Question about Nespresso D300 Espresso Machine
It flashes READY SCALED
It seem to work O.K. maybe the water could be a bit hotter but this message READY SCALED what's up"
  • florentg Nov 16, 2008
    Flashes Scaled, What can I do?
i found out that the button that warms up the steamer also has another function. if you start with the machine completely shut off but still plugged in, and press and hold the steam button, it gives you instructions for descaling and walks you through the process, telling you what to do at each step until you are done. so i did it and just finished a few minutes ago.
Posted on Feb 07, 2011
I have the same problem, I can't remove "ready scaled" and the water can be more hot.
Posted on Sep 15, 2008
I can get hot water but central heating will not come on. The radiator sign on the boiler is flashing all the time
there might be a problem. flashing lights meaning there is something wrong in either wiring or heating coil. some are equiped with manualy reset system. or some solinoid or contactor or a motorized valve. scaled water sensor or stuck float swithes.
Oct 25, 2016 | Water Water Heaters
Does not pour the proper cup size. Have the default set to the largest size. Sometimes it pours the proper size, other times it pours a smaller size. Also, the sequence of action seems to be off. Sometimes...
the Keurig is supposed to keep at least 12 OZ of hot watet at the ready...
when you press brew, the pump pushes water into the bottom of the heater... the hot water comes out the top into a clear plastic holder with probes sensing the height of the water... when the proper height is reached, the motors change state... other valves open up and that pur-measured water goes from the plastic holder tank to the arm touching the K-Cup...
Try running vinegar thru the unit and maybe the sensor probes are scaled... otherwise... you may have a intermittent connection and would beed to reseat the low voltage wires from that water height container...
involved taking the unit apart... :(
try the vinegar first.
Seems like internal cables need reseating.....
I posted how to open it... do not do unless its out of warranty... and you have a few hours of time to disassemble it...
May 06, 2010 | Keurig B50 Coffee Maker
Gaggia Coffee Delux Steam pressure probem
1: do you pres the switch for steam and wait until it is ready? 2: how long time machine needs to be ready for steaming?
solution 1 = if you don't press the steam switch on you will have very small amount of steam. solution 2 = if the machine gets ready only for few seconds to steam, than you must change your steaming thermostat attached in boiler(there are 3 of them: 1 security 2 coffee brewing 3 steam
i hope you fix it soon and enjoy in perfect espresso
Apr 04, 2010 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Will not draw water from the reservoir
Sounds like it is too scaled up to work now. Use and care guide recomend you do it every 3 months and if you dont it builds up to the point that it gets completely clogged and will not pull in water.
Mar 05, 2010 | Keurig Platinum B70 Coffee Maker
Our coffee tastes very weak. Would de scaling help.
This would not hurt, but I think you just need to add a tablespoon or two more coffee grounds or until it is the strength you want.
Only the heat of the water will give you poor quality, the hotter the water
the more coffee comes out from the grounds.
Feb 04, 2010 | Keurig Elite B40 Coffee Maker
Adobe Flash Player download problem
What Browser are you using, incidentally?
If you're trying to download the latest Flash Player, then maybe the link is detecting your browser... If you are using a 64-bit browser (I have no experience of these, I just think this might be worth a try) then maybe you should try installing Firefox and installing the Adobe Flash Player with that, to make sure you don't get 're-directed' to the 64-bit-message.
Try this link instead:
http://www.adobe.com/products/flashplayer/
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Dell Dimension 2400 PC Desktop
Triton opal electric shower overflow pipe
hi rob the problem is due to an activated thermal overheat switch, you cannot reset this unit as once it is activated it will require a new unit, its a nuisance i agree as i come across this regularly, however its condusive of a scaled up unit so you eventually turn up the shower setting higher to get the water hotter, & inturn activates the thermal switch.
According to which model it is the part is not that overly expensive, you can phone triton direct 7 they will post a new spare to you
Kindly
Richie
Nov 19, 2008 | Home
Saeko Italia - Water flow is very slow
We repeated the de-scaling and it seems to have taken care of the problem.  (at least for now!) Maybe there was a build up that the first cycle did not remove but the second cycle got it.  Don't know for sure just glad it's working!
Nov 16, 2008 | Saeco Royal Professional Espresso Machine
Nespresso D300 Espresso Machine Logo
835 people viewed this question
Top Nespresso Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Kolbrun...
Jay Finke
Jay Finke
Are you a Nespresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
