Hi my dvd player sometimes says no disc when a disc has just been put you have to keep opening and shuting the tray and then sometimes it works please help
Posted on Aug 04, 2008
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
1. Turn the power on and remove the disc on the tray.
2. To put the DVD player into version up mode, press [9], [8], [7], [6], and [SEARCH MODE] buttons on the remote control unit in that order. The tray will open automatically.
The DVD player can also enter the version up mode with the tray open.
3. Load the disc for version up.
4. The DVD player enters the F/W version up mode automatically. If you enter the F/W for different models, "Disc Error" will appear on the screen, then the tray will open automatically.
5. After programming is finished, the tray opens automatically.
At this time, no button is available.
6. Remove the disc on the tray.
How to Eject Manually
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
on Jan 19, 2016 | Denon DVD-1740 DVD Player
Hi there, My sony rdr hx510 will not open and is making a grinding rotating sound. Baby girl either put 1 one or 2 discs in incorrectly. Can you advise on how I can get it opened and renove the discs.
Must used a philip screw driver take out all the screws to the dvd player.Must take the DVD player aparts.Take aparts out the dvd player guard shield to the dvd drive to take out the dvd dic or dics out.Don't push the open button any more,the disc or discs is jamming ur dvd door tray.Will burn out ur disc tray motor,if u keep trying push the open button,trying opening it that way.
Sep 24, 2010 | Sony RDR-HX520 DVD Recorder
My DVD player won't play the disc all of a sudden. It plays the federal warning and then stops. I also cannot open the tray to get my DVD out. Help.
my dvd player is automatically shuting down, when i operate this player it did not operate, at the end i was upset
Sep 24, 2010 | Philips DVD 622 DVD Player
Dvd tray will not open or play
The reason your player keeps reading a disc and do not play is because the the disc tray is not sitting the disc properly on the lens.
The disc tray is faulty, the mechanism that controls the opening and closing of the tray is damaged and needs repair.
To fix this, you have to get the appropriate screwdriver, open the cover of the player.
You will see a mechanism by the opening of the tray that controls the disc tray.
Get a replacement mechanism and change it. Mostly the rubber slacks and does not control the tray properly.
Changing the mechanism will solve the problem.
Take care
Jun 15, 2010 | RCA DRC8295 DVD Recorder/VCR Combo
My Akai dvd player shows "no disc" after loading a dvd. The tray sometimes makes a grinding noise when opening and closing as well.
The reason the player is not reading the disc and showing no disc is either because the disc is not sitting properly on the lens from the disc tray, or the lens is weak or the lens is dirty.
To test if it is the disc tray, open the cover of the player with the appropriate screwdriver, place a disc directly on the tray and apply a little pressure on the tray, if it reads the disc, then it is the tray.
All you have to do is to adjust the disc tray and screw it tightly.
To test if the lens is weak, try several DVD disc on it,and test them also on another tested ok player, if it does not work on your player and works on other players, then the lens is weak.
to fix this, get the appropriate screwdriver, open the cover and unscrew the disc tray.
You will gain access to the lens, carefully disconnect the lens and replace it with a new lens. then it will be ok.
To test if it is just that the lens is dirty, clean the lens with a lens cleaner and test a DVD to see if it will work.
Take care.
Jun 14, 2010 | Akai DVPS760 DVD Player
LG RH1757 (80 GB) DVD Recorder / HDD Recorder Drawer keeps opening Drawer keeps opening and closing and won't read discs! Rassie from Cape Town South Africa
Could be a timing issue with the tray mechanism - possible that somebody has given the tray "a shove" to make it close instead of using the open/close button and has put the timing out.or a worn tray loading belt
Mar 16, 2010 | LG RH177 DVD Recorder/HDD Recorder
The open/close tray works sometimes only
seems you dvd player is getting problems due to dust formation. clean your dvd lens and parts inside using dvd cleaner disc. that would really help you.
Jun 05, 2009 | Philips DVD724 DVD Player
DVD disc tray keeps popping out
I had mine for 2 years and within the first 12 months the tray would not always pop out when I wanted it to. Then finally the machine would not recognise the disc type. Its in getting fixed but although the dvd drive and associated pcb have been replaced the guy says it still can't recognise the dvd disc type. Still trying to work it out.
Mar 25, 2009 | LG DVB418 DVD Player
Sanyo 6100 dvd player-disc tray automatically opens whenever power is on.
you should try inspecting & servicing the tray transport mech first and then the tray sense swt.
Dec 08, 2006 | Sanyo DVW-6100 DVD Player/VCR
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
