Question about Kenmore 62872 Electric Dryer
My dryer heats, but doesn't tumble.
How do I check the belt? I took the back of the machine off, but didn't see the mechanics of where the belt would be. It's older, model # 66801692, type #180-00
Have you any ideas?
Thank you! Carol
  • 659 Answers
Well it could be the belt but it could also be a loose motor, idler pulley or spring.
here is what it should look like bottom right picture on this one
and this will help you get to where you gotta get to
Posted on Aug 04, 2008
Dryer not tumbling
Look up the model, google or the like and see if u can find some schematics. Its does seem likely to be the belt but u may find a better way to crack it open.
Aug 31, 2012 | KitchenAid KEYS750LQ Electric Dryer
I have a Neptune dryer. On big loads, such as towels it doesn't tumble it just hums, although it does heat. What could this be?
they are turned by a large belt that encompasses the entire drum... it could be getting loose, the entire machine has to come apart to find and fix the problem... there is also a spring connected to the motor for tension on the belt this could be the problem as well.
Jul 04, 2012 | Maytag Neptune MDE5500AY Electric Dryer
MY Roper Dryer model # RED4340SQ1,Will Tumble but not Dry Clothes
For this job, all your work is going to be behind the machine. Tools you'll need is: 1/4 nut driver or drill with 1/4 adapter and a multimeter with ability to check continuity. With the machine unplugged, remove the back cover of the dryer. Once done, the heating element will be located on the right hand side with two fuses on the housing of the element. Test the element and each fuse seperatly by removing the wires and checking for continuity on each component. All parts should show continuity, so if one doesn't its bad and needs to be replaced
Apr 25, 2012 | Roper REX4634KQ Electric Dryer
My dryer heats up but does not tumble. I replaced
Sounds like worn tub back bearing.
take the belt off and spin the tub by hand to see if it is binding.
check that the pulley isnt loose on the tub back and also the motor pulley, feel if the motor spins free.
Finally check the tub itself for objects poking through or lodged in the outer tank.
Good luck
Mar 18, 2010 | Dryers
Kenmore dryer 75731 won't tumble. It heats fine.
The machhine is belt driven check the belt first.
If the motor is must be tested energizing it.
In all cases test the lid switch to ensure it is not opening contact when machine starts tumbling.
The wiring harness to motor must be tested.
If there is no other fault elsewhere, replace the timer board.
Start from the belt, if the machine is heating, then it is probably a broken belt.
Nov 13, 2009 | Kenmore 63942 Dryer
Dryer turns on but won't heat up or tumble
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Heats but won't tumble
There probably is a belt. Usually not too hard to replace if you have some basic screwdriver and mechanical aptitude. I've replaced several over the years and I aint no Maytag repairmen. Call your local parts house with the make and model and pick up a new one. Even if it's not your model you can probably find a utube video that will help make sense of it. Be sure to unplug the unit before working on it.
Sep 08, 2009 | Dryers
The dryer heats but will not tumble. I am
if the belt was broken, the safety switch would shut off the machine. the belt is probably slipping, stretched from age. replace belt
Jul 09, 2009 | Frigidaire FGX831C Top Load Stacked Washer...
Tumble dryer
If you here motor running, you have a broken belt. Give brand and model and I can help you change it.
Nov 21, 2007 | Dryers
Kenmore 62872 Electric Dryer Logo
409 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
