Re: I need to know HOW TO GET A CURRENT PAGE COUNT.
To get the page count, press Function, then choose Data Registration, then #, then scroll down to Printer, press OK, scroll down to Page Count, press OK.
Print a menu page: press menu right button until utility menu is displayed, then press select (lcd display print menu), press select again and the printer print the menu page, where you can see all the parameters.
You must enter in maintenance mode: Press the Menu/Set and Start keys. Next press the key four times to make the machine enter the maintenance mode, or turn on the machine while pressing the menu/set key. The machine beeps for approx. one second and displays "MAINTENANCE " on the LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which the machine is ready to accept entry from the keys.
Display of the Equipment's Log Information (Function code 80) Function The equipment may display its log information on the LCD. Operating Procedure (1) Press the 8 and 0 keys in this order in the initial stage of the maintenance mode. The USB serial number appears on the LCD. (2) Press the Start key. Each time the Start key is pressed, one of the following log information items appears on the LCD in the order given below. 1) Jam count, indicating how many times a paper jam has been occurred 2) Page count, indicating how many pages the photosensitive drum has been printed 3) Total page count, indicating how many pages the equipment has been printed since produced 4) Drum count, indicating how many times the photosensitive drum has been rotated 5) Drum change count, indicating how many times drum replacement has been made 6) Toner change count, indicating how many times toner replacement has been made 7) Copy page count, indicating how many copies have been made 8) PC print page count, indicating how many pages the equipment has been printed as an output device of the connected PC 9) FAX page count, indicating how many received FAX pages have been printed 10) Error code of the most recent machine error *1 11) Error code of the most recent communications error *2 12) ADF jam count, indicating how many times a document jam has been occurred 13) ADF page count, indicating how many documents have been fed (3) To stop this operation and return to the equipment to the initial stage of the maintenance mode, press the Stop/Exit key To exit maintenance mode press 99
When you change the Toner Cartridge out, you do not have to reset the page counter, this is done when a maintenance kit is installed, Though if you would like to track how many pages, you could get the current page count from the configuration page, which is accessed by going to the Menu-----
Configuration page
The configuration page lists current settings and contains a status log report.
To print the configuration page from the printer, press GO for 5 seconds, until the yellow light comes on, when the printer is in the ready state.
NOTE Make sure that you hold the GO button for less than 10 seconds.
go in start then printer and faxes and then goes the properties of hp lj 1020 and give one print text page after the page will printing goes in advance then printing default then basics and then about then display the current page count from your printer you can note down this is in eveary day and then your can manage your print count
