Question about Bushnell Deep Space 78-9512 (120 x 60mm) Telescope
Please help! I don't understand how the eye pieces work? There are no #'s - just shapes
  • 3,186 Answers
The bigger the number on the eyepiece the LOWER the magnification. Always start out with the lowest magnification, focus and center the object and then exchange the eyepieces for higher magnification.
Posted on Dec 27, 2008
  • Joe Lalumia aka TelescopeMan
    Usually the one with the largest glass element is the lowest power.
SOURCE:
Cj5 jeep ran fine every thing work now I don have head lights and no power to the starter no power
Start at the battery ground cable. Is it in good shape and on a clean ground connection. Work your way around to see if anything is loose or rubbed through on the frame. Check all the fuses in the fuse box. If you have a good DIY car pal get them to help, 2 sets of eyes is always useful.
May 20, 2015 | Spectra Jeep Cj7 76 Cj5 75 74 73 Cj6 Dj5 S...
I have recently deleted my acer crystal eye web cam because it was not working, but now i don't know how to get it back and since i don't have it i cannot use video on skype either. i have tried...
insert acer cd driver at computer, then install acer crystal eye webcam from there
or you can download installer at
http://download.cnet.com/Acer-Crystal-Eye-Webcam/3000-2110_4-202548.html
after download double click the installer then follow the instruction until finish
Best of luck!
Sep 06, 2011 | Acer Crystal Eye webcam
I have a Brother SE2700 and a piece came off that helps thread my needle, its a metal piece that goes right under neath where the needle cartiage goes in to thread my needle, I have the piece but cannot...
Unfortunately, the part may very well be broken. Unless you can find someone to repair it for you, you may have to manually thread the needle. Not such a big deal, really. Auto needle threaders have been around for only about 10 years, so machines were manually threaded for over 100 years.
Something that helps:
Lick your index finger
Swipe it across the "back" of the needle eye
(the moisture in the eye will almost cause the thread to jump through it!)
Jun 06, 2017 | Brother SE-270D Computerized Sewing...
We have a vivitar reflector tel 76700 not sure in assenbly of eye piece
Just put the eyepiece with the largest number written on it into the focuser. Take the scope outside during the day time and practice focusing on a distant object.
Dec 28, 2010 | Vivitar (1607225) Telescope
My left eyepiece on my Zhumell 20X80 will not turn to allow me to focus it. The right one works just fine. I don't want to force the left eye piece. Is there a locking mechanism I'm not aware of? Is this...
Typically the left eye piece is not adjustable. You focus the left eye with the center adjustment and then focus the right eye with the eye piece adjuster. I hope this helps.
Dec 12, 2010 | Zhumell SuperGiant Astronomical Binocular
VEIWFINDER IS BLURRY CANNOT SE OBJECTS CLEARLY
At the bottom of the eye piece there is a little slider than you can move up and down to adjust the focus. That should fix your problem if not then you are not looking into the eye piece close enough make sure your eye is pressed up against the little rubber pad and then adjust the focus.
Apr 23, 2009 | Cameras
I got a mead ds-114 telescope. & don't know how to use it!
the eye piece that came with your scope is too powerful... look on ebay or a site that sells telescopes. also look at the size of your eye piece holder... my ds-114 came with a 0.96 holder, these are an odd size.. the other size is 1.25 and the eye pieces are much easier to find. try looking at the moon when it is cresent shaped and start from there. if you have the autostar, you have to go through a set up sequence to start. then the scope will track the objects that you select on the goto function. don't give up!
Mar 06, 2009 | Meade 114EQDH4 (36 x 114mm) Telescope
Installation of a new top spray arm
should only be a little plastic push in clip facing down towards the dw in the middle of that spray arm. should be able to pop it out. you may need to take the supply tube off the back so you can get a good look at it
Nov 21, 2008 | Dishwashers
Further info on eye pc view
The recording mechanism itself was damaged in the fall and that is why it can't record new ones and also sounds like the reason the eye piece is not working the only option you have for a high tech piece of equipment like this is to have it serviced I can help you locate local repair with your zip code(or city) or you can locate the closest authorized service center here:
http://esupport.sony.com/perl/select-system.pl?PRODTYPE=1,24,26,66,9,70,5,72
If you need any further assistance please let me know.
Thanks,
Lee
Aug 18, 2008 | Sony DCR-DVD101E DVD Camcorder
Janome MyLock 744D I have been loaned this overlocker and cannot work out how to thread the final loop/eye (before the 'needle') of the right-hand bobbin. The loop/eye is positioned under the footplate....
The 744D I have does not automatically thread. There is a tiny L shaped metal piece that you push toward that back of the machine and it pulls that little eye out so you can see it. When it is threaded, then you pull that little L shaped thing back. I wish I could show you, it's hard to explain since I don't know the technical name for parts!
Mar 04, 2008 | Computers & Internet
Bushnell Deep Space 78-9512 (120 x 60mm) Telescope Logo
Top Bushnell Optics Experts
Steve Allison
Steve Allison
Ekse
Damen Wong
Damen Wong
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
