Question about Samsung TXM3296HF 32" TV
My television makes a ringing noise.
My television makes a terrible ringing noise. I can turn it on and it will be fine and then it starts. It starts out very faintly and then just gradually increases until it is unbearable. I mute the tv and it still does it so I don't think it has anything to do with the speakers. If you turn it off and then back on it does it immediately when you turn it back on. If you turn it off for a longer period(hour or so)it will run awhile before starting again. It has done this in the past, but usually would only last a few days and then it would go away. Now it has done it for a month or more. Any ideas?
  • pvitali19 Nov 29, 2008
    I have the same problem. Has anyone had an answer for it?
  • 168 Answers
SOURCE: High Pitch Sound From Samsung TXN3071WHF 30" TV
I think its the flyback and its starting to leak. this is a component responsible for the high voltage of your tv set. always observe safety in dealing with this. Have it check by a qualified technician. Good luck!
Posted on Feb 26, 2007
SOURCE: Weird noise over everything
The problem is not with the Audio. It is coming from the capacitators on the main PCB. A tech opened up our set and reproduced the noise by slightly moving the capaicators (with a stick of some sort). Instantly, the high-pitch ring started. This problem has since came back on thew new PCB and seems problematic with the type of TV/Samsung.
Posted on Nov 26, 2007
  • 3 Answers
SOURCE: Making Loud noises
sounds like the yoke on us. yoke is what makes that nosie.
Posted on Sep 13, 2008
  • 108 Answers
SOURCE: Our Samsung HL-P4663W DLP is makes noise and shuts off
It is the color wheel, inside the light engine. The bearings get dirty and makes it harder for the wheel to spin causing that whin.
Posted on Jan 06, 2009
SOURCE: Samsung Model HLR4667WAX/XAA is making a buzzing sound
This TV is horrible. I have the same one and not even a year replaced the light bulb twice. Very disappointing for a Samsung.
Posted on Sep 22, 2009
Dropped a ring into the dryer lint hold where you would clean out the lint and when you turn it on it makes a terrible noise, how can I get the ring out?
You may wind up tearing your dryer apart to retrieve the ring. If so, go to and enter the dryer model. You will be presented with a list of common replacement parts and may be able to view a generic video for your brand showing disassembly and identification of major parts.
Nov 08, 2016 | Dryers
RCA DLP HDTV making terrible noise
your color weel is going bad and needs to be replaced
May 19, 2010 | RCA HD52W59 HDTV Projection Television
Terribly load noise when washing
could need a new bearing
Jun 10, 2009 | Washing Machines
Dryer doesn;t spin
Sounds like the belt has broken. The terrible noise was probably the belt slipping until it gained traction.
May 17, 2009 | Dryers
Philips tv model id: 19pfl5422d/27 terrible loud sound
The issue is 4 1000uF X 10V on the main board under the shield close to the connector that from the power board. you will see them because they will be FAT( exploded)
Feb 28, 2009 | Televison & Video
Starter Grinding Noise, Stays In
you probably have a bent flywheel
Feb 12, 2009 | 1981 Ford F 150
Terrible noise when agitating
Your transmission has gone out. The reason the spin cycle works is because the transmission spins two different ways and you agitate way stripped the gear. Some places rebuild them. Try with your local stores maybe they can rebuild it or get you a good used one. If not you can order a new one from
Nov 12, 2008 | Kenmore 24032\24036 Top Load Washer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Samsung TXM3296HF 32" TV Logo
561 people viewed this question
Jerry Greenberg
Jerry Greenberg
