How do you take the front panel off to clean between the glass ?????
Slid the bottom storage compartment completely out. On the bottom of oven door are four (4) screws that hold trim piece that support outer glass panel. Remove screws and carefully remove complete glass and trim assembly. There are two (2) corner trim panels that are also secured by two (2) of the screws being removed. At this point you can clean all glass (both the outer panel that was removed and the inner insulated glass) and all other built up goop. Simply reverse process to reinstall.
This was very helpful, but I want to add that there is an extra strip along the bottom of the glass unit that is screwed onto the bottom of the door/glass unit. Upon putting it back together, an extra set of hands are needed to hold the glass, the extra piece, and the two side pieces. We ended up getting the glass out easy enough and cleaned it well, however, upon putting it all back together, must have put too much pressure on it as broke the glass!! Next time we'll call the dealer. :)
IPRESSED BUTTON ON KITCHEN AID SOVE SELF CLEANWHEN THE DOOR LOCKED
These oven doors are hard to uninstall and reinstall i worked over an hour on mine had to pay for advice. it has latches on each side,,push these toward the door close the door almost all the way then lift up and pull out.the problem i had was reinstalling.,the latch let the hinge spring toward the door and i didn't know how to release it..lay the door on the floor, take a pair of vise grips and pull the hinge down until you can push the latch back against the door to hold the hinge temp insert the door and push the latch toward and close,,,it ain't easy,,,kitchenaid is absolutely no help i have an owners manual,,,this is a new oven and it is worthless...hope this helps you,,it cost me $24 to find the answer
I have the same problem, my is frigidaire.
Under the handle are two tabs...one on the right and one on the left. Take a flat-head screwdriver and gently bend those black tabs UP, this will release the front panel. Lift up on the panel to remove it as it is sitting in a shallow groove. Now you can clean the glass on the panel and the glass still on the oven door. When you put the panel back on, make sure it is snuggly in place on the bottom groove, then tilt the upper part of the door in place. With your screwdriver, gently bend the tabs DOWN. To make sure they are holding the panel securely, place screwdriver on tab & use a small hammer to tap on the end on the screwdriver to drive the tabs back in place.
How do you remove the door to cleans between the glass on a model kesc307bal4 self cleaning range
jy
I have the same problem with KitchenAid Superba model. Can't find my manual and I cannot find anything on kitchenaid web site :(
No email address left on their web site whatsoever!
Me too. How the heck can I open the glass without breaking it?
