Question about GoVideo Go Video DVD/VCR Combo
The dvd's I've downloaded have been playing just fine. But the last two (2) have played to a random point, stopped anf started over. I have played these dvd's on my computer and the disc contains the complete download. Any ideas????????????? DQ
  • dlquinn302 Mar 30, 2011
    Sounds like a reasonble solution. I will give it a try.
    Thank you for the information. It is greatly appreciated.
    dlquinn
  • 3,153 Answers
Downloaded DVD's can often be encoded using different software and some work better than others.
If they only play to the exact same point they were probably built from a pair of files eg cd1 and cd2 and then encoded into one.
Computers can handle these issues much better than any dvd player due to the availability of CODECS and more tolerant software. They will often play DVD's that dvd players cannot even touch
I would suggest that you run them through another program and re-burn them. Nero does a great job and will even add chapters if they are not currently set
Try stick to the exact same source for your DVD files.
Posted on Mar 30, 2011
SOURCE:
Pauses randomly during films, all front buttons play/pause the dvd
Maybe one or more buttons jammed or wet inside.
Try opening front panel and clean the contacts. If problem persists then it is the buttons controller IC/PCB faulty.
Feb 04, 2018 | Televison & Video
LD Repeats itself every 15 seconds in play, DVD's play fine.
This solution should help or at least decrease the occurances.
It has worked for me.
The problem seems to be that the original manufacturer lubrication on the glide rails and on the glide track has lost it's viscosity causing the Laser Pick-up Head gliding process to bind causing video to repeat at any random binding point.
Open the top cover and play a Laser Disc.
Manually change from Side "A" to Side "B".
Observe how the Laser Pick-up Head glides on the track and on the glide rail.
Stop play mode and remove the Laser Disc.
With the tray open, unplug the power at the power electrical cord. Now with the power removed and the tray left open, take a "Q-Tip"™ and spray some ""WD-40"­™ on the "Q-Tip"™.
Now gently tap the saturated "Q-Tip"™ along the full length of both the upper and bottom glide rails as well as the glide tracks.
Repeat this process.
Be careful not to touch or lube the Laser Pick-up Head with the "Q-Tip"™.
If you do touch the Laser Pick-up Head, just gently clean it with another "Q-Tip"™ saturated with alcohol.
When finished, reconnect the power and play a Laser Disc.
Manually change From "SIDE "A" to SIDE "B" about three times to spread the "WD-40"™ evenly and ease the gliding process.
This solution should help.
Feb 08, 2009 | Pioneer DVL-919 DVD Player
Freezes in the middle of playing a dvd
1. You say in the (middle?) That in itself is subjective, Does it stop at an 'exact' specific point after playing for x number of minutes? Is it the same point for any DVD being played, or does it stop at a random point? - Does it stop when playing DVD--R or +R or what type of Disc? - more details helps to find a solution.
Also it is never necessary to use cleaning discs - Do that and it will wreck your player - and may never read a disc again. Using cleaning discs could have caused your problem. Use cleaning discs only for practicing how far you can throw them.
Jan 17, 2009 | Cyberhome Televison & Video
Random play for all cds in player
You might have to push each Cd button first so that it initiallizs all 5 disks and then press random
Nov 22, 2007 | Panasonic DVD-F87 Multi-disc DVD Player
DVD Problem
Call Bose and they will send you an update CD to update the firmware of the CD/DVD player. I had a problem where a few of my new movies would not play at all. They sent me an update, no more issues. If you're a registered owner, they will send update CDs frequently, be sure you're registered as well.
Nov 22, 2007 | Bose Lifestyle 38 System
Random stopping while playing CD > error message
yes yes yes clean it if that dont work i would just say "sorry" go with a diffrent brand player. cuz my dad has had 3 or 4 of them and i had 2 of them and they never lasted of held up. they have all fried to easy. i dont trust sony car equipment.
Aug 18, 2007 | Sony CDX-F5510 CD Player
Video image problem- Blue screen?
If your unit is fairly new,your VCR part might be the problem.Take it back!
If you have this unit for awhile,two things:
1. You need a professional A/V repair guy to clean up and check your VCR head.
2. The rental VHS tape is dirty.
Jul 28, 2007 | RCA DRC8335
Random no audio
I have had this happen with this particular brand frequently. I have it plugged in to a power "strip" or surge protector. I find that if I turn the strip off then on again, it resets and fixes the problem.
Feb 18, 2007 | Cyberhome CH-DVD 300 DVD Player
INSIGNIA IS-PD040922
The laser has become damaged/worn-out. There is no fix for it as replacement parts are not made for it.
Nov 27, 2006 | Insignia IS-PDO40922 Portable DVD Player
GoVideo Go Video DVD/VCR Combo Logo
230 people viewed this question
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
