control panel display that indicate the status, such as Sending page 1 .
Review the results of the fax.
If the fax is transmitted successfully, continue to the next step.
If there is no audible dial tone or the receiving fax does not answer the call, try sending the fax to a different destination. If this second attempt also fails, continue to the next step.
If the receiving fax answers the call and begins beeping, but the Connecting message does not appear on the product control panel display, the product is not detecting the tones from the receiving fax. Continue to the next step.
Step six: Use an analog telephone service
HP Fax and All-in-One products are designed to work with analog telephone services and might experience some difficulties when they are connected to phone lines with digital services. Make sure the product is connected to an analog telephone service.
To obtain digital services information or support, contact the telephone service provider or system administrator.
Step seven: Check the phone cord and fax connections
Disconnect the telephone cord, and then examine the connector on the end of the cord. Make sure the cord only has two wires.
Figure 1: Telephone cord with two wires
Figure 2: Telephone cord with four wires
If the cord has four wires, replace it with a two-wire telephone cord.
If you must use a cord with four wires, use the converter that shipped with product. The converter allows a cord with four wires to work with a device that requires a cord with two wires.
Make sure the fax is connected directly to the telephone jack by a telephone cord. Connect the cord to the 1-Line port on the back of the product.
Figure 3: Fax only
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
If other devices need to use the same telephone jack, make sure they are connected to the 2-Ext port on the back of the product.
Connect a single-line telephone to 2-Ext , and then pick up the receiver and listen for a dial tone. Make sure you are able to dial out using the telephone keypad. If you hear a dial tone and are able to dial out using the phone, the product is properly connected to a working telephone cord and telephone jack.
Figure 4: Fax and telephone
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - Telephone
Figure 5: Fax and PC or modem
1 - Telephone jack
2 - Telephone line
3 - 1-Line
4 - 2-Ext
5 - PC or modem
If you change any cable connections, try sending and receiving a fax again to make sure that the issue is resolved.
Step eight: Remove any other devices from the telephone line
If any other devices, such as a telephone, an answering machine, or a modem, are connected to the telephone line, remove each device.
NOTE: Remove each device even if it is in another room, connected to another telephone jack, or connected using a line splitter.
Connect the product to an analog telephone line by connecting one end of the two-wire telephone cord directly to the telephone jack and then connecting the other end of the telephone cable directly to the 1-Line port on the back of the product.
Try to send a fax again.
Step nine: Perform a partial reset of the product
A partial reset of the product returns all fax settings to the default values. It might be necessary to reset the language and country/region settings after the partial reset is complete.
Disconnect the power cord from the back of the product.
Wait 20 seconds, and then press and hold # and 3 on the product control panel.
Connect the power cord to the back of the product, and then release the buttons when the product turns on.
The product is reset to factory defaults.
Try to send and receive faxes again. If the problem still exists, continue to the next step.
Step ten: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
Aug 05, 2008 | HP Office Equipment & Supplies
Sending fax error message "low memory"
Try reading these:
General fax problems
Issue Cause Solution The document stops feeding in the middle of faxing. The maximum length of a page that can be loaded is 381 mm (15 inches). Faxing of a longer page stops at 381 mm (15 inches). If no jam exists and less than one minute has elapsed, wait a moment before press Cancel . If a jam exists, remove the media. If the item is too small, it can jam inside the automatic document feeder (ADF).
(HP LaserJet 3015 all-in-one) The minimum paper size for the ADF is 74 x 105 mm (2.9 x 4 inches).
(HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one) The minimum page size for the ADF is 127 x 127 mm (5 x 5 inches). If a jam exists, remove the media. The fax activity logs or fax call reports are printing at inappropriate times. The fax activity log or fax call reports settings are not correct. Print a configuration report and check when the reports print. Set the appropriate log or report printing times through the control panel or the HP Toolbox. The volume for sounds that the device emits is too loud or too soft. The volume setting needs to be adjusted. Set the appropriate sound volume settings through the control panel. Fax send troubleshooting Use the information in the following table to solve problems that might occur when sending faxes: Issue Cause Solution Faxes stop during sending. The fax machine to which the fax is being sent might be malfunctioning. Try sending to another fax machine. The telephone might not be working. Do one of the following:
  • Turn up the volume on the device, and then press Fax/Send on the control panel. If a dial tone is heard, the telephone line is working.
  • Disconnect the device from the jack in the wall, and then connect a telephone to the jack. Try to make a telephone call to make sure that the telephone line is working.
A communication error might be interrupting the fax job. Change the redial-on-communication-error setting to On.
See the electronic User Guide on the CD-ROM that shipped with the product. The device is receiving faxes but is not sending them. If the device is on a PBX system, the PBX system might be generating a dial tone that the device cannot detect. Disable the detect-dial-tone setting.
See the electronic User Guide on the CD-ROM that shipped with the product. A poor telephone connection might exist. Try again later. The fax machine to which the unit is sending to might be malfunctioning. Try sending to another fax machine. The telephone line might not be working. Do one of the following:
Outgoing fax calls continue to be dialed. The device automatically redials a fax number if the redial options are set to On. Press Cancel to stop the redials while the device is dialing.
To cancel a pending fax job, see "Canceling a fax job" in the electronic Users' Guide on the product CD-ROM.
See "Changing the redial settings" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent are not arriving at the receiving fax machine. The receiving fax machine might be off or might have an error condition, such as being out of paper. Call the recipient to make sure that the fax machine is on and ready to receive faxes. The originals might be incorrectly loaded. Make sure that the original documents are correctly loaded into the automatic document feeder (ADF) input tray or flatbed scanner (not available with the HP LaserJet 3015 all-in-one). A fax might be in memory because it is waiting to redial a busy number, other jobs that are ahead of it are waiting to be sent, or the fax is set up for a delayed send. If a fax job is in memory for any of these reasons, an entry for the job appears in the fax log. Print a fax activity log and check the Status column for jobs that show a Pending designation. All of the numbers of a long fax number cannot be dialed. The maximum number of digits of characters that can be entered into a fax number is 50. Try manually dialing the fax number. Faxes that are sent include a block of gray shading at the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM. Faxes that are sent have data missing from the end of each page. The original may be on the flatbed scanner (HP LaserJet 3030 all-in-one and HP LaserJet 3380 all-in-one only), with the glass-fax size set incorrectly. Make sure the setting is correct. See "Changing the default glass-size setting" in the electronic Users' Guide on the product CD-ROM.
Jul 16, 2008 | HP LaserJet 3030 All-In-One Printer
Can't use the fax on my Canon MP 530
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough) if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly, So try plugging into the other port on the back, it's just next to the other port hope this helps
Aug 27, 2007 | Canon PIXMA MP530 All-In-One InkJet...
Lexmark X6170 All-In-One InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
