Question about Maytag Neptune MDG5500AW Gas Dryer
Dryer running loud
My dryer - not even 2 years old - is running louder than it normally does. Any suggestions would be great. I clean the filter with each load; not sure what else what I should do. I have treated it with kid gloves and I am the only one who uses it.
  • 4 Answers
It sounds like your motor may be going out (search for motor replacement solution here).
Hopefully it is just a problem with grit in the system, or perhaps the felt gaskets have worked themselves loose. Either way, to clean out grit and inspect the system you'll need to access the interior and remove the drum. Here's how:
  1. This will require you to disassemble the dryer. This is not hard - it will require the following tools:
    crosstip medium screwdriver
    1/4 inch socket
    5/15 inch socket
  2. UNPLUG DRYER
  3. TURN OFF GAS
  4. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  5. This has exposed the interior.
Now: Maintenance time!
  1. Using compressed air blow out all vents and the motor.
  2. Wipe dust and grit out of crannies
  3. Vaccuum bottom interior
  4. Blow it out again
  5. Using ultra fine steel wool (#0000) rub all contact areas of drum - belt region, and ends that contact the felt gaskets and the rollers at the rear
  6. Check to ensure the felt gasket is in good shape all around the drum contact area. If it is torn, malformed or missing you'll need to replace. With any luck this is where your noise is coming from.
  7. Check the blower cage. Ensure this is free of grit. It is worth taking off the eight screws to wipe out/blow out interior.
  8. Worse case scenario - your motor is on the fritz (although this motor should give you 8-12 years of service). This will require removal, replacement. Motor cost is about $100. Labor will be more.
Posted on Nov 01, 2008
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
My Maytag Bravo dryer adds extra minutes to cycles. If I set it for normal or bulky it will run for some time and when I check to see if it's done it still has over an hour left on it, more than the...
Your dryer has a moisture sensor, if it senses that the clothes aren't dry enough it will extend the cycle. A couple easy things to check:
1. Be sure the spin cycle on your washing machine is working properly. If the clothes are too wet when you add them to the dryer your dryer will need to add more time to get the clothes dry
2. Be sure your lint filter is cleaned after each load, and have your dryer exhaust vent cleaned- it could be clogged.
Oct 29, 2013 | Maytag Dryers
Dryer gets loud as it heats up
You have not mentioned the brand or year or model number, but most dryers have one of 2 systems.
One older system has a bearing back there, inside the machine, but outside the drum.
That bearing can fail, causing this.
I have had several of these, and am using one now.
The dryer must be completely disassembled and the bearing replaced.
The second type uses pulleys in the back and plastic bearings (nothing more that flat pieces of plastic) in the front.
The wheels or plastic plates can wear out, also causing these symptoms.
In either case, now is the time to fix it.
God bless your efforts.
Nov 02, 2017 | Dryers
I have a dvl223Eb6ww dryer..heats great but started making a scratching noise that seams to get louder as the dryer gets hot..what could this be..we took it apart and the belt seams fine heating element...
Sounds like you have bearings problems that need need grease. Normally the drum rests on two separate bearings up front and one located at the drum center at the rear. Since you know how to take it apart you should be able to locate the bearings. A mall amount of general purpose grease will do the trick. The scatching noise may come from loose object floating around, may be a shirt button ? investigate.
Good luck and good repairs. A dryer repair is not too difficult since you have already checked to condition of the belt...Here an extra tip for the performance of your dryer, always clean the screen air filter with soap an water to remove the invisible screen deposit by the Fabric Freshner Sheet also called Fleecy. This will allow air flow to exhaus the dryer more freely.
Aug 21, 2017 | GE DVLR223 Dryers
GE Harmony Dryer makes Loud Vibrating noise
If you can open the walls of the dryer up check all screws and bolts that hold things together. Some times they will vibrate loose causing parts to make a vibrating sound against the frame itself.. Eventually the loose screws will just keep getting looser. Even the screws on the walls of the unit should be tightened That could cause a lot of noise.
Apr 10, 2017 | GE Profile Harmony DPGT750EC Electric...
LG DLE5977W dryer has stopped and developed a motor hum. How can I fix it?
I am assuming that the hum indicates the motor is running but the drum is not turning.  Possibly a broken drum belt however the check filter warning is indicating low air flow so the blower wheel could be broken at the connection to the motor shaft.
Jun 01, 2009 | LG DLE5977 Electric Dryer
Maytag gas Dryer is Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 19, 2009 | Maytag MDG7600AW Gas Dryer
8 year old Whirlpool gas dryer will not run - it just hums when put on any setting. Is this a motor problem or the belt?
it sounds like the motor....generally before the motor dies the motor will become louder and louder, and when its hot and you try to restart it it will make a loud hum as it tries to turn
Dec 31, 2008 | Dryers
Roper dryer
if you are sure vent is ok ..did you try a load with vent disconnected??...there is a chance there is something blocking air flow in lint screen/blower housing ..remove the 2 screws under filter remove all back screws remove 4 screws holding blower housing in place ..you then can pull complete housing out back
May 18, 2008 | Roper REX4634KQ Electric Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
110 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
