Question about Roper RGX4634KQ Gas Dryer
Heats up once after initials start.
After sitting for awhile the gas will kick on the you can see the glow plug heat up and the gas will not kick back on after initial dtart up.
  • 943 Answers
HI the problem you have is with the 2 coils on the gas valve. replace the coils and clean out the lint in all vents thanks the appliance doc
Posted on Oct 16, 2008
SOURCE:
Dryer quit heating.
-Check heater element first. Or possibly others then the element. like thermal fuse.
Good luck
mai
Dec 14, 2013 | Whirlpool CGM2751KQ Gas Commercial Dryer
I have a gas Kenmore Dryer 74202200 and it heats sometimes, moreso when it first comes on. The glow plug works and it clicks and it fires up, but then the fire shuts off and the glow plug comes back on a...
if it runs for the first 15 to 30 minutes and then no heat you have bad gas coils,located on top of the gas valve,when the coils heat up they fail,if you try to start it again after it sits for a long time it will lite again,also you could have a bad gas valve,try tapping the valve to see if it lites,if it does lite while you're tapping on it most likely it will be the valve,let me know what you find and send the model number.good luck
Jul 26, 2010 | Kenmore 63942 Dryer
Gas Furnace trouble
the thermostat sends a signal to the circuit board. Not knowing anymore than I do about your heater or furnace I would suggest that that is a good place to start. Any limit or safety switch wouldnt coincidentally shut off the heater when it reached the set temp.
Jan 09, 2010 | Heating & Cooling
Dryer will not relite after initial warm up
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=LGR5636L&siteCd=WHRCOM
This site has 6 variations of LGR5635L, user guides, setup instructions, warranty guides and parts manuals. Also, I think there should be a wiring diagram on the inside of rear cover. Hope this hekps.
Aug 24, 2009 | Whirlpool LGR5636L Gas Dryer
Kenmore 80 series gas dryer has not heat
most of these dryers have a little plastic plug on the front, left side. pop that plug out and look inside after turning it on. you should see a red glow. if not, then your ignitor has broken. if you see a glow, then the problem is probably one of the two little coils on the gas valve. these coils will sense if there is something to light the gas [the red glow] and open the valve - if the coils are bad, they won't open the valve
Aug 17, 2009 | Kenmore Dryers
Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Jul 14, 2009 | Whirlpool Dryers
Roper gas dryer mdl RGS7646KQ2
hi keith. yes replace the 2 coils on the gas valve. it will solve the problem. thanks the appliance doc.
Oct 16, 2008 | Roper RGX4634KQ Gas Dryer
Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Sep 12, 2008 | Dryers
GAS HEATER
No, it does not. No car heats gas, some diesels have or used to have a 'glow plug' to get the diesel started but gas cars do not.
Jun 21, 2008 | 1990 Volvo 740
Intermitten Heat up
make sure that your vent is not plug up can you go outside your house and feel good air coming out the vent when the dryer is turn on if so the only other things it could be is the coils that sit on the ignotor assmebly or the high limit termistat is not working properly the coils are little black circle coils that sit in the ignitor assmly should have a metal braket across the top of them holding them in you can check resistance on these coils if you have an meter
Mar 22, 2008 | Kenmore 72802 Gas Dryer
Roper RGX4634KQ Gas Dryer Logo
61 people viewed this question
Top Roper Dryers Experts
Marvin
Marvin
Dennis Boxerman
Colin Stickland
Colin Stickland
Are you a Roper Dryer Expert? Answer questions, earn points and help others
