Question about Acer Aspire 5610-4648 Notebook
Sound i have no sound on my laptop and it says my speakers work
  • 4 Answers
Right click the speaker icon and enter the sound properties.
Make sure the boxes are unchecked and the volume levels are up and MUTE is off.
If you have a bad driver you can remove it by going to the system menu (right click my computer). Remove the driver and it will be reinstalled when you reboot.
You can also check online for driver updates at the manufacturers support site.
Check the obvious first. Also if you did anything like install a new game or software update, that can be your conflict.
You can roll back to the last restore point if all else fails.
You will find it under start/programs/accessories/system tools/system restore
Always create a new checkpoint when everything is running great and before you install large programs.
CR
Posted on Aug 04, 2008
No Sound, Windows 7 laptop
Is the speaker plug it the right connector and inserted all the way? Are you using the headphones jack? Do headphones work in the jack? Is the sounds section in Control Panel function properly ? TroubleShooting? What? Drivers? Power on speakers? Check connections/wiring?
Nov 24, 2012 | Computers & Internet
Harmon Kardon Go+Play speakers wont work on Del laptop with Windows 7.
click start control panel hardware and sound manage audio devices playback
you should see your speakers right click select enable or you might have to configure them this option will be at the bottom of of the playback list also right click on the speaker select properties
you should see a few tabs general levels enhancement and advanced you might find you need to select a different option possibly stereo or dvd or studio quality windows7
hope this helps
Feb 16, 2012 | Harman Kardon Audio Players & Recorders
Speakers are not working in dell inspiron 6000
Please connect an external speaker or headphones and check if you get sound. If sound works then the issue is with the onboard speakers in the laptop.
If sound does not work with the external speakers or headphones then the issue could be with the sound card driver or settings.
Dec 25, 2010 | Dell Computers & Internet
No sound from external speakers with toshiba dynadock
if using XP, go to start control panel , sound and audio devices.Under the audio tab make sure the C Media CM106 sound device is selected under sound playback. Then under the volume tab set the volume somewhere in the middle or at the top if you don;t have active speakers . Then Under Speaker settings advanced, make sure the speaker setup is set to Laptop Stereo speakers. Also make sure the speaker volumes are up on the speaker volume button. click ok. If no result check that the cm106 sound decvice was cemented in as I saw it dissaper when I thought i had slected it. I think the key thing here is the device and the laptop speakers setting.
Aug 26, 2009 | Toshiba Dynadock Port Replicator, Docking...
Sound speakers not workin but headfones workin
plz check the speaker with other computer if the speaker is ok then the problem is with your sound card.
Jun 25, 2009 | Acer Aspire 4720 Notebook
Sound does not come out of speakers but does with headphones
try to uninstall the sound driver and install the actual one from here http://support.acer-euro.com/drivers/notebook/as_4720.html
Jun 07, 2009 | Acer Aspire 4720 Notebook
Built in Speaker no output Sound.
If you can get inside the laptop, try reseating the speaker wires to the motherboard and if that doesn't work, then your speakers are blown are the moterhboard is bad.
Feb 09, 2009 | ASUS m6n Notebook
Hi, My speakers won't work on my "Vista" laptop. I have made 3 trips to bestbuy. "it's 20 miles round trip." The geek guy got them working,when I play DVD movie. befor they worked on...
Your Majorgeek seems to have been a Minorgeek. When you purchase external speakers to use with your laptop, you must configure your laptop for them. Since your system appears to have worked before you tried to use external speakers, I doubt that you have a problem with your sound device driver. Still,
go to control panel,and check device manager to see if you have any problems. If you have a problem flagged, let me know. If not, click on Hardware and Sound, then on Sound, and see how your laptop speakers are configured. Majorgeek should have turned off your internal laptop speakers and configured them for your external speakers. If they didn't, that likely explains your problem. Configure them and test the sound there.
If you need to use your laptop speakers (say you take your laptop somewhere without your external speakers) you will need to reconfigure your sound to the laptop speakers whenever you need to use them. Let me know if this solved your problem.
Jul 12, 2008 | Logitech X-530 Computer Speakers
Speakers do not work but rearly they will?
What type computer? Vista or XP? I take it you have X-530 speakers?
Go to control panel,and check device manager to see if you have any problems. If not, click on Hardware and Sound, then on Sound, and you will see the "Playback" tab. Highlight "speakers" by clicking on it, then click on "configure" to see how your laptop speakers are configured. If you have a laptop, your internal laptop speakers should be turned off. Configure them for your external speakers and test the sound there. If you need to use your laptop speakers (say you take your laptop somewhere without your external speakers) you will need to reconfigure your sound to the laptop speakers. Let me know if you have further problems--you may need to update your sound driver.
Have you done maintenance on your computer, such as getting rid of unnecessary files and defragmenting the hard drive? If not, go to "applications" in your program files to do so.
Jun 20, 2008 | Logitech X-530 Computer Speakers
Acer Aspire 5610-4648 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
