Help!! No cooling, just fan!!!
I HAVE A LESS THAN 2 YEARS OLD AIR CONDITIONING (MODEL#FA4BNF036) THAT HAS STOPPED COOLING. I SEE NO LEAK AND HAS BRAND NEW FILTER. IT'S A SINGLE UNIT FOR CONDOMINIUMS. i THINK THAT THERE SHOULD BE A WARRANTY STILL, BUT TO GET TO SERVICE IS BEING A PAIN. CAN ANYONE PLS GIVE ME AN IDEA HOW TO GET IT WORKING AGAIN?
tHANK YOU
Comment by CAAAPEREIRA, posted on May 08, 2008 Yes, I can hear the fans running, but I will have to open the panels to verify everything else. The thermostat shows cools and I have programmed it for the temperature to hit 70F. But the temperature does not go below 79F. Does these kind air conditioning have internal fuse? My apartment lights blinked yesterday and I notice that after that the air conditioning stopped working properly. I pressed the "Reset" button on the digital Thermostat which displays "cooling" but it acutally does not! I HAVE A LESS THAN 2 YEARS OLD AIR CONDITIONING (MODEL#FA4BNF036) THAT HAS STOPPED COOLING. I SEE NO LEAK AND HAS BRAND NEW FILTER. IT'S A SINGLE UNIT FOR CONDOMINIUMS. i THINK THAT THERE SHOULD BE A WARRANTY STILL, BUT TO GET TO SERVICE IS BEING A PAIN. CAN ANYONE PLS GIVE ME AN IDEA HOW TO GET IT WORKING AGAIN?
tHANK YOU
Comment by CAAAPEREIRA, posted on May 08, 2008 Yes, I can hear the fans running, but I will have to open the panels to verify everything else. The thermostat shows cools and I have programmed it for the temperature to hit 70F. But the temperature does not go below 79F. Does these kind air conditioning have internal fuse? My apartment lights blinked yesterday and I notice that after that the air conditioning stopped working properly. I pressed the "Reset" button on the digital Thermostat which displays "cooling" but it acutally does not! My problem is that the thermostat is set to 69, but the house is still 86 or 87 degrees!!! Cool air blows from the vents but the house is not cooling off. I have a Trane.
  • 182 Answers
Sounds like the unit is low on charge.you will need a pro to check it
Posted on Aug 05, 2008
My cooling fan on my 2002 Lincoln ls 3.9 is hydraulic and I believe it's going out.. Is it a good idea to replace it with an electric cooling fan plyz help
I can only say that if this system uses the old style oil filled fan clutch that has been used for over 50 years, the method of testing is to measure fan shaft rpm against engine rpm. When the air temp is cold, the fan clutch is suppose to slip to prevent over cooling the engine. If the fluid runs out from a leak, the blade clutch can no longer lock and you lose air flow.
The electric fan is an option, but many cars have both systems because there is just too much heat to get rid of. Room is always a problem. Some electric fans have 2 speeds, largely dependent on getting sensors to work at 2 different temperatures.
Aug 25, 2015 | Lincoln Cars & Trucks
Air Conditioning broken - fan still works
Probably a control board failure. If the modes don't work and the fan auto/on works, I'd say the circuit board has failed. Does the fan turn on when cool is selected? If not, 99% sure it's the board. If it does, it's probably a compressor component issue. Window units are considered throw aways.
Aug 31, 2017 | GE Heating & Cooling
I have a blizard split model 10.5 years old in a caravan. model sa101 the air feels cooler but seems to have no noticable difference in actual temperture and compressor seems to run continuously ...
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
Jan 31, 2011 | Electrolux Heating & Cooling
Fan works, air conditioning does not. Try resetting the power (in the proper sequence - outdoor unit followed by indoor unit). Air conditioning came on briefly (less than a minute) than stopped, leaving...
Without seeing the unit,
1 - the condenser fan (which is in the outdoor unit) could be blown. This would cause the unit to go off on high head pressure.
2 - it could be low on refrigerant, which makes it do nothing but blow room temperature air around. The unit would go off on low pressure
3 - the filter is dirty, blocking the cooling
4 - the compressor could be shorted, or a corroded wire somewhere that feeds the contactor
Mr. Slim Ductless Splits are the best on the market and should only be repaired by a trained technician.
Hope this helps.
May 28, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Suddenly stopped cooling
ck for ice in back of freezer / it sounds like the defrost heater has failed of a evap fan. ice may be blocking coil or the fann is not moving the air .. ****
Jan 18, 2010 | Refrigerators
GE Eterna stopped cooling. Not even 2 years old!
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Check the fans especially the condenser fan. The noise if you listen close is probably the klixon cycling because the compressor is hot. If the condenser is plugged (real dirty), sign of a clean house, and/or the condenser fan is bad you will not get cooling. If the condenser fans operating properly and the fans inside the freezer and refrigerator are operating that would indicate serious problems assuming the compressor is operating.
Good Luck,
Gilshultz
Dec 01, 2009 | GE Refrigerators
After switching from heating to cooling - air won't come on
It sounds like the fan relay in the stat itself is not closing when you make the switch over. If you have had the stat for less then 5 years it is covered. Honeywell has a full 5 year warranty on their focus pro stats, and would replace it free of charge.
Apr 02, 2009 | Honeywell Focus 6300B 5-2 Days...
you probably have a defective contactor or start capacitor on condensing unit. if you pretty handy with wiring go to the condensing section open the panel. you should see a contactor (it's the little black piece with all the wires) check the condition of it. next to it is a capacitor and by the problem that you describe it could be that. check it if it looks bloated there's your problem just go an get an combination capacitor and wire up. (make sure the power to unit is off first. any other questions email me @ hvac.tech7872pr@gmail.com
May 09, 2008 | Carrier 38BRC048 Air Conditioner
NO COOLING
Hmm.this will require a few questions for you to answer. first does all the fans run, condenser fan??? indoor blower? and does the compressor humms, when you turn it on?
May 08, 2008 | Carrier 38BRC048 Air Conditioner
Heating & Cooling Logo
435 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
