Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Magnavox big screen problem
When I turn tv, there is no picture. When i turn it off the picture comes on for one second, then tv shuts off. Tv is about 5-6 years old. Somebody told me it could be power supply? I'm thinking projector bulb. Any thoughts?
  • kiddwyck Aug 07, 2008
    When I see the screen before it shuts off, the picture comes up good. I dont hear any audio. I notice next to the power button. The av button. I can push that and the tv turns off, just like the power button. the first time this happened, The picture came back by itself, but this time its not coming back. Prior to this tv was working good, only thing i noticed was when you turn it on, it will take alot longer for the picture to come up then when i first bought it. about 7 seconds to see picture when you turn it on.
  • Philips Master
  • 3,459 Answers
Its not the bulb.
When it comes on is it real bright?
Did you loose the audio also?
Any other symptoms prior to having this problem?
Posted on Aug 06, 2008
6ya staff
SOURCE:
We have an older Phillips Magnavox tv. The tv will turn on & we will see the picture for a short time but then the screen turns grey. We still have sound, just no picture. Also, the green power light...
Hello, the grey screen could be due to a missing 220Volt source which feeds the color (RBG cathodes)inside the CRT(picture tube). When this happens the beam current inside the CRT goes high in a matter of second, thus triggering the beam current protection circuit(blinking green light)shutting down the TV. Repairing the secondary voltage source is necessary to get the TV working normal, a good technician should be able to repair it for between 80 to 100 dollars parts included, except a picture tube, which could be also the cause of the problem(K-A shorts).
Nov 06, 2010 | Philips Magnavox 27MS343S 27" TV
Can you replace the picture tube on a big screen maganavox tv?
yes it can be replaced.but the tubes are costly to get replaced.you can get the parts at www.partstore.com or at www.shopjimmy.com thanks.
Jul 11, 2009 | Philips Magnavox 51MP392H Rear Projection...
TV SCREEN IS JUST A BLUE PICTURE,BUT HAS SOUND
Hi and welcome to FixYa,
Offhand it would appear that the VCR section of the combo unit would require a bit of cleaning. Specifically, head cleaning. The easiest approach is to use a VHS tape head cleaner.
The other post of "tv turns on then 5 seconds later shuts off" would be the auto-protect kicking in. This indicates that a likely hardware fault exists. Try to initially reset the unit by unplugging from the mains for an extended period. Otherwise it would require opening the unit for voltage measurement/diagnosis.
Pls post back updates. Good luck and thank you for using FixYa.
Jan 25, 2009 | Philips Magnavox Learning Universal Remote
Magnavox TV will no longer turn on
Does it beep .. or anything? Does the front LED come on?
May 24, 2008 | Philips Magnavox 51MP392H Rear Projection...
TV FIX
A line across the screen means a loss of vertical sweep. This could be as simple as an IC or as difficult as a deflection yoke. These are not do it yourself repairs.
Nov 30, 2007 | Philips Magnavox TP3285C 32" TV
Tv problems
i have a sony hdtv 60" and when I try turn the tv on the power light flashes 5 times green then it turns red
Nov 26, 2007 | Philips Magnavox 51MP392H Rear Projection...
Tv has a big black in yhe middle,does that mean that the picture tube is going out
no that is not the sympton of picture tube failure. please give the details of your problem so we will get you solution.
Oct 07, 2007 | Philips Magnavox 27MS343S 27" TV
Tv has an advertisement that wont go off
Press the up and down volume buttons on the TV at the same time. This will turn off demo mode.
Aug 29, 2007 | Philips Magnavox 27MS343S 27" TV
No sound no picture
This is a common problem with older Philip Magnavox projection sets. Over time one of the IC chips on the main power board begins to fail. You can find replacment chips and repair instructions on www.magnavoxhelp.com.
Mar 28, 2007 | Philips 50P8341 50" Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
