Question about Insignia 42" LCD Flat-Panel HDTV
No Signal HDMI
I have an Insginia 42" HDTV. I tried hooked up my Comcast box with HDMI cable. I went to select the correct imput on the tv and got No Signal floating around my screen. I know I hooked the cables correctly. There are only so many HDMI ports to pick from. What is this things major malfunction?
  • Anonymous Feb 06, 2009
    I have just bought a Dell Ultrasharp 2709W 27" Widescreen LCD Monitor. It has has a HDMI input in addition to the main monitor interfaces. Now when i plug my playstation 3 into it (HDMI) it tells me that there's no signal in the port. I was wondering if anyone has any trouble shooting ideas before I call the store i bought it from or even Dell.
    THANKS!
  • kcpowwow Feb 25, 2009
    can hook up my suround sound and my directv reciver,but cant seem to figure out how to hook up my wii..dont know which plug ins to put the cables into...help me
    New Friend:
I have the exact same setup and issue. (42in plasma & Comcast).
It worked just fine and then one day I had sound but no video feed. Tested the HDMI cable, and it wasn't the problem. Hooked the cable box up with component cables and it worked fine. Either the HDMI port from the TV went bad or the Comcast cable port went bad. How does one replace an hdmi port circuit board?
Posted on May 28, 2013
So, did you have to get the television replaced or the box?
Posted on Sep 21, 2008
Had the problem. Turned out to be a defective hdmi port circuit board.
Posted on Aug 27, 2008
Can i hook up a seiki model SE39UY04 to a comcast HD box useing only the HDMI cable and which slot on the TV do I use
You should be able to. You should be able to hook the HDMI cable into the tv, than go to "TV Input" and select "HDMI 1" "HDMI 2" or "HDMI 3" depending on which input you used
Nov 30, 2014 | Seiki 39" Class 4K 120Hz LED Ultra HDTV -...
Can't get hdmi signal from comcast dvr to LG smart tv
the type of cable you use is important. i work for dish network and i have seen cables go bad. also tv's hdmi imputs go bad as well. i would call a technitian out to look at the system, have him try a new hdmi cable and in different ports to make it work. it may be there reciever or your tv.
Mar 05, 2013 | LG 55LM6700
I have comcast cable HD. What setting do I have to have on the tv?
Try connecting the HDMI output from your Comcast Set-top box to the HDMI input on your set. Then select the appropriate HDMI input from the menu.
Jun 13, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Using a vga cable to hook up my pc to the tv and doesnt work
did you change the imput --use the remote--push imput, change to component
Mar 12, 2009 | Olevia LT37HVS 37 in. LCD HDTV
NO SOUND FOR TV BUT I HAVE SOUND ON DVD
the bose has to be hooked up to the cable box output and video 1 on the bose. This is the only way it will work
Nov 14, 2008 | Sony Grand WEGA KDF-42WE655 42" Rear...
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
No Non-Hd sound
I had the exact same problem on a brand new Insignia 26 " LCD with DVD. Comcast tech was able to fix it by changing the Comcast box diagnostics. Here is what he did. Using the Comcast remote with the TV on - press power, cable, menu in that order. A comcast diagnostic srceen will appear. Select Additional HDMI options, then audio options. Change the audio options to L-PCM. Press power again to exit the diagnostics. That will fix it and you get to use the HDMI cable.
Jun 19, 2008 | Insignia 26 in. LCD Flat-Panel HDTV
Closed caption problem
I had the same issue... here's what I did.  If power off your cable box, then press the menu button, there's a selection to enable or disable Closed Captioning.  This works for both HD series Motorola boxes Comcast offers, at least in the Minneapolis/St. Paul area.  Hope this helps!
Evan
Feb 17, 2008 | Toshiba 42LX177 42 in. LCD HDTV
Lc-42d62u 42in.
This is a common issue with HDMI. Try unplugging the TV for 2 monutes and also reset the cable box as well by inplugging.
Feb 10, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Insignia 42" LCD Flat-Panel HDTV Logo
1,567 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
