Question about HP OfficeJet 4215 All-In-One InkJet Printer
Print spooler when installing HP OfficeJet 4215 All-In-One
I am attempting to install the printer on my PC with Windows XP. All of the software is installed, but it won't allow me to proceed because it says the print spooler is stopped. How do I fix this? Thanks!
  • epmink Aug 06, 2008
    Thanks for your time. When I do that it says, "Error 1068: The dependency service or group failed to start." Any advice?
  • 1,601 Answers
Go to control panel, administrative tools, services, and turn it on.. hit start and set it to automatic.
Posted on Aug 04, 2008
  • Thomas Christopher
    Thomas Christopher Aug 06, 2008
    1. Click Start, and then click Help and Support. 2. Under Pick a Task, click Use Tools to view your computer information and diagnose problems. 3. In the Tools area, click System Configuration Utility. 4. In the right pane, click Open System Configuration Utility. This opens the System Configuration Utility. 5. Click the Services tab. 6. Make sure all the following services are turned on. To turn on a service, click to select the check box.
    � Application Layer Gateway Service
    � Network Connections
    � Network Location Awareness (NLA)
    � Plug and Play
    � Remote Access Auto Connection Manager
    � Remote Access Connection Manager
    � Remote Procedure Call (RPC)
    � Telephony
    � LexBce Server (if you have it)
    7. Click OK, and then click Restart.
    If the above doesn't fix the problem, try the following:
    • Open the Start menu
    • Go to Accessories
    • Right Click on Command Prompt and choose "Run as administrator"
    • After the Command Prompt window opens type the following
    • sfc /scannow
    • This will scan your system files for problems, report on what it finds, and will instruct you to reboot if repairs need to be made
    This solution worked for me when a friend told me that all her network adapters were showing up under Device Manager but not under Network Connections.
How to install my printer?
Can you confirm that it's an HP OfficeJet 4215 printer?
What OS and type of device (computer, phone, Mac, PC, Windows version, ...) are you trying to install it on?
How are you trying to install the printer?
How are you connecting the printer to your computer? (USB, network, Bluetooth, Ethernet, or ?)
Have you tried to install it, and if so, what happened? Exactly what error messages did you get?
Here is a link to the drivers for the HP OfficeJet 4215 all-in-one if that helps you get what you need without answering all the questions above: Drivers Software
Jul 28, 2014 | HP OfficeJet 4215 All-In-One InkJet...
My officejet 6310 all in one printer has nt been working for past several days the report states that spooler has not running
Hello Richard! Welcome to FixYa!
If the printer report states that spooler has not running then there are few steps which fix that problem. Follow the given steps carefully:-
Click Start of your PC and open the Run Command and type the command as "Services.msc"
Then scroll down to print spooler services, Right Click and and select Stop
Now delete all your Print Jobs which are in pending status
Now go to C:\WINDOWS\system32\spool\PRINTERSand delete all the files or folders listed there, Now you can try to return to the Services.msc and start the print spooler service to see if this has been fix your problem
Be sure to stop the print spooler services before proceeding. First you must remove the corrupt drivers manually from the windows registry.
Delete your printer driver, now try to enable print spooler service again and Uninstall the Printer Software installed in the PC, Now again install the printer driver and software.Your problem will be solved.
I hope this solution helps you and you have a clear picture in your mind. Let me know if you have any confusion.
Sir, Your Rating as Five Stars and Words of appreciation will be esteemed.
Thank you for taking my service
Concerned: Muhammad UzairTeam : FixYa
Dec 16, 2011 | HP Officejet Pro L7590 All-in-One InkJet...
Can't install driver
Hi and Hello
XP Driver HP-OfficeJet-4215
Not sure what you need by saying can’t install driver I think you need to gave more info, but I will try to think way, ok if you got a new printer and you have the Cd driver for it,,, if you trying to install driver on to your pc windows Xp the Cd must be xp driver if the windows you got is Vista or windows 7 then it a different drivers so it will not work, other thing is your CD ok?
And trying to get Vista or Windows7 Driver is a job to get hold of them. Xp driver mostly can get easily enough.
Ok next what I will do I will put a Driver install on my website for you can download it from the link here just click on this link and it will download for you make sure to save it on to your desk-top so you can find it ones you have downloaded the driver just double click on it and it will run the driver for you and follow the instructions.
Click on this link _ENU.exe
Please come back to say Thanks
All The Best: Pineworks
Jan 28, 2010 | HP OfficeJet 4215 All-In-One InkJet...
HP officejet 4215 to print instead of fax
if you are using windows then go to control panel and go to printers(windows vista) or printers and faxes (windows xp) and then select the correct printer icon out of the two icons.. there will be two icons (for eg . officejet 4215 and officejet 4215 fax.. ) choose the one which doesnt says fax .
Oct 20, 2009 | HP OfficeJet 4215 All-In-One InkJet...
The print spooler service is not running.
Reinstall the printer drivers will shore it up quickly the spooler has to do with the printer so do that and you should be fine.
Apr 23, 2009 | HP OfficeJet 4215 All-In-One InkJet...
HP Officejet 4215 will not print
  • Unplug the printer cable from the computer.
  • Unistall the printer drivers from Device manager and also unistall the all the printer appications
  • restart the computer
  • try to download drivers from the website
  • after installing drivers and software it will ask you to connect the printer.
  • then you can connect the printer and and try to Print the test page.
Mar 29, 2009 | HP OfficeJet 4215 All-In-One InkJet...
I lost the Cd to instal my hp printer to my computer
Here is a link for the 4215. Links are on this page for software downloads, manuals, etc.
4215 Support Page
Nov 17, 2008 | HP OfficeJet 4215 All-In-One InkJet...
HP photosmart all-in-one 4100 series
The issue is with the print spooler. If the operating system is XP then click on start >> run >> type services.msc >> the services window opens, now locate the print spooler and right click on it and select stop(if it is started) then again right click on it and then click on start. Now the spooler service will start, then try installing the all-in-one software.
Aug 02, 2008 | HP OfficeJet 4255 All-In-One InkJet...
Hp officejet 4215
Hello sonyamac,
You can download the software directly from the manufacturer and install it without the CD. Go to, find and click Software & Driver Downloads, select Download drivers and software, type officejet 4215 in the box and press enter. Select which officejet matches yours: 4215, 4215v or 4215xi (you can find that info on a label attached around your printer. Sometimes the model is only described as CXXXXA format. If that is all you got, go back to the prior page and type that model instead of officejet 4215. You should reach a page where you select which operating system you are using, click on it and on the next page you can select which software you want to download. After saving your download, just open the program, follow the installation instructions and you should be ready to print in no time. Hope this helps.
Dec 26, 2007 | HP Officejet 4215 All-in-One Color Photo...
Computer doesnt recoginze port
Hi, It might be a good idea to completely uninstall the printer from your computer altogether, also unplug it and then restart your PC. Then shut it back down and then plug the printer back in and restart. Are you using Windows XP if so the PC should see the printer when it boots and will require instalation. Please note if your printer originally required you to first install the software before attaching the printer to the PC then you should follow the original instalation requirements. Let me know how you go.
Nov 07, 2007 | HP OfficeJet 4215 All-In-One InkJet...
HP OfficeJet 4215 All-In-One InkJet Printer Logo
67 people viewed this question
Ben Johnson
