Question about Black & Decker String Trimmer Cordless 12" 18V
This power pack edger/trimmer that says NO Bumping Required doesn't give me more cord and hasn't since I bought it a couple of years ago. I went back to HomeDepot where I bought it and they sold me a preloaded spool designed for this product. They put it in for me and it still doesn't work.
    Problem Solver:
  • 18 Answers
See my answer to this under B&D Grass Hog Electric Trimmer. Possibly, if you have the white lever mentioned in another solution, that might be it.
Posted on Sep 02, 2008
SOURCE:
The pull cord on my trimmer pulled out, but did not recoil. It is new this year. Any thing I can do to get it to recoil?
More than likely it has jumped off the recoil spring, but it may have broken the spring. More investigation is required,best get your tools out. :)
Sep 17, 2011 | Husqvarna Garden
My battery does not hold the charge, i will charge it for 24/hour and it only last 5 minute, why is that, iI buy this product for wife when went to Iraq, and when i talked ton her on the phone three months...
NiCad batteries have this problem when they are recharged frequently after being only partially discharged. This is also the case when the batteries are left in the charger continuously - even if the charger is described as being "automatic". I have old 12v batteries that I have been using for 20 years, but I only charge them for a few hours, and only when they have run down enough to be useless. I prevent leaving them too long in the charger by using a timer that cuts the power to the charger after a couple of hours. A couple of years ago I bought new drills and chargers, and believed that the chargers would be automatic and so could be left plugged in. Those batteries only lasted a couple of years, while the old ones are still going strong. I now use the timer for any of these chargers, automatic or not - but I had to buy new batteries first. good luck, Al K
Jul 29, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Bought trimmer last year...battery no good this year...will not charge
Check that your charges is working - charge light on the unit or test output voltage. If these are ok, you will have to buy a new power pack for your trimmer or get a battery specialist to make up one for you. This will be by far the cheaper option.
May 01, 2011 | Worx GT WG150 10 in. 18 Volt Cordless...
Bumping does not release cord
its possible that the line is too thick,or incorrectly wound,or too much line on the spool,or the spool is clogged with grass,rgds
Sep 25, 2010 | Troy Bilt Tb70ss Gas Trimmer
I've owned this great little Black and Decker CST800 grass trimmer for 6 years and only use it in Montreal summers (5 months long). Just this past week, I brought it in to recharge it and left it for 5...
never charge batteries that long usually only 3to5 hours if ni-cd . most batteries last 3 or 4 years . totally discharge pack and try to charge again . if nothing buy new battery pack
Jun 15, 2010 | Black & Decker 8 Inch 12 Volt Cordless...
Cord won't retract
The spring is either broken or the catch on the end of it isn't seated, this is a coil spring inside the hub, probaly has to be rewound to gain the tension back
Aug 22, 2009 | Garden
TRIMMER WILL NOT FEED LINE
Have you tried bumping it on the ground as you give it throttle? If so, then the line itself may be too large for your trimmer.
I really need more information to answer the question accurately though.
Jim
Jun 24, 2009 | Homelite Mighty Lite Lawn Trimmer
Black & Decker String Trimmer Cordless 12" 18V Logo
55 people viewed this question
Top Black & Decker Garden Experts
gggg
Nick Olsen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
