Question about GE Energy Star WCVH6260F Front Load Washer
It won't drain...
Yesterday, the machine, continued to try and pump water out during the load. This lasted for about 1/2 hour. I unplugged it for fear the pump would burn out, but then the door wouldn't unlock. Finally, after a few hours it unlocked. The clothes were still soaked, and there was water in the drum. What can I do?? Not draining or wringing clothes. I have cleaned the hose out and the rubber seal aroung the tub. Still H20 in the bottom of the tub. GE Adora Front load washer model WHDVH626
  • 706 Answers
From your description, you could have a problem with one of several things.. You can run a few tests to determine the most likely area that is causing your problem ,,, If possible, can you unhook your drain hose from the drain and use a barrel to cycle water into ? (You can stop the washer any time to empty the bucket... Anyway, try running a wash load ( without clothes) and monitor the water flow... when the washer is pumping water out, you should have a fairly high stream flowing into the bucket. Using a bucket will rule out a clog in your house drain line...and provide d irect means to see how well the system pumps.. If the water is only trickling out during the drain process, then you have one of sveral problems.. The pump is clogged or defective, the supply from the drum to the pump is clogged and not allowing the water to be drawn into the pump or the outflow tube from the pump is clogged or crimped. Any of these problems will require you or a service person to gain access to inside the washer and diagnose the problem. I had a similar problem on an LG front loader and it was the pump itself.. One thing to remember is to use HE detergent for these front loaders.. and a very small amount of that.. Hope that helps...
Posted on Aug 15, 2008
Why my AEG F55080vi stops after drain cycle (program beginning) and then it stops and I hear 2 beeps and 2 flash continuously?
Definitely, water drain time-out. Error code i20.
The pressure switch doesn't return to EMPTY (1-2) after two drain phases lasting 120 seconds.
Possible causes:
Drain circuit obstructed/blocked; drain pump
interrupted or jammed (foreign bodies); level
pressure switch blocked on FULL (1-3); hydraulic
circuit of pressure switch obstructed; wiring faulty;
circuit board faulty.
Thanks to your detailed description of failure I conclude that in drain phase (after starts drain pump) leaks water and causing a short circuit. I would thoroughly reviewed drain hydraulic circuit. If is alarm displayed and there is no water inside dishwasher then check heater and anti-interference suppressor.
Dado
Jul 12, 2014 | AEG Dishwashers
Water leaks (drips ) into tub after cycle/spin is complete
You have a bad pressure switch or the small hose connecting to the pressure switch may be bad
If the washer leaks water when is filling only, check the following: 1.Fill hoses
2.The water mixing valve
3.Filling injector ( If your washer uses one )
4.Filling spout
If the washing machine leaks during the wash cycle, check the following:
1.The pump
2.The tub stem & seal
3.Tub to pump hose
4.The drain hose
5.Tub (rusted holes)
6.The drum support bolts
If the washing machine leaks during the spin cycle, check the following:
1.The drain hose
2.The tub cover seal
3.The pump
4.The pump hoses
5.The stem & seal
Feb 10, 2008 | Maytag LAT2300 Top Load Washer
LG WM2140C front load washer overflows during drain cycle
This sound like the water is leaking from the drain pump.
Dec 22, 2012 | Washing Machines
Suds and then f35 error code shortly afterbstarting any wash cycle.
SUDS error = SUDS LOCK (OVERDOSE OF DETERGENT
DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained
and it will try to spin or drain again.
If too much detergent was used:
- Run the unit through a RINSE/SPIN cycle.
- Run a NORMAL cycle without adding any detergent.
This should clear the unit of the excess detergent.
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check wire harness connections to the drain pump, pressure switch, and Central Control Unit (CCU).
4. Check/clean drain pump filter of foreign objects.
5. Plug in washer or reconnect power.
6. Check drain pump.
7. Check the pressure switch.
8. Verify CCU operation by running a Diagnostic Test or any cycle.
F35 error = ANALOG PRESSURE SENSOR FAILURE
If this failure is displayed, there is any malfunction of the steamer component detected by the Steamer Electronic Board.
1. Check if pressure hose is fi xed correctly.
2. Check if the airtrap is not blocked.
3. Check if the hose is not blocked.
Dec 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Our whirlpool sport will not drain, 5d code has appeared. what can we do
SUDS LOCK (OVERDOSE OF DETERGENT DETECTED DURING THE WASH CYCLE)
If suds are detected continuously by the pressure switch during the drain or spin phases, the washer will fill 4 liters of water and during 5 minutes the unit will rest without tumbling, the water will be drained and it will try to spin or drain again.
Possible Causes/Procedure
• If too much detergent was used:
- Run a NORMAL cycle without adding any detergent,
• This should clear the unit of the excess detergent.
Nov 30, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code Sd (or 5d)
It means Suds Lock(Overdose of Detergent Detected During The Wash Cycle).If suds are detected continuously by the pressure switch during the drain or spin phases,the washer will fill 4 litres of water and during 5 minutes the unit will rest without tumbling,the water will be drained and it will try to spin or drain again.
– Run the unit through a Rinse/Spin cycle.
– Run a Normal cycle without adding any detergent.
3. Check wire harness connections to the drain pump,pressure switch and Central Control Unit(CCU).
8. Verify CCU operation by running a Diagnostic Test.
Apr 11, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
Whirlpool duet pump stays on
try running the load with out soap
you could be oversoaping each and everytime
these machines have sud sensors and will continue to run the pump as long as suds remain in the sump
watch the load as it goes through the wash cycle
if you see suds and did not add soap then there you go
these machines do not need anything more than 1 tblspoon per load
1/8 the water 1/8 the soap
Oct 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore 48102 Front-Loading Washer
I have had the same problem. I unplug the washer for a couple of hours and then run the rinse/spin cycle and it takes care of the problem. I've had my machine for 2 1/2 years and this problem started exactly after the first year ended. The first time it happened, I called for repair but before the repair guys came I tried this and so far it has worked. It happens about every few months.iIt's a pain but so far no repair guy bill, yet.
Oct 06, 2007 | Washing Machines
It won't drain...
rush, read this post and post back...Catrvier http://www.fixya.com/support/t136352-washer_stop
Mar 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE Energy Star WCVH6260F Front Load Washer Logo
196 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
