Question about Samsung SCX-6320F All-In-One Laser Printer
Locked scanner i need help to fix the error.
  • 77 Answers
Check the lock of the scanner( fixed at the down side of the scanner) . there is a green colour lock. release it.
Posted on Feb 10, 2009
Where is the "scanner lock switch" located on a Canon Pixma MP980 printer? I cannot seem to locate the switch "under the hood" so I need assistance.
The scanner lock on the MP980 is on left hand side of the scanner unit. It's closer to the hinge of the document cover and almost centered between the scanner glass and the edge of the printer. If you lifted the entire scanner unit, you won't see the switch. You should be able to push the switch towards the open lock symbol with your finger or thumb. The Getting Started guide has a pretty good picture of where the switch is in Step One. The guide is available on the product page, http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp980#BrochuresAndManuals , in the Brochures & Manuals section. The current link to the Getting Started Guide is http://gdlp01.c-wss.com/gds/2/0300001552/01/MP980_GS_EN-US_V3.pdf . After moving the switch, turn off the all-in-one. Then unplug the power cord to clear the error message from the printer's memory. After a few minutes, plug the power cord back in and turn on the printer.
If the error persists and the scanner is unlocked, the scanner mechanism may be damaged. If that's the case, your MP980 needs service. If the unit is under warranty, contact Canon. (If it isn't under warranty, you'll need to decide if the unit is worth the shipping and handling fees and the minimum $50 or so charge just to determine the problem at a service center. (That fee will be applied to the cost of fixing the printer, if you decide to have the technician continue to work on the unit.)
I hope this helps.
Sep 21, 2015 | Canon PIXMA MP980 All-In-One InkJet...
Scanner carriage error
Look in the book for the scanner lock. It will still be locked for transport.
Jan 24, 2014 | Ricoh Aficio SP C240SF
Printer ar168D Error L1-00
The L1-00\r\n error indicates the scanner didn't return to it's home position or is locked and can't leave the home position. There is a lock switch (designed to lock scanner into place for safe transport) located to the left of the copier and just under the scanner. It's a plastic dial that needs to be turned to the "unlock" position. Once done, your problem should be fixed.
Nov 12, 2009 | Sharp AR-168D Copier
Error message while switching on the scanner
sigo con el problema del escaner s2w 6400ut bloqueado me dice que siga la guia rapida para su desbloqueo
Apr 01, 2009 | BenQ Scan to Web 6400UT Flatbed Scanner
Sharps AL 1530CS flashing L service code and shuts down
You didn't mention the number or code or L code.
If its L1-00 its just only the scanner, it means the scanner is locked.
There is a crystal lock under the scanner and on the top of the exit tray. just rotate the lock, makes sure that the front of the lock is on the direction of the scanner(to the right).
Hope it helps...
Feb 23, 2009 | Sharp AL-1530CS All-In-One Laser Printer
Error 5020 scanner lock switch will not turn off.I am using printer pixma mp810
Does anyone know how to fix error 5020 release the scanner lock switch and turn the power off & on.The Cannon MP810 Printer. Please Help!Thanks
Dec 07, 2008 | Office Equipment & Supplies
MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Sep 10, 2008 | Canon MP830 All-In-One Printer
SCX-6320F All-In-One... Problem>>>> locked scanner error
There is a green button just on the top of the paper exit, you just need to pull it, and to shut down the multifunctional and then turn it on again. I don´t know if you already did this, hope this can help you.
Aug 04, 2008 | Samsung SCX-6320F All-In-One Laser Printer
Unlock
Most scanners shipped have a lock on them to prevent the top from opening up and damaging the glass. This is a screw type mabey other but a penny fits in mine. This may not be the case for you but look in your manual to find the unlock device.
This will also in some scanners prevent the stepper motor from moving in transit . The stepper motor is the device thats makes the bar slide up and down to scan the page.
Hope this helped some.
Kevin
Dec 30, 2007 | Visioneer OneTouch 5800 Flatbed Scanner
Error
uninstall the software unplug the usb cable. installt he software plug in the cable see if that fixes it.
Oct 16, 2007 | Canon CanoScan 3000ex Flatbed Scanner
Samsung SCX-6320F All-In-One Laser Printer Logo
216 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
