Connecting pc to tv
Get no signal using 15 pin connection to rgb(pc) on tv
how do i set up pc
thank you lg 42hd/1080p and sony vaio notebook with model number vgn-fs780w. what i need to do in order for pc to t v to work. do not know what steps i need to take to correct this issue. thanks
I have a addition to this question. What cord would be necessary to hook up the Toshiba Satellite M45 (laptop) to a Tv?
Posted on Sep 13, 2008
  • 4 Answers
You need to toggle to the external display by holding the Fn key + F7 or F8. Look at your keyboard and you'll see little TV screen icons. You can also go to start/control panel/display settings or right click on your desktop and access the display properties.
There is usually two tabs with two displays and the active current display in from. Click the other and adjust the resolution and type using the drop down menus.
You might need to consult your TV manual as well to make sure your in the right input mode.
CR
Posted on Aug 04, 2008
SOURCE:
Ibm thinkpad wont connect to LG TV
Lower the screen resolution to 720 dpi.
Another issue is the reference to RGB. Is it the 3 cable (YPBPR) or the standard 15 pin VGA? You may need a converter.
Oct 08, 2012 | IBM ThinkPad T40p 2373 Notebook
Dear Sir, We have Toshiba REGZA 24PB1E LCD TV. I want to test our Gigabyte PC GA-G41M-Combo MB with VGA port (15 Pin Connector) Pls let us know how to connect & get the solution ASAP. For...
Hello
With either the PC IN or HDMI connection, you can watch
your computer's display on the TV and hear the sound from the
TV's speakers.
When connecting a PC to the PC IN terminal on the TV, use an
analog RGB (15-pin) computer cable and a PC audio cable.
To use a PC, set the monitor output resolution on the PC
before connecting it to the TV. The following signals can be
displayed:
Format Resolution V. Frequency
VGA 640 × 480 60Hz
SVGA 800 × 600 60Hz
XGA 1024 × 768 60Hz
Other formats or non-standard signals will not be displayed
correctly.
Note:
The PC audio input terminals on the TV are shared with the
HDMI-1 analog audio input terminals
Some PC models cannot be connected to this TV.
OK.
Mar 24, 2011 | Toshiba REGZA 47HL167 TV
How do I connect a PC to a LG50PG20 50" HDTV Plama?
You need a VGA cable (15 pin) connected from PC (monitor out) to the PC input on the HDTV (15 pin) this is for the video. For the audio, connect from PC to HDTV, audio cable, either 3.5mm from earphone out on PC to HDTV 3.5mm audio input (next to PC VGA input) and also be sure to set PC screen resolution to compatible output for HDTV like 1024 X 768 or 600 x 800 etc.
Select the PC input on the HDTV using TV remote.
Hope this helps.
Mar 06, 2011 | LG 50PG20 50 in. Plasma HDTV
Trying to hook my home PC into my LG TV gets me the message Invalid Format, what can I do to get the signal or can i use this tv for my monitor with a dell PC
Connect VGA (D-sub 15 pin) cable from PC to TV (RGB PC) input jack. Connect audio cable from PC to TV. Set screen resolution on PC to be compatible with TV, such as 800 X 600 or 1024 X 768 etc. Select on the TV, the PC INPUT using the TV remote when ready to use as monitor.
Under PICTURE on the TV select SCREEN (RGB-PC). You can AUTO-CONFIG or you can set resolution manually to the same you set PC to. Other adjustments can be done here as well to get optimum picture on TV from PC.
Mar 01, 2011 | LG 26LG30 26 in. LCD TV
TV will not work when connected to laptop with av cable
moz-screenshot.jpgmoz-screenshot-1.jpgmoz-screenshot-2.jpg This information is from the owners manual for your model Sony (PCG-GRZ610) PC Notebook computer found on page (57) has a diagram and procedure for making the correct connections. You must make sure you have the correct connection cables and have set both the television and computer for external signal output source (notebook).External signal input source (television). The cable connection is listed below and follow the web page link to see the correct procedure for getting the laptop computer and the television working together. This procedure is explained in the notebooks owners manual on pages (112) (113) (114) you will also need to look in the televisions owners manual to see the procedure for switching the input source to external, so it can see the computer's signal. The owner manual copy is listed as the user's guide. You will also find customer service available on this web page. They will be able to help you with any problems you might be having with the set-up between the computer and television not explained clearly to you in the owners manuals of the laptop and television. I hope this information helps you solve the problem of making the connection between your laptop and television. Thank you for using FixYa and have a nice day! http://esupport.sony.com/US/perl/model-documents.pl?mdl=PCGGRZ610
May 07, 2009 | Sony VAIO GRZ610 Notebook
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
LG 17'' LCD Monitor VGA 15 pin connector pin diagram
pin no 1 - Red colour signal (Red colour wire)
pin no 2 - Green colour signal (Green colour wire)
pin no 3 - Blue colour signal (Blue colour wire)
4&5 Not connected
pin no 6&7&8 are (Grounds)RGB Returns
9&10 NC
pin 13 Hohizontal sync signal
pin no 14 vertical sync signal
Not nessasry other pins
Nov 17, 2008 | LG Studioworks 700S 17" CRT Monitor
Using TV as computer monitor
Same problem!!! Inspiron E1505 connected to a year old LG 47" 1080p lcd. My rgb used to work fine, plug and play with my pc. No luck with my laptop though. I've tried setting up duel monitors, updating all(atleast I think all) of my drivers, and rechecking all connections!! Please Help.
May 06, 2008 | Televison & Video
Sony pfm42x1 colour problem
Check the settings in the menu and make sure you have the input properly set to RGB and not color difference settings (Y, RY, BY).
Apr 22, 2008 | Sony PFM-42X1 Plasma TV
Connecting pc to tv
What you need to do is right click on your deskdop, and select your videocard settings ,,, for example miune is Nivida Display,,,
any way you have to select your, It should automatically detect the tv you have connected and all you will need to do is set it up... if it doesnt detect the tv, there should be an option to detect it for you mine is in tools...
Sorry i couldnt give you a step[ by step procedure, as it varys for different adapters..
Jan 11, 2008 | Televison & Video
Computers & Internet Logo
734 people viewed this question
Ekse
Marvin
Marvin
