Question about Lexmark X2500 All-In-One Printer
I brought a Lexmark X2500 color all in one.It came with just one cartridge #24,and it needs two.I would like to know the cartridge numbers for each one.
  • 39 Answers
Go to Lexmark's Cartridge Finder page. Pick All-in-One in the first box. When the second box appears, pick Lexmark X2500. Then the third box will appear and click it to see all the carts you can buy that work with it.
Looks like it's 28, 29, 31, 34 or 35.
Posted on Aug 07, 2008
X2500 new black cartridge won't work
Try to insert a different known working or a new color cartridge to identify if it's a faulty cartridge issue. Please contact Lexmark Technical Support Center should you need further assistance.
Mar 28, 2012 | Lexmark X2500 All-In-One Printer
Changing ink cartridge
  • Here is an instruction set I found at http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html
  • Step 1 Press the "Power" button to turn on your Lexmark X2500 3-in-1 printer.
  • Step 2 Open the top portion of the printer to reveal the ink cartridges.
  • Step 3 Lift the gray plastic cover on the left. Remove the empty black #28 ink cartridge. Next, lift the purple plastic cover on the right and remove the empty color #29 ink cartridge.
  • Step 4 Remove the new black #28 ink refill cartridge from its packaging. Tear the protective strip of paper from the cartridge's sensor. Now, remove the new color #29 ink refill cartridge from its packaging and tear the protective strip of paper from the cartridge's sensor.
  • Step 5 Turn the cartridges so that you can read the label. This is the way the cartridges should face when being put into the printer.
  • Step 6 Slide the black #28 cartridge into the slot on the left side and push it down. Slide the color #29 cartridge into the slot on the right side and push down.
  • Step 7 Push the gray plastic cover down over the #28 cartridge until it clicks closed. Push the purple plastic cover down over the #29 cartridge until it clicks closed.
  • Step 8 Close the top portion of the printer. Your new ink cartridges are installed, and your printer is ready to use.
  • Read more: How to Replace Ink Cartridges in a Lexmark X2500 Printer | eHow.com http://www.ehow.com/how_4488808_replace-ink-cartridges-lexmark-x2500.html#ixzz0uMXO4kIN
    Jul 21, 2010 | Lexmark X2500 All-In-One Printer
    Does the lexmark x2500 need a special type of ink?
    If you go into the office supplies store, there's usually a guidebook for each manufacturer of printer, and what cartridges it takes. Otherwise, you can look on the sides of the packages, and there will be a listing of the makes of printers it will work with. If you hadn't thrown it out, an ink cartridge recycling service would take the cartridge and replace it with a refilled one, with a discount in exchange for the empty.
    Oct 22, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark printer always want a new cartridge
    What you need is to reset the ink level:
    1) Goto the Lexmark Solution Center application.
    2) Press button Maintenance>Install a new print cartridge, follow the instruction on screen. U may then have your new full ink level. Note: u only can reset to full level, cannot customize the level by your own.
    Hope this help.
    YBC (/\)
    Feb 18, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark cartridges
    According to the Lexmark Website, those are the correct cartridges. Did you compare them to the cartridges you removed? Did you remove the tape from the heads? Did you insert them properly?
    Jan 05, 2009 | Lexmark X2500 All-In-One Printer
    Lexmark x3430 need ink cartriage
    This is the only information I could find. Didn't your printer come with a black and color ink cartridge? If it did, all you need to do is take the ink cartridge out and write down the numbers written on the cartridge. The only ink cartridge I could positively confirm was the #24 color ink cartridge. The Lexmark website does not list any black ink cartridges for this model. This information was obtained from Officemax.com.
    Lexmark - 24 Ink Cartridge - Color
    Compatible with Lexmark Z1400 series, X3500 series and X4500 series printers;
    Lexmark - 23 Ink Cartridge - Black
    Compatible with Z1400 series, X3500 series and X4500 series printers;
    Sep 15, 2008 | Computers & Internet
    I have a Lexmark X3430
    If you had brought original lexmark cart you can get it exchanged as it comes with one year warranty you need to contact lexmark support to get your cart exchanged ....
    Good luck...
    Aug 24, 2008 | Lexmark X2500 All-In-One Printer
    Ticket # 49578
    If you bought your printer as part of a pakage from Circuit City it may use cartridges only supplied by them. In that case it's a #2 and a # 3. I had the same problem, they don't tell you that though.
    Jun 12, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark x2500
    Try cleaning the copper plates and install back again if the same message pops up try single cartridge if the error exits with 2 cartridges ,replace the cartridge as lexmark cart has 1 year warranty..
    Mar 25, 2008 | Lexmark X2500 All-In-One Printer
    Lexmark X2500 All-In-One Printer Logo
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
