Ir 5000 intermittent jamming when copying on a3 paper only
When using the feeder it will jammed intermittent
    Sniper:
  • 54 Answers
Clean the feeder pick up rubbers
Posted on Aug 14, 2008
SOURCE:
Fix paper feeder that keeps jamming. How to clear jam and fix on-going jamming problem
What thickness of paper are you using? Also is the paper new/fresh or are you re-using paper that has gone through the printer already?
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
The copier experienced repeated paper jams
Pl. mention make/ model and where it jammed. if possible the photo of the jammed paper inside the machine. Also mention the total pages printed in A4 and A3 size.
Thanks.
Dec 13, 2014 | Office Equipment & Supplies
Canon ir 2420 shows paper jam when there isnt any
HI,
This is happen due to printer feeder problem.... pls check feeder and clean carefully.
Thanks,
Nov 11, 2014 | Office Equipment & Supplies
Hello , i have cannon IR 2270/2870g photo copy machine ,paper jam at the time of double side copy
Open your developer unit and check sensor , refix it an close unit see........your problm solved
Apr 22, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
Make A3 Copy (Toshiba Studio 206)
If your copier didn't set any A3 drawer, then u need to insert A3 paper on bypass unit, on left panel select A3 (Original) to A3 (copy) b4 u press the start button. Otherwise paper jam will occur.
Apr 05, 2010 | Toshiba e-Studio 205 Copier
The canon runner s5000
1)u must verify which location of the first paper jam occur.
2)pick up unit > feeding >fuser unit> output delivery unit.
3)try to use platen glass for copying instead of using the auto document feeder unit.then u can narrow down the issue.
Sep 11, 2009 | Canon imageRUNNER 5000 Copier
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Jamming of paper using the Automatic Document Feeder
You may have a really tiny paper jam. You need to open up unit to get access to feeder properly. Use a torch, jams can be so small you can miss them. cheers lilacgerry
Jan 28, 2008 | Brother MFC 6800 All-In-One Laser Printer
Open Questions:
47 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
