Question about NEC Computers & Internet
My NEC MultiSync LCD2080UX powers up and I get the screen for about 2 seconds then it goes blank. If I turn the power off then back on the screen comes on for about 2 seconds and goes blank. On screen menu does the same thing. Please help! Joe...
  • fahad_ali172 Oct 29, 2009
    tell me nec MULTISYNC LCD 2080UX+BK ABOUT TOUCH SENSOR CABLE FROM MONITOR TO PC.
I returned the monitor for a full refund. I'll keep shoping. Thank you for your responce and drop me a line from time to time. dipper19
Posted on Aug 06, 2008
SOURCE:
I have 2 of these monitors with the same problem. On power up the green led will light & remain on but the screen remains black. On one of the monitors the screen will light up for a few seconds then...
The inverter that turns on the back light may be bad - it's suppose to create the high voltage pulses to fire the CCFL back light lamps. Apparently the back light turns on after a few seconds however, it cannot stay on because the inverter might be bad. If you connect a known external CCFL lamp to the to the inverter output you can isolate the inverter.
Dec 26, 2010 | NEC MultiSync LCD2010 20.1" LCD Monitor
NEC MultiSync LCD1765 won't power on
Look for bad caps with bulging top in the power supply first, post back what you see inside so we can guide you further, see example of failed monitors due to bad caps (after about 2 years): http://s807.photobucket.com/home/budm/allalbums
Feb 15, 2010 | NEC MultiSync LCD1765 17" Flat Panel LCD...
Multisync LCD 1700V turns on then screen goes blank and shuts off
Does the power light stay on? If so, you have an inverter problem. If the power light goes off, you have a power supply problem.
Sep 02, 2009 | NEC MultiSync LCD1700V 17" Flat Panel LCD...
Screen goes blank after a few seconds
Hi ,
The monitor flicker problem. The monitor when turn on will display image for couple of second then turn black. The monitor status led is still green. This will happen each time it is turn on. The symptom at appear to come from the inverter board.
May 08, 2009 | NEC-Mitsubishi NEC Display Solutions...
NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 02, 2009 | NEC MultiSync LCD2010 20.1" LCD Monitor
Multisync 1735nxm screen dosent work
Your video card may be the issue. Can you try another monitor or try this one on another PC? This will eliminate or verify the monitor.
Mar 18, 2009 | NEC MultiSync LCD1735NXM (Silver, Grey)...
My MultiSync LCD1810 Monitor stays on only for only 1 Second.
The Capacitor on the Inverter Circuit Board has gone bad and needs to be replaced. That's it.
Feb 17, 2009 | NEC MultiSync LCD1810X 18.1" LCD Monitor
DISPLAY STAYS FOR 2 SECOND ON NEC MULTISYNC LCD 1760V
the inverter board has a problem. this is the small pcb that sends high volts to the backlights you will need to change it
Jul 12, 2008 | NEC MultiSync 1525X 15" LCD Monitor
Monitor displays breifly then goes to blank screen
F1 = Fuse 1
You should be able to locate a surface mount fuse at your local electronics store.
Apr 12, 2008 | NEC MultiSync LCD1830 18.1" LCD Monitor
Nec multisync 2080 monitor
You don't really need to replace the power supply, you can repair it by replacing the bad capacitors. I've done it to 2 Nec monitors and it works. However I do not believe its you power supply because you are getting the power on light.
Oct 16, 2007 | NEC MultiSync LCD2000 Monitor
Computers & Internet Logo
225 people viewed this question
Top NEC Computers & Internet Experts
Ekse
Steven Wander
Steven Wander
Thomas F. Schneider
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
