-   I have a dd603ss the bottom drawer is leaking at the top of drawer, the seal looks good. the drawer slides are rusted and corroded I think that the lid is not closing all the way on the left side, the side that has water on it after washing. the F1 code alerted me to the situation.If it is the lid motor can I replace it my self.-   eddiepfist
F1 fault means the flood switch on the base of the dishwashers has been activated.
nine times out of ten its the lid motors.
You can remove the two kick plates on the bottom of the dishwasher.
Dry out the water in the base with a sponge.
only one draw will be leaking water??
This allows you to use the second draw until a serviceman shows up.
Dry the base out A.S.A.P, because you have a electronic board that sits on the base. cheers
I have a dd603ss the bottom drawer is leaking at the top of drawer the seal looks good. the drawer slides are rusted and corroded I think that the lid is not closing all the way and has been leaking for some time on the left side, the side that has water on it after washing. the F1 code alerted me to the situation.
Hi I have dishwasher Westinghouse touchdry SB915. It was working properly from long time. Today I...
(More)
Hi I have dishwasher Westinghouse touchdry SB915. It was working properly from long time. Today I started and its not working now. I can select program like normal or eco or rinse or fragile or heavy but that time twice it appears minutes respectively but then it shows some vierd number on display and if press start button, its not working.
We have a westinghouse touch dry Sb915. It started beeping through the wash cycle and stopping -...
(More)
We have a westinghouse touch dry Sb915. It started beeping through the wash cycle and stopping - then you could press the program button and it would continue on. It would do this about 4 times before continuing on with the cycle. Now the dishwasher is constantly beeping through all the cycles and we can not get the cycle to finish - it just keeps getting stuck. The timer also moves forward and backwards (one minute it will say 6 minutes left and then it will say 42 minutes!). My partner is a plumber and has had a look at the dishwasher but he cannot work out where it needs to be fixed. Any help would be appreciated! Thanks.
my dishwasher is a nardi, not very well known, but recently the cutlery with any grease on like marg...
(More)
my dishwasher is a nardi, not very well known, but recently the cutlery with any grease on like marg or butter does not get clean, plates are fine, so i am confused. appreciate a reply thanks
