Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Paint had gone on surrounding the clock area
Hi
when i was cleaning with some liquid my stove top (surrounding the clock area ) paint had gone. how can i repaint on that area. can i get any spray paint in stores
thank you very much
priya
    Problem Solver:
  • 9 Answers
You can get spray paint in stores. Here is the kicker. Generally speaking Ovens and stoves have a baked on finnish. The problem is going to be getting a (And this is the key words) "High Heat" paint that matches the color of your stove. Most paint stores have "High Heat" in black red or silver to paint Bar B Q's with. However most do not have a multitude of colors that kitchen appliances come in. If your stove is one of those colors then problem solved go to the local paint store and pick it up. If not try looking at automotive paint stores for the similar color. In an automotive store you will look in the isle for Engine paint. If you can not find a paint that matches the color in High Heat, you could try an appliance epoxy. The thing is that is usually used on refridgerators, washers, dryers etc and not recomended for stoves. Try a small spot and monitor it. If it begins to peel my recomendation would be replace the stove as coatings beyond that will start to become more pricey than a new range.
Posted on Jan 20, 2009
SOURCE:
Can I get paint to put on top of my stove as it’s burned off.
Hello, Clara -
The "paint" on stoves tends to be a baked on enamel, much like the multiple layers of sprayed on and heat cured "paint" for automobiles.
You will need a heat resistant paint for your stove, for one thing.
Read the information and comments here:
https://www.houzz.com/discussions/2412570/painting-my-range-bad-idea
And, read this from home renovation expert Bob Vila:
https://www.bobvila.com/articles/painting-appliances/
Plus, read the comments here:
https://www.finishing.com/268/45.shtml
This article provides step-by-step instructions in painting a stove:
http://homeguides.sfgate.com/paint-kitchen-stove-24787.html
Plus, there are links to related articles.
If, after reading all that information, you may choose it is a project you do not want to tackle. You can look for a business in your area which does kitchen appliance refinishing.
Best wishes.
May 31, 2018 | Kitchen Ranges
Oven will not heat past 195 degrees
Check and see if you have blown a fuse which is usually in the top of the stove in the area of the clock if you have one. You usually can get in from the back of the stove at the top.
Jan 03, 2015 | Maytag Gemini 30" Self-Cleaning...
I have some chips on a Findlay cookstoves enamel.It is old and the enamel is light green.Any ideas where I may find something to touch it up?
There are several brand of touch-up enamel paint for appliances. Krylon for example, it's carried by a wide variety of retailers such as Home Depot, K-Mart, Sears and Walmart.
You can also get it at store that specialize in paint like Sherwin Williams. They might also be able to give you the best match to your color. If not you can try appliance stores. They may be able to give you a good match. The only other option is to match it yourself. The best way to to that is to get some color card examples from a paint store or hardware like Home Depot and find the best match. Now get a list of the colors that they use to mix it. Ask if you can get a very small amount of the colors used in the mix and using trial and error mix it yourself.
You can also try mixing it to get your color using enamel auto touch-up paint.
There really is no source for old appliance touch-up paint so it will never be perfect but with a little trial and error you can get pretty close.
Hope this helps you out.
Prep before painting:
  • Sand the damaged area lightly with fine-grit sandpaper. Roughen the area to be painted and remove any rust, but avoid sanding the surrounding surface.
  • Clean the area thoroughly with a rag dampened with paint thinner. Let dry.
  • Paint over scratches with appliance touch-up paint, using the bottle's applicator brush or another fine-tip paintbrush. Let dry overnight.
There will be issues with areas that are exposed to high heat so be prepared to repeat when necessary.
Nov 13, 2009 | Stoves Kitchen Ranges
How to remove scraches from ceran top
Clean the stove top thoroughly. I use oven cleaner to clean my stovetop. It works wonders. Be very careful not to get the cleaner on any part that is not ceramic finish.
Then, lightly spray Appliance Paint on the scratched area. You can purchase this paint at any hardware or Home Improvement store. It comes in several of the standard appliance colors.
If you need to use more than one coat, wait several hours between coats. Better to use several light coats than one heavy coat. A single heavy coat will tend to chip.
Oct 08, 2009 | Maytag MER5775Q Electric Kitchen Range
3 of 4 knobs do not compress to turn on gas
You must replace those controls. Cleaning or loosening them up would be temporary at best and the next time they stick it could be in the open position. Safety first...Eric
Jun 14, 2009 | Jenn-Air 30 in. CCG2423 Gas Cooktop
Stove top elements f1 error code
Hi. you can try to reset the electronic oven control by unplugging the unit for 3 mins. if the problem still exist, you will have to replace the clock/control(electronic range control).
please rate and god bless:)
Apr 02, 2009 | Kenmore 24032\24036 Top Load Washer
Painting The Frame
Your going to have to sand prime sand prime sand paint. Just increase the grit number each time, there has to be some adhesion
Nov 20, 2008 | 2006 Honda CBF 600 ABS
F-o-on face of stove................keeps beeping
Your touch pad (electronic -control ) Replace it and your problem is gone.My opinion is that water (sponge cleaned) has found its way through the touch pad and caused this.Tip: clean clock area with a damp towel only. Please rate This !
Jul 06, 2008 | Maytag Kitchen Ranges
Cleaning area around burners
Try regular oven cleaner (not the overnight kind) . This will work if there are no aluminum or painted parts. Don't do this if the instruction manuel says not to.
Jun 12, 2008 | Jenn-Air JGC9430ADS Gas Cooktop
Whirlpool 465 oven
THE SIDE PANELS ARE A BASIC PAINT LIKE YOU FIND ON AUTOMOBILES, BUT MOST OF THE COOKTOP AND SOME BACKSPLASHES ARE MADE OF PORCELAIN. IF YOU ARE GOING TO PAINT THE SIDE PANELS, BE SURE TO STRIP ALL OF THE KITCHEN GREASE OFF THE PANEL SURFACES. BEST TO USE AMMONIA WATER TO CUT THE GREASE.
IT IS NOT ADVISABLE TO PAINT THE COOKTOP OR BACKSPLASH AREAS.
Apr 09, 2008 | Ovens
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
123 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Bruce Denton
Steve Allison
Steve Allison
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
